Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 01-31-2009, 05:56 AM   #1
Davefocus's Avatar
Davefocus is on a distinguished road
RR OBD main menu indicator
Morning,
Is it possible to identify that you have OBD connectivity with an indicator in RR. I have the www displayed using "ONLINE" but wondered whether you could identify that a USB port is active?
I'm using DashCommand and I don't think it is any facility to Sendkey to RR but wanted to have an icon on the main menu to show it's availibilty, even if it means using Xport to run a script to identify port active or similar (a little beyond my ability ). Any suggestions to whether this would be possible and worth me having a go? Or would it be too much pain for too little gain!
Thanks,
Dave
Vauxhall Astra SXi Car PC installed.
Centre console screen fabrication in progress.
Davefocus is offline   Reply With Quote
Old 01-31-2009, 07:52 AM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
are you using the OBDMPG plugin? that has a connector indicator
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 01-31-2009, 07:54 AM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Davefocus View Post
Morning,
I'm using DashCommand .................................................. ...........
Thanks,
Dave
Enforcer is online now   Reply With Quote
Old 02-01-2009, 08:59 AM   #4
Davefocus's Avatar
Do you mean use xport to split the OBD USB port to run DashCommand as the OBD application and OBDMPG for OBD indication?
A valid suggestion but I think this may be too much pain for too little gain. The OBD indication is not that important - just the 'icing on the cake' really. My M10000 struggles to refresh DashCommand as it is. I must invest in an Atom 2 soon............
It was just a thought . Any other suggestions would be most welcome but I think I'll let this one go for now!
Dave
Old 02-01-2009, 09:48 AM   #5
MGD
MGD's Avatar
MGD is on a distinguished road
You can right an Autoit script that checks every 5 or 10 min to see if the application is running in the background and sets an indicator in your menu.skin file.
MGD is offline   Reply With Quote
Old 02-01-2009, 02:25 PM   #6
Davefocus's Avatar
I'll investigate into this.
Thanks,
Dave
Old 02-01-2009, 03:32 PM   #8
Davefocus's Avatar
Quote: Originally Posted by Enforcer View Post
Thank you E.
I didn't think to check whether an app was running. I guess this script would be the answer.
Many thanks,
Dave
DigitalFX 3 Main Menu Addition redsyphon Road Runner 7 04-12-2008 12:10 AM
Question about launching an embedded application fromthe main menu screen cdevelasco Road Runner 5 03-14-2005 02:41 AM
Trouble going back from TV to Main Menu Balki RR Bug Tracker 14 03-11-2005 07:25 PM
Launch M$ Iexplorer(embedded) from main menu lez MediaCar 8 01-09-2005 03:08 PM
Add Applications - Main Menu frodobaggins FP FAQ 0 12-01-2004 06:33 PM
