Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-14-2009, 11:03 AM   #1
spamminator is an unknown quantity at this point
Feature Request: dynamically loaded skin components
At the simplest level I'm asking for support for conditionals in skin files. I.e.:
if x = y
<some component -- button, IMG, application, custom list>
else
<some other component -- button, IMG, application, custom list>
endif
When the skin is loaded RR would load one or the other based on the values of x and y. I know you can already hide labels by changing the labelcode to nothing, but this would allow skinners to make one skin that can be used for multiple things based on some variables at load time. Like, say:
1. Load music player with album art displayed
2. Hit button for visualisation
3. Skin sets a variable, tells RR to reload this screen
4. Load music player with visualization where album art was
And you wouldn't need multiple .skin files to pull it off.
At a more complex level it would be great to be able to dynamically load skin elements WITHOUT reloading the skin. Same example as above, except RR loads BOTH elements, but only displays/draws the one based on the value of x. In this example we may need to limit it to only a true/false instead of multiple values for x.
spamminator is offline   Reply With Quote
Old 07-14-2009, 11:45 AM   #2
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
This would be another push RR over top feature...
I would think something along the lines of these type cmds...
DELBUTTONID;BXX
ADDBUTTON;<whole button define line here>
DELLABELID;LXX
ADDLABEL;<whole label define line here>
Ect...
Dont see something like this being really that hard to both use and implement....
RR Coding Team Comments????
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 07-14-2009, 12:08 PM   #3
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Mitch and I were talking about showing/hiding buttons on the skin.. similar to the flash objects.. right now, objects are created only from the .skin file and can't be unloaded (although labels/flash/indicators can be hidden and even buttons can be modified). Making RR load more objects in run-time is not that hard. Making it UNLOAD objects in run-time may be a bit of a trouble -- this may require some re-structuring of the "table" that stores the objects loaded on screen, but with some effort it could be done.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 07-14-2009, 01:14 PM   #4
I think that at least the simplistic part of my original post should be really simple. Basically when parsing the .skin file, only load into the table the objects in either the IF or ELSE case of the statement. Since you're reloading the whole screen there's no worry about unloading objects from the table. This would be a welcome change in the near term.
For Blue's idea, I think we could just use:
ADDITEM;<definition>
DELITEM;Xxx
And the object code itself should be enough to tell RR which object it is (L01, B01, etc.). Only problem there is a lot of people are gonna have to tweak their skins to not just have 50 L01s (like me... )
Old 07-14-2009, 01:16 PM   #5
The Curator
Blue ZX3's Avatar
That makes sence, espec if you del a button in the middle of the buttons array, that could be a bit messy if u latter use the setbuttonxx command b/c that btn would no longer be in that button array element but up one.
Better to hide/show would be probably best and easies for both US an skinners...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 07-14-2009, 01:32 PM   #6
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
What you are describing can be done with skin code IF you are using a reloadscreen command by way of INC in the main skin file.
i.e.
Audio_player.skin
Code:
RoadRunner Skin RRScreen menu background1.png,blank.png,blank.png,blank.png INC,inc_audio_player$displayvariable$.skin End
inc_audio_player0.skin
Code:
<Has code to display album art>
inc_audio_player1.skin
Code:
"VISU","SETVAR;displayvariable;1||RELOADSCREEN||VI SU"
The way the skin would work is that on initial loading, audio_player.skin will load it with the album art code (displayvariable = 0).
As soon as you hit "VISU" button, it will change $displayvariable$ to 1 and reloadscreen will load the code that display an application area instead of album art.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 07-14-2009, 01:36 PM   #7
i.e.
Audio_player.skin
Code:
Code:
Code:
Clever! But I still think adding support for something like this natively would be good.
Old 07-14-2009, 01:41 PM   #8
Sal R.'s Avatar
Don't get me wrong, if this could be implemented, you know i'd be using it.
More a skinner's FYI if it becomes difficult to execute.
Old 07-14-2009, 01:44 PM   #9
Sal R.'s Avatar
DELBUTTONID;BXX
DELLABELID;LXX
Ect...
The specific button ID is a real good. All my BXX, LXX, IXX codes are all 00's except for the ones I want specific control over.
Me likey.
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 183 08-28-2008 09:58 PM
hAv1c and hAv1cPlus Skin release - 800 x 480 (Transparency, custom font color) monkeyracer RR Skins 65 07-23-2008 03:03 AM
How To: Get your new skin out to the masses. monkeyracer RR FAQ 10 07-19-2008 08:59 AM
Loaded MC2.0 skin, doesnt work andres2882 Road Runner 4 09-27-2006 04:42 PM
Dependencies Nobias PhoneControl 18 01-30-2005 03:38 AM
