Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-07-2009, 08:12 PM   #1
Tzunami is on a distinguished road
Sorry But I am about to Quit
I have been ready to put my Carputer in my car for about a month. I have posted a half dozen times and have appreciated all the help, both in responce to my queries, and to everyone for their wealth of knowledge.
But this thing has me baffled and I think I may give up.
Every Skin I download that uses a background for the skin ends up not working. and I mean every single one.
I have the most current version RR ver 1.0.1.5.
This skin is the new 506 by DocBrezy but they all end up the same.
The entire page is washed out, no buttons show until i run my cursor over them at least one, and even then the background never shows up. Very frustrating... sorry to vent...
Enclosed are two photos of what i see each time. First is before cursor the second after cursor.
Any suggestions ...while i still have hair to pull out....
Tzunami is offline   Reply With Quote
Old 07-07-2009, 08:59 PM   #2
prodigalsun is an unknown quantity at this point
Post the specs of your set up. I think that may be the reason.
prodigalsun is offline   Reply With Quote
Old 07-07-2009, 09:02 PM   #3
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
First make sure you have the GDIPlusWrapper.dll in the rr folder, and make sure it is registered. This is what allows transparency in RR.
Open the RR.ini (In the root RR folder) Look for a lines like this, if they are not there, then add it:
background=C:\Program Files\Road Runner\Backgrounds\Red_texture.jpg
backgroundpath=C:\Program Files\Road Runner\backgrounds\
Then just make sure that the path and *.jpg exist in that folder.
A good way to test, is to copy the the full path from the background= line, hold down the windows key and press R (Same as start menu, then select run) and paste the line in the run dialog box, and press enter. If the path and image name are correct, the image will open in windows image viewer, or whatever you have associated with .jpg images.
EDIT:
If it still does not work, open the skin.ini in the skin folder you are using. Make sure those lines are not in that ini, and if they are you can deleted them, or copy the ones from the rr.ini. The reason being, is whatever is in the skin.ini will take priority of whats in the rr.ini.
for instance, If you have the lines in rr.ini correct, and background=x:\pics in the skin.ini, it will overide the rr.ini
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 07-07-2009, 09:09 PM   #4
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
You need to set a background.
first, do you have a backgrounds folder in the root of RoadRunner/RideRunner with graphic files in it.
Then in RRConfig, skins section there is an option to set a background, use that to select a file from that.
or there should be a background selector section in the skins you are trying.
Enforcer is offline   Reply With Quote
Old 07-07-2009, 10:23 PM   #5
The Path
It was the path. I have them all working except Omega
and Teknk2. But i can live with what I have..
thanks so much.
Old 07-08-2009, 11:13 AM   #6
Again Thanks
I once again want to thank the community and especially JohnWPD, Enforcer and prodigalsun for responding. They are not all working but that still maybe some path stuff pointing to the wrong place.
My first order of business is to centralize the background path and then correct them all.
Again thanks
Cliff Nix
Bloomington IL
Old 07-08-2009, 11:33 AM   #7
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Do you have the latest .NET, flash and JRE?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 07-08-2009, 01:13 PM   #8
docbreezy's Avatar
docbreezy is an unknown quantity at this point
Again thanks
Cliff Nix
Bloomington IL
Not sure how all of the other skins have theirs' organized but i purposely put my backgrounds folder inside of my skin, that way i can just copy the entire skin file to my car once i've configured it. It makes things easier (for me) to transfer as some of my RR settings are different in the car than the desktop where i do most of the editing. Anyway, glad you got it working.
NEVER BLEND IN!!!
docbreezy is offline   Reply With Quote
Old 07-08-2009, 02:19 PM   #9
Confusion Master
Enforcer's Avatar
Well this was discussed many moons ago, and I'm sure it was decided that it would be better to have the Background folder in the root of RR so that all transparent skins can access then.
Obviously if you only use one skin you can stick it anywhere i guess.
Old 07-09-2009, 10:11 PM   #10
Raw Wave
mitchjs is on a distinguished road
are u using RideRunner June? use the installer!!!
install the carwings
even without a set backgound, all the new RideRunners will fall back to black
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is online now   Reply With Quote
Old 07-10-2009, 10:18 AM   #11
Super Moderator
JohnWPB's Avatar
Absolutely! For any skinners out there making new skins, please use the Root Road Runner folder for the background path. C:\Program Files\Road Runner\Backgrounds
I have 8 skins installed on my system, and 7 megs of images in the BG folder. If I had the backgrounds folder in each of the skin folders that's just a major waste of space.
It also makes standard, so you won't have the problem of backgrounds working in some skins and not others.
Old 07-12-2009, 02:42 PM   #12
Raw Wave
err... RideRunner\Backgrounds
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-12-2009, 03:56 PM   #13
docbreezy's Avatar
Nuff said, i will make note of that for future release and referances.
NEVER BLEND IN!!!
Old 07-12-2009, 11:48 PM   #14
Super Moderator
JohnWPB's Avatar
Heheh good habits are hard to break
Old 07-12-2009, 11:49 PM   #15
Super Moderator
JohnWPB's Avatar
Also following with the whole pattern, the next release of my skin will put the logo's in the root RR folder as well. There is just no sense of each skin having all of the backgrounds, logo's, 3D logos and such duplicated so many times.....
Get your gf to quit smoking Vinister Off Topic 45 09-21-2006 06:33 PM
a command line tool to quit Frodoplayer (?) ernie FrodoPlayer 0 03-08-2005 06:33 AM
I can't quit VIS without a keyboard The Grinch FrodoPlayer 2 07-27-2004 12:41 AM
Quit smoking.... PORTUGAL Off Topic 1 02-17-2004 08:20 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
