05-20-2009, 09:08 AM
#91
Terminal flasher
Quote: Originally Posted by shahabmusic
I installed latest flash player off adobe website just minutes ago :-)
then I found that wrx website which contains logos and clocks... I downloaded the package and replaced the clock shockwave with the old white one... but now when rr loads, it wont show the logo eventho I have logo_main there... but when I click on it it shows the clock but there are white edges all around the clock.
RR JUST LOADED
AFTER I CLICKED ON THE CLOCK
did you update with firefox or IE. You must update with IE if your going the activeX route.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
05-21-2009, 06:54 AM
#92
I did it with firefox and it didn't work..... yea i did it with ie and its fine now thanks a lot :-)
There is nothing impossible in the world :-)
05-21-2009, 01:33 PM
#93
RR JUST LOADED
You probably miss the carlogo png or bmp. Can't remember the name and type, but you'll find it in the readmefile for the clock.
Henrik
06-05-2009, 10:51 PM
#94
I love this skin and it's really close to what I want. Looking for a good HD Radio skin to use with it until hopefully DocBreezy gets back in the groove and finishes this great skin.
Anyone found a good HD Radio skin to use in the interim?
Carputer progress:
100% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓]
Zotac N630I-D-E M/B w/ Nvidia 7100, Celeron 430 1.8 GHz, Xenarc 700IDT, M2-ATX, RR & DFX 4.0.
06-05-2009, 10:57 PM
#95
Raw Wave
you dont need to update Flash with IE, you just need to install the FLASH ActiveX installer. located in this STICKY POST http://www.mp3car.com/vbulletin/road...sh-10-now.html
Please read all the stickies
that should do it
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
07-07-2009, 08:17 AM
#96
Sweet skin!! Any closer to release? Or maybe PSD release?
07-07-2009, 09:29 AM
#97
Check the first post, there is a pretty stable beta release with a couple psds' on there.
For all others I meant to put a note on here letting everyone know that though there seems to be little movement on the skin, it is infact still progressing but progressing slowly. i've been called back to military service so priority right now is getting personal affairs in order. As soon as i'm settled i'll get back to it.
NEVER BLEND IN!!!
07-08-2009, 12:48 AM
#98
Sorry must have missed that eventhou I have read thru this thread several times... Thanks anyways!
07-08-2009, 04:59 PM
#99
For some reason i can't get the pictures to work... Any tips?
07-08-2009, 05:56 PM
#100
Locate this line in the ExecTBL file ;
"BPICS","LOAD;Photo.skin;ImageViewer;$SKINPATH$Sup port\ImageViewer\ImageViewer.exe;ImageViewer",""
and change only this part of the line " $SKINPATH$Support\ImageViewer\ImageViewer.exe " so that it points to wherever the image viewer is. By default it should be in the RR main directory in a folder either called ImageViewer or Picviewer.
NEVER BLEND IN!!!
07-09-2009, 09:31 AM
#101
I can't find that line anywhere in the execTBL file bud... Should I add it somewhere? Any chance you can upload it or something?
I really like this skin... it's the best one i've seen by far.
07-09-2009, 06:18 PM
#102
Raw Wave
Couldn't find that line either, maybe doc is holding back on us!
Just add the line in exectbl
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
07-09-2009, 06:37 PM
#103
You know what, that was my bust... My exectbl file has been updated with the dynamic buttons, and i was looking at the wrong one. So even though you change it it the exectbl, i will not work.
Solution 1; Go through the skin file of every screen that has the photo button (Aidio_Browser, Audio_Player, Menu, Video_Browser) and change the the B03 line to reflect the image viewer path
Solution 2; Go to all those aforementioned skin files and change the B03 line to the "BPICS" command and just add that line in my previouse post to your exectbl
NEVER BLEND IN!!!
07-10-2009, 02:05 PM
#104
Hi
Where can I download the needed RRextension plugin?
I did some searchs in the forum and google, but I canīt find it...
07-10-2009, 04:58 PM
#105
Raw Wave
So you ARE holding out on us!  Just like MGD!
M2-ATX Power Supply
Windows XP SP3
| Thread Tools |
| Display Modes |
Linear Mode
