The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 03-07-2007, 04:21 PM   #241
Chuck's Avatar
Vehicle: 2001 Chevy S10 ZR2
My Photos: (0)
Update 3-7-07
I did so much junk that I don’t even remembers what I did.
http://mysite.verizon.net/charles.ri...cksSkinXII.zip
2001 S10 ZR2
Chucks Skin
Chuck is offline   Reply With Quote
Sponsored Links
Old 03-11-2007, 09:09 AM   #242
Chuck's Avatar
My Photos: (0)
Update 3-11-07
I think I have the Net detect and auto update perfected now.
This Net detect senses RR and if RR closes then Net detect will close itself also will close itself if BYVAR;NETDETECT;0.
This Net detect will only down load if, set interval, ping and vehicle speed has been met.
This net detect has settings for update intervals, vehicle speed, ping intervals, ping timeout, site to ping, auto weather, auto traffic and a auto custom and every thing can be set from the skin on the fly.
Also added auto custom so you can have the netdetect update or run anything RR will do at update time. – hold the custom button to set.
The weather and traffic .exe’s have been refined to integrate with RR and fail safe the files they are downloading so if a file failed they restore the old file till the next download.
The weather updater will check to see if weather.com is present before running “RELOADWEATHER” command. – how many times have you had RR hang because of this.
These files are for this skin so good luck trying to use them in your skin.
You must have voice=true in rr.ini file to get the full benefit of this skin and these updates.
http://mysite.verizon.net/charles.ri...ksSkinXIII.zip
2001 S10 ZR2
Chucks Skin
Old 03-12-2007, 01:46 PM   #243
Chuck's Avatar
My Photos: (0)
Update 3-12-07
Forgot to bypass the max vehicle speed for auto download when the cell phone is on.
Just drop this in the \Program Files\Road Runner\Skins\Chucks\Installs\Online folder.
In the process of adding auto cell phone dial in X amount of time if no wifi has been connected.
2001 S10 ZR2
Chucks Skin
Old 03-17-2007, 08:24 AM   #244
Chuck's Avatar
My Photos: (0)
Update 3-17-07
Well this auto update thing is working excellent.
There different modes
Auto WiFi, Auto Cell phone and both together.
In auto WiFi you set the intervals to start hunting for a connection and when it finds one it checks to make sure your not going over the max speed you have set and downloads then starts the timer over.
In Auto Cell phone you set the intervals to start the dial-up and downloads at intervals set.
If auto WiFi and Auto Cell phone are selected it will start hunting for a WiFi connection at intervals set and if no connections are found it will start the cell timer and if no connections are found then start the dial-up and downloads
http://mysite.verizon.net/charles.ri...sSkinXIIII.zip
EDIT; Added WiFi Hopper to the WiFi Scan skin
2001 S10 ZR2
Chucks Skin
Old 03-18-2007, 06:19 PM   #245
LawnGOD's Avatar
My Photos: (0)
Beautiful Looking skin....
but I just cant seem to get it running. Downloaded the latest package (XIIII I think), and followed instructions in the readme. When I open RR and choose the XIIII skin and restart RR, I get the install screen. 1 and 2 seem to install correctly. When I click 3, it looks like Winamp stops in the background. But the install screen just sits there. I can close it with a right click, but then I go right back when I restart RR. I have read the entire thread and cant seem to make it work. I think I am missing something obvious but I cant tell what. Any ideas or help would be greatly appreciated.
Thanks in advance,
==LawnGod
LawnGOD is offline   Reply With Quote
Old 03-18-2007, 06:45 PM   #246
Chuck's Avatar
My Photos: (0)
I changed some stuff in the command for 3 and it works for me but it must not on some pc so I will change it later.
For now open the skin.ini in the chucks folder and change the SETUPDONE=0 to SETUPDONE=1 and that should fix it
Make sure you are using the RoadRunner.exe in the chucks folder or newer.
EDIT; If you was not using the RoadRunner.exe in chucks folder then try it first before trying the skin.ini change and let me know.
2001 S10 ZR2
Chucks Skin
Old 03-20-2007, 05:36 PM   #247
My Photos: (0)
Great skin, but I'm having a few problems
The skin looks great and I can't wait to use it, but I'm having a few problems.
-The top doesn't show up. It seems this is done with flash, but it doesn't work at all.
-The setup never completes. I tried chaning SETUPDONE=1, but from then on it never works right. I have to tried to configure buttons, and even when I enter button edit mode, clicking on a button and then an option (Audio MP3's for example) won't do anything.
-The exit option seems to do nothing at all. I have to right click on road runner to close.
Any help would be appreciated. It seems like I'm missing something simple, but I have no idea what. Thanks again for the great looking skin.
tboneuls is offline   Reply With Quote
Old 03-20-2007, 06:20 PM   #248
Vehicle: 1999 Chrysler 300M
My Photos: (0)
tboneuls (& LawnGOD too) - I had the exact same issues you describe last week and after repeated re-installs, I started typing a post here and noticed there is a RoadRunner.exe file in the Chucks directory. I copied that to my RoadRunner directory (2 levels up) and replaced the RoadRunner.exe that was installed by the RR installer (as Chuck mentions above)---and my problems went away! You might try that procedure, as I can confirm it worked for me.
rlarson128 is offline   Reply With Quote
Old 03-20-2007, 07:56 PM   #249
Chuck's Avatar
My Photos: (0)
YES YES YES YES YES
You must use the beta RoadRunner.exe file in the Chucks directory OR newer and replaced the RoadRunner.exe that was installed by the RR installer in the RoadRunner directory
I have an update coming out in a day or so to change day night skin automatically along with some bug fixes amd Smoother auto update for weather and traffic.
2001 S10 ZR2
Chucks Skin
Old 03-22-2007, 11:08 AM   #250
Chuck's Avatar
My Photos: (0)
Auto day night working good with my internal skins. thx blue zx3
2001 S10 ZR2
Chucks Skin
Sponsored Links
Old 03-24-2007, 11:25 PM   #251
LawnGOD's Avatar
My Photos: (0)
Wonderful skin...
Loads of options already installed. I will be running this skin. But I cant seem to get the Truetype Fonts correct. I followed the instructions about installing ChuckRR.ttf. But when I double-click the file, it just opens a doc with all the diff size symbols. Then when I open RR, some button indicators have a weird label.
Any help would be greatly appreciated.
Thanks very much for a great skin.
==LawnGod
Old 03-25-2007, 06:01 AM   #252
Chuck's Avatar
My Photos: (0)
You need to install the font for this skin in window fonts
Control panel
Fonts
File
Install new font
Then point it to ChucksRR.ttf file
2001 S10 ZR2
Chucks Skin
Old 03-25-2007, 07:29 AM   #253
Chuck's Avatar
My Photos: (0)
UPDATE 3-25-06
Added Auto day night skin changes.
Changed the skin setup to use the actual audio player.jpg’s files so if you mod a skin it will show up – loads slower.
Only 14 *.jpg’s for each skin to change the whole appearance.
Improved the auto update stuff.
Fixed some bugs
http://mysite.verizon.net/charles.ri...ucksSkinXV.zip
2001 S10 ZR2
Chucks Skin
Old 03-25-2007, 08:30 AM   #254
LawnGOD's Avatar
My Photos: (0)
ChuckRR.ttf
That did it!. Now everything runs perfectly! Thanks Chuck for a wonderful skin, and outstanding support!
==Lawn
Old 03-25-2007, 09:23 AM   #255
Chuck's Avatar
My Photos: (0)
Your welcome just let me know if I can help with anything else.
2001 S10 ZR2
Chucks Skin
Sponsored Links
vB code is On
Trackbacks are Off
I'm dating a deaf chick Grayscale Off Topic 114 02-22-2006 04:47 PM
1994 ford explorer recessed lilliput lots of pics! xdjxklusivex Fabrication 13 01-06-2006 09:20 PM
Fusion of Zaurus and '00 Accord (lots o' pics) Xumbi Show off your project 18 07-12-2005 10:47 PM
1997 Chevy Trukputer - DONE! Lot's O' Pics! WHOOO HOOOO! voidunknown Show off your project 20 02-07-2005 09:58 AM
Can't create a post with lots of pics?? tbird2340 Suggestions/Comments 2 09-09-2004 01:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
