The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 06-18-2006, 02:43 PM   #136
Chuck's Avatar
Vehicle: 2001 Chevy S10 ZR2
My Photos: (0)
Update 6-18-06
Added my automatic player
Not only will it cycle thru the 4 players now but also it will cycle thru my presets in each player.
You can just have one player activated and it will just cycle thru the presets you select.
I intergraded an auto button in all my players to just cycle thru presets and read out runtime on the button. Also if you hold the button it will take you to the settings skin.
The cycle will automatically stop if you go to anther player
I forgot to put the add to rr.ini file – down load at bottom of this first post
2001 S10 ZR2
Chucks Skin
Chuck is offline   Reply With Quote
Sponsored Links
Old 06-18-2006, 06:55 PM   #137
Vehicle: '07 Toyota Tacoma TRD Sport (Black Double Cab 4x4)
My Photos: (0)
I cannot believe how complicated and advanced your skin is. Much props to you Chuck for the constant upgrading and hardwork you've put into this skin.
replicant
my ride:
TacoPC (worklog)
TacoPC (flickr pics)
*Eclipse AVN-6610bt For Sale!
replicant is offline   Reply With Quote
Old 06-19-2006, 06:33 PM   #138
Chuck's Avatar
My Photos: (0)
Update 6-1-06
Changed some stuff in the automatic player
Took out last screen setting – works by itself now
Added hold and resume
Works with GPS mode in players now
Fixed lockup when you start with no players selected
Down load update.zip file at bottom of post 1
2001 S10 ZR2
Chucks Skin
Old 06-22-2006, 07:32 PM   #139
Chuck's Avatar
My Photos: (0)
Update 6-21-06
Well I like this automatic player so much I decided to add all my presets.
Added manual mode – set timer to 0
Added next and previous selection – just use next and previous in all my skin at bottom right when automatic is running
Changed some stuff
Fixed a lot of stuff
Update file at bottom of post 1
2001 S10 ZR2
Chucks Skin
Old 06-25-2006, 09:18 AM   #140
Chuck's Avatar
My Photos: (0)
Update 6-25-06
Automatic player changes
Added a little help scroll
Added indicator in bottom buttons so you know Which player is activated
Changed auto button in all players – white for single player mode red for switch player’s mode
Fixed xm last screen not working right
Update at bottom of post 1
2001 S10 ZR2
Chucks Skin
Sponsored Links
Old 06-27-2006, 06:10 PM   #141
Chuck's Avatar
My Photos: (0)
Update 6-27-06
Did more stuff with automatic player
Fixed typeo-bug in xm – not showing active xm
Added wait for end of song in audio player part
Changed timer 0 5 10 15 20 30 45
Added countdown for end of song
Added underline indicators to see what’s going on with presets
2001 S10 ZR2
Chucks Skin
Old 06-28-2006, 01:34 PM   #142
Chuck's Avatar
My Photos: (0)
Update 6-28-06
fixed audio not changing when radio is off
2001 S10 ZR2
Chucks Skin
Old 07-09-2006, 03:13 PM   #143
Chuck's Avatar
My Photos: (0)
UPDATE 7-9-06
Added pic viewer with slide show
Multi player stuff
New quick menu
Now with auto mute so you don’t hear all that junk wile the channels and play list are changing.
Wait for end of song now works XM and Sirius too. – thx guino
Faster saves and restore – thx guino
With this skin your better off not running an ExecTBL.ini in the RR directory – just rename it
http://mywebpages.comcast.net/charlesrichards/ChucksSKINII.zip
2001 S10 ZR2
Chucks Skin
Old 07-09-2006, 07:15 PM   #144
tn6478's Avatar
My Photos: (0)
Hey chuck how do u make your skin center with 800 by 600 its always going somewhere else on the screen
tn6478 is offline   Reply With Quote
Old 07-10-2006, 11:27 AM   #145
Chuck's Avatar
My Photos: (0)
I do not understand what somewhere else on the screen is.
That space at the top is so you can see IG and copilot directions all the time when you hit the Nav-IG button a second time.
Then you can hit the bottom bar to get IG full screen.
Look at post #31
But you can change it in the general.ini file
2001 S10 ZR2
Chucks Skin
Old 07-10-2006, 11:35 AM   #146
Chuck's Avatar
My Photos: (0)
Update 7-10-06
Had a bug in the ExecTBL.ini file with Sirius – file at bottom of post 1
2001 S10 ZR2
Chucks Skin
Old 07-11-2006, 07:39 AM   #147
tn6478's Avatar
My Photos: (0)
What I mean is i am using 800 X 600 but when i turn your skin on, you skin is not center. Its half off on the screen and I can still see the desktop. i tried to change your skin in the general.ini to 800X600 but then your skin looked funny
Old 07-11-2006, 11:50 AM   #148
Chuck's Avatar
My Photos: (0)
You need to turn Clear Type on and then it should look just as good as 1024x768
Control panel
Display
Appearance
Effects
Use the following method to smooth edges of screen fonts:
Clear Type
Then ok and apply
The setting in the General.ini file
OriginalWidth=1024
OriginalHeight=683
ShowWidth=800
ShowHeight=534
XPosition=0
YPosition=66
if you do not what the space at the top
OriginalWidth=1024
OriginalHeight=683
ShowWidth=800
ShowHeight=600
XPosition=0
YPosition=0
2001 S10 ZR2
Chucks Skin
Old 08-11-2006, 04:53 PM   #149
i3igmind's Avatar
Vehicle: 1994/Honda/Accord
My Photos: (0)
Unhappy Why
Quote: Originally Posted by Chuck View Post
This is the older Down load
http://mywebpages.comcast.net/charle...rds/Chucks.zip
It is still not 100% but it will give you something to play with
why my skin doesn't look like this even after the update, can you help??
HOnda Accord '94
i3igmind is offline   Reply With Quote
Old 08-12-2006, 06:16 PM   #150
Chuck's Avatar
My Photos: (0)
What does it look like?
Try removing these from the ExecTBL.ini From the Road Runner directory – not the from the chucks directory
"ONFILECLICK",""
"ONDIRCLICK",""
"ONPLCLICK",""
"ONDLCLICK",""
"ONPBCLICK",""
"ONPLSELCLICK",""
"ONDLSELCLICK",""
"ONSONGSTART",""
"ONSKINSTART",""
and let me know
2001 S10 ZR2
Chucks Skin
Sponsored Links
vB code is On
Trackbacks are Off
I'm dating a deaf chick Grayscale Off Topic 114 02-22-2006 04:47 PM
1994 ford explorer recessed lilliput lots of pics! xdjxklusivex Fabrication 13 01-06-2006 09:20 PM
Fusion of Zaurus and '00 Accord (lots o' pics) Xumbi Show off your project 18 07-12-2005 10:47 PM
1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO! voidunknown Show off your project 20 02-07-2005 09:58 AM
Can't create a post with lots of pics?? tbird2340 Suggestions/Comments 2 09-09-2004 01:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
