Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 06-07-2009, 10:19 PM   #1
Deric's Avatar
Deric is an unknown quantity at this point
Displaying only one set of details 1st day of Weather (5day)
Edit: I was unable to get this to work but Blue figured it out. See post 14 for details.
======ORIGINAL POST=========
I've been looking through variables and for some reason I can't figure out how to do this. I want to only display one set of images in my weather (5 day) skin. This works fine for days 1-4 but for todays weather I need to have it check first if data is available and if not display the night image. I thought I could do this by reading w_0day_hi and if it's value is "N/A" then display w0nighticon. Any help?
Deric is offline   Reply With Quote
Old 06-08-2009, 09:22 AM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i always thought this should be something added into RR. There's no reason to display 2 sets of labels/icons after 4pm. It would actually be simple to add via plugin but who knows maybe one of the RR skin wizards can whip something up with stock RR commands. I cant wait to see how that skin turns out for you
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 06-08-2009, 12:07 PM   #3
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
You can try something like this:
Indicator code:
"$DISPICON$"
On the weather button (that loads the screen) add this:
Code:
"<originalcommand>||SETVARBYCODE;DAYHI;w_0day_hi||EVAL;ISNA;strcomp("N/A";"$DAYHI$")||BYVAR;ISNA;SETVAR;DISPICON;WICON<<SETVAR;DISPICON;w0nighticon"
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 06-08-2009, 03:22 PM   #4
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
At some point, some on the basic builtin functions will be removed from the source and made into plugins. Making the RR exe the skinning engine only as Guino has wished he'd started with this line of thinking...
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 06-08-2009, 04:57 PM   #5
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Nice thread tittle.
treetop777 is offline   Reply With Quote
Old 06-08-2009, 07:03 PM   #6
Deric's Avatar
Indicator code:
"$DISPICON$"
"<originalcommand>||SETVARBYCODE;DAYHI;w_0day_hi|| EVAL;ISNA;strcomp("N/A";"$DAYHI$")||BYVAR;ISNA;SETVAR;DISPICON;WICON<<S ETVAR;DISPICON;w0nighticon"
That worked great Guino. Thanks a lot.
Old 08-17-2009, 12:55 AM   #7
Deric's Avatar
Note: I updated the title and added final code to post 1. I'm unsure if this will be needed once weather is taken out of the core code and used in a plug-in.
-Deric
2006 Mustang with indash CarPC
Parts list
D945GCLF22GB RAM20GB HDD
Opus 120W PSULilliput 8"Directed HD
RideRunnernLite XPiGO8
Old 08-17-2009, 01:57 AM   #8
The Curator
Blue ZX3's Avatar
To slightly simplify your ind part of the code, just set the "Today" ind to "wicon", that shows the corresponding day/night icon depending on what time it is..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-17-2009, 02:05 AM   #9
Deric's Avatar
I originally had that in but if the current status was different than the day or night status (say it's currently cloudy but tonights forecast says t-storms) it wouldn't give the correct details.
Parts list
Old 08-17-2009, 02:18 AM   #10
The Curator
Blue ZX3's Avatar
So what you wanted was only the day OR night icon not the current. What your looking for would be like a "wdaynighticon" that would act like the posted ind code.
[ Edit ]
Like this right?
"wdaynighticon" - Shows either the day or night weather icon, if day info not availible (>~4PM) then shows the night icon
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-17-2009, 04:01 AM   #11
Deric's Avatar
Correct - I just noticed my byvar code is backwards plus I'm not getting a true result back from strcomp
[ Edit ]
Like this right?
Parts list
Old 08-17-2009, 04:52 AM   #12
The Curator
Blue ZX3's Avatar
That has been added, but don't know if it'll make this release whenever it does get released..
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-17-2009, 05:44 PM   #13
Deric's Avatar
I'll wait for the update since I can't get it to work and I was hoping to use something similar for setting images elsewhere in the skin. It looks like I'm not getting the variable ISNA set to something. If I set a label to "$ISNA$" I get no status and it seems the ByVar command defaults to TRUE. This was the code I was using
LOAD;WEATHER_DETAIL.SKIN||SETVAR;DAYHI;w_0day_hi|| EVAL;ISNA;strcomp("N/A";"$DAYHI$")||BYVAR;ISNA;SETVAR;W0ICON;w0nightico n<<SETVAR;W0ICON;w0dayicon",
I put label commands for $DAYHI$ amd $ISNA$ and only DAYHI is showing with a temp value (75) on my weather_detail.skin. ISNA shows nothing.
Parts list
Old 08-18-2009, 12:34 AM   #14
The Curator
Blue ZX3's Avatar
Here is not only a working code, but also takes into account F & C temp labels Part of the problem was that the "w_0day_hi" label also appends the correct temp format to the "N/A" and causing all the codes above to not work correctly, to which I have to adj the PI's code as i too just noticed this...
I moved the load the end of the cmd so that when the screen is loaded the weather icon's var is already set to use the correct image. This is of course assuming that your coming from the weather screen or issued a "relaodweather" cmd before hand to populate the "w_0day_hi" label..
Code:
"Weather_5Day","EVAL;ISINTL;strcomp("USA";"$weatherunits$")||BYVAR;ISINTL;SETVAR;N/AFC;N/A C<<SETVAR;N/AFC;N/A F||SETVARBYCODE;DAYHI;w_0day_hi||EVAL;ISNA;strcomp("$N/AFC$";"$DAYHI$")||BYVAR;ISNA;SETVAR;W0ICON;w0dayicon<<SETVAR;W0ICON;w0nighticon||LOAD;WEATHER_DETAIL.SKIN"
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 08-18-2009, 02:04 AM   #15
Deric's Avatar
Thanks Blue! . I figured it might be something with the value and even tried a couple other weather items but gave up. I was actually about to go through the old source code to see if I could find the issue.
Parts list
Easy to skin? Pewter Phoenix Software & Software Development 4 11-07-2005 06:13 PM
Easy way to view and play DVD images? parvo99 FrodoPlayer 0 10-12-2005 07:13 PM
Easy and Cheap 12v-12v supply? KyleYankan Power Supplies 9 06-29-2005 07:55 AM
Noob easy question! MrLister Newbie 6 04-23-2005 02:05 PM
Easy question for most of you.. Tirade Power Supplies 1 03-27-2005 09:57 AM
