02-25-2009, 09:50 PM
#31
Doc!
Nice skin, as I wrote you in another thread, the new coverjuke plugin is posted in the plugins section. If you use it, let me know if you need any support with it.
02-25-2009, 10:16 PM
#32
The most stylish and consistent skin! Love it...
02-26-2009, 04:43 AM
#33
Quote: Originally Posted by ws6vert
Doc!
I'm on if, already got this set up and working great. I have this set up as my default Cover Browser. The wife usually gives me a nod of encouragement but she usually not that interested in what i'm doing. When i showed her this screen, she actually "Wowed" it and approved its addition. She even played with it for a while. Great find, and Good job integrating in RR.
Thanks Man, Trying something.
NEVER BLEND IN!!!
02-26-2009, 02:50 PM
#34
i also give my vote to make this skin as RR's default skin.
02-27-2009, 08:30 PM
#35
Well i spent some time trying to figure a way to add dynamic menu buttons. The main menu isn't going to be dynamic, but in the spirit of customization, the two alternate menus will be. I personnaly won't need then, but i know everyone uses different Apps. Anyway some held hooking up these dynamic buttons will be appreciated.
Also the following is the alternate screen i will be using for the two other menus, since i use icons and no text, can i load the glass image over the set icon to get the desired effect? and if so, what dictates in which order the images will display?
NEVER BLEND IN!!!
03-05-2009, 02:21 PM
#36
how is it coming doc?
03-05-2009, 04:47 PM
#37
wow this skin is by far the best i've seen cant wait til your done with it
03-06-2009, 01:23 AM
#38
My bwoy. Well its coming along, slower that expected because i have to do "alot" of trial and error in order to get the codes working but im getting it done. I got your update, and as expected, flawless.
Not too long before its done, no timetable. A few major parts left, but mostly little bits and pieces. I'm trying to make everything work as perfectly as possible because chances are if there are any bugs in the codes, i will be as lost as you.
NEVER BLEND IN!!!
03-10-2009, 11:07 PM
#39
Location: Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
love your work. i will be using this skin in my z at some point.
03-11-2009, 10:48 AM
#40
One Sharp Cheddar
[QUOTE=docbreezy;1295163]Well i spent some time trying to figure a way to add dynamic menu buttons. The main menu isn't going to be dynamic, but in the spirit of customization, the two alternate menus will be. I personnaly won't need then, but i know everyone uses different Apps. Anyway some held hooking up these dynamic buttons will be appreciated.
[QUOTE]
For changeable dynamic buttons, use a variable for your button code.
LIKE THIS
"$BUTTONCOMMAND1$"
This will use variable BUTTONCOMMAND1 as your command setting
You can set the variable using a setvar command and a save it using a savetoskin command. I did this in one of my earlier skins. You could also write a script that would save it to a specific section of your skin.ini alon with setting a label code and image file for use as an icon.
I attached a script I made real quick to help with creating these buttons
You will need to make sure you have an OSK for your skin and Voices enabled
have fun, read the readme.txt
Go to this thread for the download
03-22-2009, 03:02 PM
#41
DocBreezy, how are things progressing?
Anywhere near a release yet?
I'm really looking forward to installing this skin.
Best ect.
Henrik
03-23-2009, 02:06 AM
#42
Check out the bottom of the first post.. A basic version of the skin is up there for the moment.
NEVER BLEND IN!!!
03-23-2009, 02:23 AM
#43
Just messed around a little with it, stunning work man!!! Keep it up!!
03-23-2009, 02:25 AM
#44
Thanks, as you can se, its basic.. Now if i could do some of that flash magic i see you do, that would be something.
NEVER BLEND IN!!!
03-23-2009, 02:32 AM
#45
Thx back at ya,
still working on more components, feel free to use any you want in your skin, not that they are worthy of your graphic artistry  ....
| Thread Tools |
| Display Modes |
Linear Mode
