Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-13-2009, 07:35 PM   #121
ihateafropaul is an unknown quantity at this point
Quote: Originally Posted by treetop777 View Post
Can you release your latest one with the dynamic buttons so we can play with it before you move to another project
BTW - Nice animation in the flash version. Speaker icons look weird tho'
+1 on this. They look like mini UFO's
ihateafropaul is offline   Reply With Quote
Old 07-13-2009, 07:35 PM   #122
docbreezy's Avatar
docbreezy is an unknown quantity at this point
could you also check on the RRMedia Database for me, i think i have everything configures right but still can't get it to work. can't add songs or playlists to disk and the sort. I posted help in the RRmedia thread but it seams my posts are invisible.
NEVER BLEND IN!!!
docbreezy is offline   Reply With Quote
Old 07-13-2009, 07:37 PM   #123
docbreezy's Avatar
Lol, i hear y'all. Its a work in progress, but like i said its a while before i put some serious work on this so we'll see what i come up with then.
And damn i thought those wre pretty originally nice.lol
NEVER BLEND IN!!!
Old 07-14-2009, 06:09 PM   #124
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Quote: Originally Posted by docbreezy View Post
Here is what i have so far for the dynamic button version. Pls pay attention to the Please Read Me file to set correct paths as i just pull this out of my skins folder and didn't clean it up.
I didn't mean to stray from current business, i have a little bit of attention deficit lol. But no fear i have to get this skin done and stable before i turn it to flash.
P.S. i know the Volume buttons are different but again i wanted icons of my own and that is what i came up with thus far.
Thanks for sharing but after taking a look at it's guts - i'm lost! maybe cause some aspects are modeled after Carputer1's unorthodox way of coding.
Thought i could help finish it but now i don't think so.
Again, thanks for sharing.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 07-14-2009, 06:16 PM   #125
docbreezy's Avatar
Lol, you see what i released it yet though, all the codes are right but its just non-compliant. Thanks for looking though. Did you by any change check the RRMedia, to see if you can add songs and playlists to disk?
NEVER BLEND IN!!!
Old 07-15-2009, 01:28 AM   #126
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
Thats 1 way of putting it lol....
just dl'ed the attached files with dynamic buttons works well
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 07-21-2009, 09:36 AM   #127
docbreezy's Avatar
Dit it work as is or did you have to modify something? if not then we can only assume it is something system specific. Eitherway i will study some of the other skins with dynamic button to see what solution i can come up with.
NEVER BLEND IN!!!
Old 07-21-2009, 09:43 AM   #128
THE EXPERIMENTER
carputer1's Avatar
If iremember right the buttons changed straight off the only
Mod I did was set the path for imageviewer. I'll download
Again here at work and try it again give me an hour
Links
Old 07-21-2009, 10:14 AM   #129
THE EXPERIMENTER
carputer1's Avatar
Ok tested again , thebutton swap works good but not all buttons
Work after change. Like settings button , YouTube works as does video
I'll into it later for you, I think it's just the launch cmd for
Those buttons, nothing to drastic
Links
Old 07-21-2009, 12:44 PM   #130
THE EXPERIMENTER
carputer1's Avatar
ok doc found your problem its your exectbl lines for launching the cmds you use for the menu.
ie = settings , in exectbl you have this
"SETTINGS","MENU;Settings.skin","" Remove the last 2 "" then it will work
"BPICS"Load;Photo.skin;Imageviewer;Support\Imagevi ewer\Imageviewer.exe;Imageveiwer",""
2 things wrong here, again with the extra "" and you have not defined the path for the exe in the launch line, if imageviewer is in your skin folder like the line looks to suggest then your launch line should be like this
"BPICS"Load;Photo.skin;Imageviewer;$SKINPATH$Support\Imageviewer\Imageviewer.exe;Imageveiwer"
hope this helps , may need to check the rest of your code, i have only got time to check these 2 lines as trying to put my truck dash board back in after my heat matrix blew on me and i'm off on holiday tommorrow..
sorry i can't help more
Links
Old 07-23-2009, 06:43 PM   #131
Raw Wave
treetop777's Avatar
What about the backgrounds, can you make that work? I hit the settings button and nothing happens. I know it can be changed in skin.ini.
M2-ATX Power Supply
Windows XP SP3
Old 07-25-2009, 03:22 PM   #132
docbreezy's Avatar
Ha, it was as simple as that, the buttons work. Thank carputer, that was big enough help. treetop, did you change the list path and the indicator path in the BkGrnd.skin to where your background folder? Also needs to be changed in the ExecTBL, the SETBKGND, DAYBKGND and NIGHTBKGND paths. Don't worry i will be changing it to the standard $RRPATH$Backgrounds once i release so there won't be need to naually change these.
NEVER BLEND IN!!!
Old 08-11-2009, 11:34 AM   #133
richieb is an unknown quantity at this point
how is this coming on, I am waiting on it. Thanks.
richieb is offline   Reply With Quote
Old 10-18-2009, 01:48 PM   #134
shahabmusic is an unknown quantity at this point
Is there any way that I can use my silabs radio with this skin?
There is nothing impossible in the world :-)
shahabmusic is offline   Reply With Quote
Centrafuse Beta 1.40 veetid Centrafuse 27 11-12-2007 10:29 AM
laptop wont keep vid settings / Non dock compatable to use with doc?? hombredelassrta Laptops, Netbooks, Tablets, UMPCs, etc. 4 12-24-2005 11:50 PM
laptop wont keep vid settings / Non dock compatable to use with doc hombredelassrta Newbie 0 12-22-2005 10:46 AM
Infiniti G35, 7" Xenarc Install, How-To Doc god_of_cpu LCD/Display 0 02-20-2004 03:03 PM
Telxon PTC w/ DOC and WiFi Hyp3rion Newbie 0 01-14-2004 11:56 AM
