Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-01-2009, 10:02 AM   #1
riko is an unknown quantity at this point
Skin Problem
Hi Guys,
I proceed with my skin for Road Runner, I have modified the graphics :-)
Before, Version 1:
Now, Version 2:
Please I have a problem with a insert slider_play, I remember that I use as Carwing skin base, and I want to add the slider bar, for example the slider bar of Iphone_Beta skin...
please see the image :
I insert the code as in figure, but when I load the Skin and I load the audio file, the slider_play is trasparent, but work if I use the mouse !!!!!!
HELP ME !!!
after I don't understand the field : 0 , Style , H2 ... ????
thanks.
Riko
riko is offline   Reply With Quote
Old 07-01-2009, 10:27 AM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
This is in skin commands.txt:
Code:
/, (S) Slider /, Slider /, x y w h x1 y1 w1 h1 O Style Pointer file path h2 Code tooltip /, --- --- --- --- --- --- --- --- - ----- ----------------- --- ----- ------- SXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,H,01,"SLIDER3\POINTER.gif",XXX,CODE,"" The above tag creates a slider view within the given boundaries (x,y,w,h). x1,y1,w1,h1 define the area in which to display the Slider Styles (Images) -- This area is also the area where clicking with the mouse will change the slider value. O is the oriantation (H=Horizontal, V=Vertical). The Slider Style is the number of the style (Y Tag below) with the path to the images to use. *Note: You can alternatively specify a file name like "BAR.PNG" as the slider style for a single image slider. Pointer is the path to the image to use as the pointer/tick in the slider. h2 is the is the thickness or height of the pointer image. CODE is a valid SLIDER CODE defined below. /, (Y) Slider Style /, Back Slider file path /, ---------------------- YXX,"SLIDER3\SLIDER_*.gif" The above defines a style (set of images) to use with a slider. Has no effect alone. The images should range from 0 to 20 -- the * marks where to insert the number of image to load. XX is the style number to be used in the SLIDER definition.
If you have more problems after reading that, just let us know..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 07-01-2009, 10:37 AM   #3
thanks GUINO,
but I dont see the slider bar, follow I write my code :
RoadRunner Skin
RRScreen audio_player
audio_player_off.png,audio_player_off.png,audio_pl ayer_on.png,audio_player_down.png
L,757,178,40,20,255,255,255,12,"Larabiefont","Trac ktime","Right"
L,757,144,40,20,255,0,0,12,"Larabiefont","CURRENTT RACKTIME","Right"
L,698,17,101,30,0,255,0,20,"Larabiefont","Time","C enter"
L,184,562,29,30,0,255,0,12,"Larabiefont","VOLUME", "Center"
Y01,"slider_play\pointer.gif"
S02,450,485,204,39,451,486,200,25,H,01,"slider_pla y\pointer.gif",11,"SONGPOS",""
INC,Bottomtext.txt
L,757,93,40,20,0,255,0,12,"Larabiefont","Status"," Right"
B,704,388,97,145,"PLAYSOUND;C:\Documents and Settings\Federico\Documenti\file.wav||load;audio_b rowser.skin",
B,-1,225,51,74,"PGUP",
B,-1,302,51,74,"PGDOWN",
B,-1,388,97,145,"DOWN",
B,-1,64,97,145,"UP",
B,737,546,64,55,"EXIT",
B,512,546,69,55,"PLAYSOUND;C:\Documents and Settings\Federico\Documenti\mixer.wav||MIXER",@SKI N@
B,655,546,78,55,"SHUFFLE/REPEAT",
B,220,546,69,55,"MUTE",
B,360,489,83,112,"PLAY",
B,455,546,54,55,"NEXT",
B,292,546,54,55,"PREV",
B,-1,546,64,55,"VOL-",
B,66,546,78,55,"VOL+",
L,587,577,20,20,255,0,0,10,"Larabiefont","BYIND;sh uffle;<<=S","Center"
L,587,552,20,20,255,0,0,10,"Larabiefont","BYIND;re peat;<<=R","Center"
IL,PL,transparent.bmp,sel.bmp,,0,50,60
S,140,93,407,389,255,255,255,255,0,0,255,0,0,255,0 ,0,255,0,0,false,18,"Larabiefont:B"
J,559,220,123,158
/, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
IL,PL,transparent.bmp,sel.bmp,end.bmp,2,50,80
END
HELP !!!!!!!!!
Old 07-01-2009, 10:48 AM   #4
THANKS GUINOOOOOOOOOOOOOOOOOOOO...
I resolve my problem :-) ....
please I have another problem, in the image section I don,t see the preview image , i post my code :
RoadRunner Skin
RRScreen Picviewer
picture_viewer_off.png,picture_viewer_off.png,pict ure_viewer_on.png,picture_viewer_down.png
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
/, I, x, y, w, h, Code;INDICATORCODES
B,-1,225,53,70,"BROWSE",
B,-1,307,53,70,"BACK",
B,-1,387,103,148,"DOWN",
B,-1,66,103,148,"UP",
I02,144,97,350,350,"PICTURE"
L55,144,97,350,350,,,,,,"EXEC;LOAD;picture.skin||" ,""
/, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, Font name
S01,500,88,182,421,255,255,255,255,255,255,255,255 ,255,255,255,255,255,255,255,255,128,0,TRUE,14,"La rabiefont"
SD,00,03,30,30,"$picspath$","*.jpg;*.bmp;*.gif;*.p ng",FALSE
IL01,DL,transparent.bmp,sel.bmp,1,70,50,
END
Old 07-01-2009, 01:09 PM   #5
guino's Avatar
I don't see anything wrong with the skin code.. as long as you select a valid image file in the list, it should display in the preview space.
I would only suggest moving the IL line up (before the S01 line).
Old 07-02-2009, 04:14 AM   #6
Hi,
I have try to moving the IL before the S01 line, but I don't see the preview.
If I use the carwing skin I see the preview, the difference with my skin is the graphics...
mmmmmmmmmmmmmm :-(
Old 07-02-2009, 09:48 AM   #7
guino's Avatar
you are not seeing the preview IMAGE or the FILES list so you can select and see the preview ?? Also, do you have the images INSIDE the MP3 files by any chance ? (Cause if you do, you would need the mp3art plugin in your skin as well)
Old 07-02-2009, 10:21 AM   #8
Hi Guino,
I resolve, I delete the Picture_on.png, because with the touchscreen the onmouseover I don't use... I rename the file into Picture.skin and I see the preview :-) ...
Old 07-15-2009, 03:57 AM   #9
Hi Guino,
Hi at all,
please friends help me, I have many little problems (please see my video
My first Roadrunner skin...
You need to upgrade your Flash Player
When I load the Radio_Player.skin and after I load or Audio or Video .skin, the volume set to 0%... This problem is present with all skin (Carwing, BMW-E36) ... GRRRRRRRRR..
Old 07-15-2009, 09:00 AM   #10
I resolve the audio problem to set in RRconfig in the radio section the output line ( Sintetize SW) ... but I don't understand as when I load the radio, after the audio or video player and after return in radio, I don't listen !!!, I must exit to RR :-(
Why ?:-(
Old 07-15-2009, 01:12 PM   #11
guino's Avatar
did you check your radioline setting ? what version of RR are you using?
Old 07-16-2009, 02:50 AM   #12
I use the RideRunner "RR 06-01-2009 Release", yesterday I have install the upgrade "RR 07-01-2009 Release" and resolve me the problem in the video player ( before after full screen I don't see the video )...
my radio skis is :
RoadRunner Skin
RRScreen radio_player.
Y01,"hd_signal\SLIDER_*.gif"
S01,427,255,32,24,,,,,H,01,"hd_signal\POINTER.gif" ,24,"HDSIGNAL","Signal Strength"
B,11,232,49,135,"RADIORESET",
I,747,330,9,12,"SURF:b"
I02,741,418,9,12,"SCAN:b"
I,718,561,9,12,"MUTE:b"
/DESIGNED FOR HD RADIO
/Labels
L,22,12,764,34,255,255,255,24,"GE Drover","RDSNAME","scroll-center"
L,426,205,258,28,255,255,255,20,"GE Drover","RDSTEXT","scroll-center"
L,630,159,42,23,255,255,255,18,"Digital-7","=mHz","CENTER"
L,429,113,196,75,255,255,255,60,"Digital-7","FREQUENCE","right"
L,369,407,53,35,244,181,8,14,"GE Drover","VOLUME","right"
/Buttons
B,731,230,70,65,"DELPRESET||PLAYSOUND;C:\Programmi \RideRunner\Skins\Perl_White_V2.1\Sounds\deletepre set.wav",
B,719,140,81,65,"PLAYSOUND;C:\Programmi\RideRunner \Skins\Perl_White_V2.1\Sounds\editpreset.wav||EDIT PRESET",
B,704,67,100,65,"PLAYSOUND;C:\Programmi\RideRunner \Skins\Perl_White_V2.1\Sounds\add.wav||ADDPRESET",
B,401,471,98,100,"FREQ+",
B,300,471,98,100,"FREQ-",
B,-2,546,64,55,"VOL-",
B,230,394,95,74,"FMPRESET;PRESET2",
B,120,393,96,76,"FMPRESET;PRESET1",
B,584,474,74,97,"FMPRESET;PRESET8",
B,502,474,70,97,"FMPRESET;PRESET7",
B,231,474,66,97,"FMPRESET;PRESET6",
B,142,474,74,98,"FMPRESET;PRESET5",
B,584,393,99,76,"FMPRESET;PRESET4",
B,478,392,96,76,"FMPRESET;PRESET3",
B,66,546,71,55,"VOL+",
B,663,546,70,55,"MUTE",
B,0,66,90,140,"UP",""
B,0,391,90,140,"DOWN",
B02,723,392,78,67,"PLAYSOUND;C:\Programmi\RideRunn er\Skins\Perl_White_V2.1\Sounds\seek.wav||SCAN",""
B,730,306,70,65,"PLAYSOUND;C:\Programmi\RideRunner \Skins\Perl_White_V2.1\Sounds\scan.wav||SURF",
I,539,335,59,28,"STEREO"
B,703,467,99,65,"PLAYSOUND;C:\Programmi\RideRunner \Skins\Perl_White_V2.1\Sounds\tune.wav||TUNE",
S,144,99,265,253,255,255,255,0,0,0,255,255,255,0,0 ,0,244,181,8,,14,"GE Drover"
END
help :-(
How To: Get your new skin out to the masses. monkeyracer RR FAQ 10 07-19-2008 08:59 AM
"Avic'ted" - Pioneer Styled Skin monkeyracer RR Skins 36 10-19-2007 11:08 AM
StreetDeck Skin Problem Solixa StreetDeck 9 06-27-2007 11:27 AM
RR w/Blue Devil Skin - XM Problem Bump Road Runner 1 12-20-2006 10:10 AM
problem with Pioneer skin visulisations chewEboy RR Skins 16 01-26-2006 07:03 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
