Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 07-15-2005, 03:31 PM   #1
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
Skullster Skin.. Please help me finish this skin
ok.. first off this is a module skin.. which means I've done most of the work so you have a basic layout, and anything in the middle can be changed.
I havent done much on this, but you will see how easy it is to add your own stuff.
things I have done..
Main menu ( password is 1111 ) you can change this in menu.txt
Audio
Audio Browser
Video
Video Browser
GPS (sort of)
Exit
Skin Browser
I know theres loads to do, but if you feel like you can help then please do.
Now this skin uses freedrive as well, infact gps is on all pages. You will need to edit the sdk.ini file in freedrive to look something like this;
FDSPEED=
FDSATS=RoadRunner
FDSATIND=RoadRunner
FDETA=RoadRunner
FDETR=RoadRunner
FDHEAD=
FDROAD=RoadRunner
FDLONG=
FDLAT=
FDALT=
FDTIME=
FDDATE=
FDEND=
FDDIST=
FDUNITS=
FDMAN=
FDNEXTMAN=
FDNEXTSTREET=
FDNEXTMANDIST=
FDMANFULL=RoadRunner
FDCAMS=
Now... as I said everything is module.. so in the skin folder you will find a templete folder, in this are some blank images and also a blank.skin this holds all the buttons/info for the blank skin, all you need to do is add the middle :-)
There is a little flash in it, mainly the security page and the volume bar at the side.
Security page..
This can be configured by editing the menu.txt
&password=1111&
&exit=EXIT&
&numberofattempts=3&
//password - Just change the password to whatever you want (0-9)
//exit - Command excuted when password is wrong
//numberofattempts - how may times your allows to get it wrong before above command is used
you can set your password / number of attempts / action if wrong
If you dont want to use this, just open up RRconfig and put something like AUDIO in the Start command to execute box
Grab the Skullster 0.1 version from HERE
Please let me know what you think :-)
CdR
CdRsKuLL is offline   Reply With Quote
Old 07-15-2005, 03:36 PM   #2
FreeDrive Creator
CdRsKuLL's Avatar
o btw you will also need the LCD2 font installed on your system for it all to look nice
attached
CdR
Old 07-15-2005, 03:48 PM   #3
mox
mox's Avatar
mox is on a distinguished road
Awesome stuff -- I envy you (and other skinners) for your graphics skills!
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
Old 07-15-2005, 07:05 PM   #4
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I just added some prevention against displaying those "CENTER"/"RIGHT" labels when when FD isn't running.. will be on next release..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 07-16-2005, 03:23 AM   #5
FreeDrive Creator
CdRsKuLL's Avatar
your a good man :-) Will be adding more modules as I go along
Thanks M8
CdR
Old 07-16-2005, 10:36 AM   #6
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
love this skin!
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 07-19-2005, 11:55 AM   #7
Viscouse's Avatar
Viscouse is on a distinguished road
I love the volume button. Out of the way, yet still a design element on every page that's not intrusive or "Oh there's the volume button".
I should add that I actually really like the module idea. I love the idea of static buttons on every page, and info that shows on every page.
Can't wait to see what's next!
You know you want to...Worklog
Enjoying v1.0 since it's operational. Aaaawww yeah.
Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
Viscouse is offline   Reply With Quote
Old 07-24-2005, 07:50 PM   #8
MoFo's Avatar
MoFo is on a distinguished road
Hey CDRSkull. is this possible? instead of having album art..have a little minimap:
Photochop:
MoFo is offline   Reply With Quote
Old 07-24-2005, 07:52 PM   #9
MoFo's Avatar
or if a minimap is not possible..how about an arrow and distance to next turn:
photochop:
Old 07-25-2005, 02:11 AM   #10
guino's Avatar
The second one should be possible with a little flash or extra integration... I haven't found time to test this feature (already implemented) for MM... but there's some bug in MM's distance information (or so I hear).. I believe Arathranar is working on something to allow displaying the map in different screens... for FreeDrive you can easily do that by doing the same of the GPS screen on the audio player screen (embed&cut window) -- this would display FD's menus though.. and it may not "FIT" in the small space correctly..
Old 07-25-2005, 05:45 PM   #11
FreeDrive Creator
CdRsKuLL's Avatar
Hi Guino.. not had a play, but does the flash sit ontop of the album jpg, or does it sit below.. I could make a flash gps direction and also make it transparent when no route is played so if there is one you can see the album jpg.
CdR
Old 07-25-2005, 08:28 PM   #12
guino's Avatar
The flash sits behind it, so if an album art is available it would likely be displayed on top of the flash.. This would be no different with the MM directions currently implemented (and untested)... so the only way to display directions is to reserve screen space for it to display..
Old 08-01-2005, 06:46 PM   #13
ummagawd is on a distinguished road
i actually really REALLY like this skin.... any chance of embedding iGuidance with it *crosses fingers*
ummagawd is offline   Reply With Quote
Old 08-02-2005, 12:32 PM   #14
lagunatl2k is on a distinguished road
I second that request
lagunatl2k is offline   Reply With Quote
Old 08-05-2005, 09:37 PM   #15
DaRacerz is on a distinguished road
Also love what you have started. I'd finish off the job except I got zero artistic skill even though you already set the foundation.
Mark
Website: http://www.geocities.com/daracerz83/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
DaRacerz is offline   Reply With Quote
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 02:51 AM
Who wishes to finish this skin? mick-uk RR Skins 43 06-16-2005 06:31 PM
Frodoplayer 1.0.9 Skin Released WeeZyFellA FrodoPlayer 43 02-13-2005 11:38 PM
New Skin - Spaced_Out for FrodoPlayer 1.08 WeeZyFellA FrodoPlayer 24 10-17-2004 10:50 PM
Anyone want to finish my skin? Rireal Media Engine 3 09-01-2004 02:55 PM
