Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 10-25-2005, 08:07 PM   #1
b8bboi is on a distinguished road
Release: Proximo's CF style skins
As promised, here're the green, orange and red versions. Also the new CFX blue version has some bug fixes (mostly in the GPS skin) so re-download it if you want. Thanks liquid_smoke for the web host.
Green
CFX Green
Orange
CFX Orange
Red
CFX Red
Original Blue
CFX Blue
Blue at 800x600
CFX Blue 800x600
To make your own color, see post #60.
Extra tools.
This contains the transparent OSK, Zorro's PicViewer and my batch files for a couple of small extra functionalities (mainly support for Audio CD). You can skip this if you don't care about those.
CFX Tools
Please check for virus as I cannot guarantee anything.
PSD is here.
PSD
One thing though, the PSD has a lot of sets and layers so it will take you a while to figure out where things are. It kinda goes like this.
Frames = Main metallic frame (different ones for different skins)
Left Menu Bar = left menu bar
Dots background = Usually go with the selected Frame above
___ Buttons = The button bar on the bottom, usually the media buttons (some skins like TV, Phoco have extra buttons at other places)
___ Button Bar = The button bar on the side (PgUp, PgDown, Up, Down, etc.)
___ Windows = Main Window in the middle
___ Bottom Buttons = Buttons on the bottom right corner.
Blue ZX3 is also kind enough to host the complete set of PSDs. You can download them here.
http://myspotontheweb.no-ip.org/inde.../page0003.html
Each PSD corresponds to a skin. Small note: on menu.psd, I changed the Radio icon to say "Misc" since I don't have Radio in my CarPC. The Radio icon is still there if you want to re-enable it.
Update: Just added the ability to sort playlist by Date Modified, Song Name, Randomized or Reverse (thanks Chuck for the code). Please download CFX.zip and CFX_tools.zip if you care for these.
Installation Instructions
1. Download and unzip CFX skin into C:\Program Files\Road Runner\skins\
Download and unzip CFX_tools into C:\Program Files\Road Runner\
You final directory structure should look like this.
C:\Program Files\Road Runner\skins\CFX\
C:\C:\Program Files\Road Runner\CFX_Tools\BATs\
C:\C:\Program Files\Road Runner\CFX_Tools\PicViewer.NET\
C:\C:\Program Files\Road Runner\CFX_Tools\UBoard\
2. Install the fonts inside C:\Program Files\Road Runner\skins\CFX\fonts\
You only need to install GEDRBI__.TTF for now but just do all 3 of them to be safe.
3. (Recommended) Copy the Winamp presets from CFX\mixer_presets\ to C:\Program Files\Road Runner\
4. (Optional) To use Dinasty's flash logo on the main menu, download yours from here.
http://underconstruct.4t.com/LS%20Clocks/
Make sure you save it as clock.swf (inside my CFX folder).
(Read bottom of menu.skin for more details on how to replace the logo with your own or switch to RR logo. I use 2 menu skins so whatever you change in menu.skin, do the same in menu2.skin or you'll have two different looking menus.)
5. If you want to use the transparent OSK included in CFX_Tools, you need to install .Net Framework from microsoft. Download it here.
http://www.microsoft.com/downloads/d...displaylang=en
If you use PicViewer.Net, make sure to change the setting in C:\Program Files\Road Runner\CFX_Tools\PicViewer.NET\PicViewer.NET.Confi g.xml
6. (REQUIRED). Read ExecTBL.ini for instructions on how to change the values of a few parameters, particularly
LOADCD command:
"LOADCD","RUNQW;C:\Program Files\Road Runner\CFX_Tools\BATs\LoadCD.bat" "E||LOADLIST;C:\Program Files\Winamp\winamp.m3u;Audio CD||!BROWSE"
Edit this line so that it points to your CD drive (the "E||LOADLIST" part. Change it to D||LOADLIST if your CD Drive is D.)
Path to iGuidance:
If you use iGuidance, change the path to it in the following line. Otherwise, the FULLSCREEN button won't work.
"iGuidance_Fullscreen","LOAD;external_gps_full.ski n;RUN;C:\Program Files\Road Runner\SKINbedder_v2.99999\SKINbedder.exe;SKINbedd er"
I'm using Skinbedder. If you're not sure, open RR.INI and just copy and paste the values under "gpspath" and "gpsname" over. Replace "C:\Program Files\Road Runner\SKINbedder_v2.99999\SKINbedder.exe" with your gpspath and replace "SKINbedder" with your gpsname.
7. Open Audio_browser2.skin. Somewhere around line 78, change the path there to the path to your MUSIC folder. Otherwise, browsing by Album Art won't work.
SD,02,02,120,120,"D:\"
Change "D:\" to your music folder, for eg., "E:\My Music\" etc.
I don't know why we have to do this. It should default to the Music folder set in RR.ini.
8. (Optional) These skins are customizable. Read the .skin files and parts that are marked with /****__**** for instructions.
menu.skin and menu2.skin: Blank logo, Dinasty's flash logo, RR logo, Toyota logo.
mixer.skin: Provide your own favorite Winamp presets.
radio_player.skin: Change one of the buttons to point to either XM or Sirius.
9. Note: There're a few buttons here and there that do nothing right now. They're there for future's upgrades. Most notably,
Sync button on bottom right of main menu.
Fullscreen button in Video player. It only hides the control but doesn't expand the video itself to Full screen. I need to check back with guino on this one.
Maximize button in Video Player. This is supposed to switch between Normal mode and Playlist mode (where you can see the video playlist AND the video at the same time). I'm waiting for guino's support on this one.
SUB button in Video player. I'll try and get it to work with Vobsub/fddshow to disable/enable subtitles. It probably won't be functional any time soon. It's only there to fill space.
10. The GPS speed unit (yellow text to the right of the song LCD) is not built-in so right now I set it to mph. I apologize to UK users. For now, you can do a global Find and Replace on all .skin files for "mph" and replace it with "kmh." I will probably provide an easier way for you to do this in Stage 2 (basically the speed unit will be an image file and all you do is replace the default one with another that says "km/h").
Also, just above the GPS speed is a heading indicator image. I provided the 8 files (W.jpg, NW.jpg, etc.) but I don't know if it works or not since I don't have a GPS unit. Try and let me know.
That's about it, I guess.
CREDITS
All credits go to proximo from the Centrafuse 's forum for the initial design. I simply took over and made a skin for RR. (did spend 2 months adding stuff though ).
Dinasty for a couple of Photoshop pointers and the Flash clock/logo that will be used in the skin.
Zots and guino (author of BMV) for a couple of sliders.
liquidsmoke for a few skinning ideas (and I stole 2 icons from you, too. )
Untested Skins
Since I don't have the hardware/software to test these out, the following skins will be provided but untested.
- Radio, XM, Sirius
- iGuidance, Freedrive, Map Monkey (and their full screen versions)
- PHOCO
- CDRip
If/when you discover bugs, post back here and I'll gladly update.
Also, I won't be making Mappoint skins. However, the PSDs will be released so you can make it yourself.
Screenshots
Main menu. You can use Dinasty's flash logo in place of my Toyota logo. Instructions will be provided later.
Main menu with Road Runner logo.
Music
b8bboi is offline   Reply With Quote
Old 10-25-2005, 08:11 PM   #2
Music with Visulization
Video
Browser in Album Mode.
Old 10-25-2005, 08:11 PM   #3
OSK
Old 10-25-2005, 08:12 PM   #4
Phone Control
Old 10-25-2005, 08:14 PM   #5
Weather
Old 10-25-2005, 08:30 PM   #6
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
This Skin Is Blazin Hot
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 10-25-2005, 08:32 PM   #7
SMKFree
i want to test it now
mp3car live search
Old 10-25-2005, 08:34 PM   #8
SMKFree
is this considered spam?
anyway, i just noticed the CF inspired layout, IMO looks loads better than the default CF skin. What is TranksOSK?
mp3car live search
Old 10-25-2005, 08:37 PM   #9
SMKFree
ok, last post.
can i have your internet connection indicator icon?
mp3car live search
Old 10-25-2005, 08:40 PM   #10
ls, thanks, dude. Nah, you're not spamming.
Quote:
What is TranksOSK?
It's a transparent OSK that I found somewhere. You click that. RR's OSK goes away and a transparent OSK appears so you can see through what's underneath.
Which one are you talking about? The one that says "ONLINE" is just simply text in Arial.
Old 10-25-2005, 08:42 PM   #11
SMKFree
the the transparent OSK a seperate app? if so i would like to check that out also. The icon is the one in the lower right hand corner in the first image. I assumed you were using it as a connection indicator, thats what i want it for.
mp3car live search
Old 10-25-2005, 08:51 PM   #12
wariow is on a distinguished road
pics dont' load for me
wariow is offline   Reply With Quote
Old 10-25-2005, 08:54 PM   #13
Yeah it's a separate app. I'll provide that with the skin, of course. Just need to find a decent web host.
That icon is supposed to be a Sync button that I intended to integrate with EZSync. It's not functioning right now, only there for future's expansion.
Like I said, I'll be releasing the PSD together with the skin so you can take whatever you need.
BTW, this is only stage 1.
In stage 2, the menu on the left will be completely customizable as well as the buttons on the main menu skin.
Also, hopefully I'll be able to provide Green and Orange Heat versions. Or whatever colors you guys want.
Here's some screenshots of those 2.
Old 10-25-2005, 08:54 PM   #14
Tainted Love
Cris's Avatar
Cris is on a distinguished road
This looks really sweet! I'm not that fond of the menu bar on the left though...the backgrond of it.
Could you make one in green?
Cris is offline   Reply With Quote
Old 10-25-2005, 09:00 PM   #15
You mean the sublte background? I really like it. (It's proximo's idea, of course). To each his own, I guess.
A green one will be in stage 2. Right now I can't even find a host for version 1.
mac style skin release... btbe RR Skins 42 08-14-2007 10:07 AM
Cf - Corvette Zo6 Style... BLOWNZO6_pc RR Skins 7 01-15-2006 09:13 PM
Why we need PSD files from CF std skins justintime CF Plugins 4 11-05-2005 08:20 PM
XP Pro on CF card working!! knubile WinNT Based 48 01-03-2005 07:48 PM
XP on CF II Drive NOS TANG Software & Software Development 13 11-30-2004 02:20 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
