Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 11-08-2009, 01:13 PM   #1
cdcamaro9534's Avatar
cdcamaro9534 is on a distinguished road
Have LSX 3.01 Skin Issue. (with pic)
I've got an issue with the first screen with LSX 3.01. I could go into details, but I'll let the pic explain itself. Note that the other menus look ok, like audio, ect. Can someone tell me what might be going on. I've uninstalled and reinstalled with no luck.
1995 Chevy Camaro
VIA EPIA M10000 Mini-ITX Motherboard
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Road Runner Frontend w/ Liquid Smoke's skin
Xenarc 700IDT with DVD CDR/RW
cdcamaro9534 is offline   Reply With Quote
Old 11-08-2009, 06:12 PM   #2
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
looks like you need to install or upgrade to flash 10
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 11-09-2009, 05:38 AM   #3
zillacles is an unknown quantity at this point
I had a similar issue to yours, Flash 10 was installed both for IE and Firefox, etc etc. Turns out it was because RR wasn't closed properly before opening a new instance. Check to see if you have two RR .exe's running, or I think I also deleted rr.ini before it finally stopped doing it
zillacles is offline   Reply With Quote
Old 11-09-2009, 08:39 PM   #4
Thanks for the reply guys, I haven't got to try anything yet cause I needed a cable to finish my install. Once it's here, I will give it a try.
I'm sure I don't have two instances running, but I know flash 10 isn't installed. I'm sure this could be the issue.
1995 Chevy Camaro
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Old 11-10-2009, 07:09 AM   #5
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I'm unsure what version of RR you're running but I've seen this on OLDER versions of RR when you did not set a VALID background image for the skin to use (just a thought).
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-12-2009, 10:53 PM   #6
Ok I'm still having an issue. I've managed to get the skin kinda fixed by doing a complete uninstall, and reinstall. But I still have an issue with the white box at the bottom. I've installed Flash Player 10, but nothing changed.
I did notice in the processes that both RideRunner.exe and RoadRunner.exe were running at the same time. But only one version of RR is installed on this PC. This is a complete new install with a fresh XP.
I tried messing with the background images in RR Configure. But nothing changed. I even made sure both rr.ini and skin.ini were set the same as mentioned in a post I searched for earlier.
While the skin works, I would like to have the white box gone. I'm clueless whats causing this right now.
And this is RideRunner Version 10/6/09 if that helps.
1995 Chevy Camaro
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Old 11-15-2009, 01:30 PM   #7
mrcanngo's Avatar
mrcanngo is on a distinguished road
What version of winamp are you running?
That kinda looks like the area that the visualization should be running. Can you try upgrading/downgrading to version 5.13
Or try going (within the skins menus) to Options - Personalize - Main Menu and Vis Options - Select "Big Clock"
And see if that helps?
Just started playing with this skin so no idea if that'll help or not.
mrcanngo is offline   Reply With Quote
Old 11-15-2009, 03:00 PM   #8
Raw Wave
treetop777's Avatar
@ 9534 that is absolutely a flash problem, install this one http://www.mp3car.com/vbulletin/road...sh-10-now.html or upgrade through the adobe site WITH INTERNET EXPLORER only.
M2-ATX Power Supply
Windows XP SP3
Old 11-20-2009, 08:49 AM   #9
I've already installed with this file. I've ran it a couple of times in fact. And the first time I installed flash before doing a format and reinstall, I used the internet and installed from Adobe's website.
I've pretty much have given up in the issue. I have a few older LS skins that I ran in my Camaro. I'll probably revert back to one of those, cause they never gave me any problem. And I might toy around with a few other skins as well.
As far as Winamp, I'm running 5.12. This is what I've ran in other installs with great success. I just don't see that being a Winamp issue.
1995 Chevy Camaro
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
LSX Void FAQ ssteger VaultWiki 0 10-21-2009 04:10 PM
How to have your Skin moved to the the Completed Skins Sub-Forum JohnWPB RR Released Skins 0 09-24-2009 02:28 PM
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 183 08-28-2008 09:58 PM
TEKNIK3 - Concept Skin Valheru RR Skins 39 05-27-2008 01:26 PM
Digital FX 2.0 Transparent Released JohnWPB RR Skins No Longer Supported 3759 03-07-2008 01:23 PM
