Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 12-07-2005, 11:04 AM   #136
Hark's Avatar
Hark is on a distinguished road
Gimme dat!
Hark is offline   Reply With Quote
Old 12-08-2005, 12:31 AM   #137
Hark's Avatar
Does anyone else using this skin with XM have the sat reception bar/meter not located properly? It seems to be too low. Also, resuming from standby to XM (last screen/thing listened to) doesn't seem to work properly, have to go out then back in. This may not be a skin problem, though.
Old 12-08-2005, 12:48 AM   #138
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
This is a known issue if you have a XMPCR instead of the XMD1000 ... sometimes also if you have a crappy/cheap USB->Serial Adapter for the XMD.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 12-08-2005, 06:40 AM   #139
kbreeden
I'm running the skin at 800x600 and the "sat" bar is too high and the "Ter" bar is too low.
I'm using the XMPCR for XM. The only problem I've noticed regarding hibernation is that in order to get music to play I must start in the mode that was playing when I hibernated. In other words, if I was in XM when I hibernated I must start music playing in XM before I can hear mp3s. The reverse is also true. It's a minor issue which I can certainly live with.
kbreeden is offline   Reply With Quote
Old 12-08-2005, 09:58 AM   #140
b8bboi is on a distinguished road
Hark, I haven't tested the XM skin since I don't have the hardware. You can use SkinEditor to rearrange the components and maybe post back the fix here and I'll update it. Thanks.
b8bboi is offline   Reply With Quote
Old 12-08-2005, 10:40 AM   #141
Hark's Avatar
I'll try - I'm very new at this, but maybe this is the push I need to learn more about it. Great work on the skin.
Old 12-08-2005, 10:42 AM   #142
Hark's Avatar
I have the XMD unit (the one that's free after rebate now!). I had WebDog make me a cable, it seems very high quality and works very well - not sure if this is to blame for my problem. I'll also search if there's a way to make RR "reload" the XM screen on standby resume, which I think would solve it.
Old 12-08-2005, 10:44 AM   #143
replicant is on a distinguished road
This is definitely a solid skin/foundation to build on Hark for your learning.
replicant
Audi A4 (flickr pics)
replicant is offline   Reply With Quote
Old 12-08-2005, 10:55 AM   #144
kbreeden
Ha, I'm learning too. I didn't know anything about skinning until about 30 minutes ago. The Skineditor is crucial. Makes things understandable. Anyway, I have attached a modified XM skin that properly lines up the signal bars on my desktop running RR at 800x600. Now we'll see if it also works on my carputer. Let me know if it works for you.
Oops, when I tried on carputer the indicators were perfect, but everything else was messed up. I don't advise using the file. I'll work on it some more.
Old 12-08-2005, 01:24 PM   #145
Will Albers is on a distinguished road
OK, why does my igmod still have the title bar at the top? Its in the right place, but as soon as i press the volume button it falls to the back of the screen. There is something I am not doing right... anyone?
I have RR config set as external, with it pointing to igmod. I have the window name as --iGmod something--. I tried that and iGuidance with no change.
Will Albers is offline   Reply With Quote
Old 12-08-2005, 01:36 PM   #146
PURDooM's Avatar
PURDooM is on a distinguished road
--iGmod Reloaded--
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 12-08-2005, 01:42 PM   #147
Quote: Originally Posted by PURDooM
--iGmod Reloaded--
correct. That should embed the window into RR right? eliminating the title bar and allowing normal button fucntionality without sending the application to the rear?
edit - got it... typo
Old 12-08-2005, 05:57 PM   #148
Has anyone gotten the CDrip application to work? I cant seem to get it to close.
Old 12-09-2005, 09:52 AM   #149
kbreeden
XM Signal Level Indicator Update:
The XM skin contained in the above XM.zip file does fix the locations of the XM signal strength indicators when viewing RR at 800x600 and 800x480. The XM problem I mentioned was not related to the edited skin, but to the fact that XM had inadvertantly cancelled my account. All's working fine now.
Old 12-09-2005, 02:06 PM   #150
Added 800x600 version for CFX Blue. See first post for link.
mac style skin release... btbe RR Skins 42 08-14-2007 10:07 AM
Cf - Corvette Zo6 Style... BLOWNZO6_pc RR Skins 7 01-15-2006 09:13 PM
Why we need PSD files from CF std skins justintime CF Plugins 4 11-05-2005 08:20 PM
XP Pro on CF card working!! knubile WinNT Based 48 01-03-2005 07:48 PM
XP on CF II Drive NOS TANG Software & Software Development 13 11-30-2004 02:20 PM
