10-31-2005, 11:54 PM
#91
RoadRunner Mastermind
Hey CDR, nice work yet again... you've got PM on the Pic Viewer Plugin (works nice)... I love the album art thingy... I just need to make a SIRIUS screen and I'm set....
Regarding the issue with being able to click Flash behind the menus... I don't believe I can do anything about it... it's just how the Flash object works..  I guess you could (at most) add some code to your flash script to check if the current screren in RR is the same one that the object was loaded onto (hard coded name I guess)...
Ride Runner RR's Myspace
11-01-2005, 09:41 AM
#92
FreeDrive Creator
will add a few lines to check present screen :-) Thanks for the PM about the picview, got it working now, with a zoom also. Still got to play with it a bit more, Gobby has added ini settings and hes progressing with it further. This will be released with the MC3.0 version in a couple of weeks, will start skinnning afew more things next week I think. O btw, just checked the update to RR.. still no If Frm.DL.Tag <> "DEFAULT" Then fix yet :-p for the album cover default path I see. A have also been playing with flash embedded in a exe, then using this exe as a embedded application in RR, results seem good so far, with the exe embedded my cpu load is at 5%, but when rr embedded just the swf file it jumps up to over 30%.. so I can now try playing with more effects and stuff :-)
will let you know how I get on
CdR
11-01-2005, 09:46 AM
#93
The skin is great m8....what could use a little "push up" is freedrive...speed cameras and other neet stuff
great work man!!!
Virando costas ao mundo
Orgulhosamente sós
Glória antiga, volta a nós!
11-01-2005, 11:50 AM
#94
The Vauxhall Vectra Project
Whats MC stand for ? Most Cool ?
Terran
#95
CdR
Sorry, I think I fixed it, but overwrote it with the changes TheUni made.. can you post the little bit of code it had it again ? I think it was right on ShowForm() right ?
11-01-2005, 12:00 PM
#96
Is it possible to remove the MC logo in the left lower corner?
11-01-2005, 01:02 PM
#97
Raw Wave
CDR & Guino, can one of you shed a light?
Anyways, I tried adding 2 buttons on the games.skin file. My goal is to play all the builtin games without keyboard/gamepad.
One button on the left blank area:
ACTIVATE;Form1||SENDKEYS;{LEFT}
and {RIGHT} on the other side... it doesnt work tho... any idea? I tried without Activate also... Form1 seems to be the embed name being used by the game.skin file.
Thanks!
Roy
2005 Range Rover 4.4
11-01-2005, 01:13 PM
#98
Quote: Originally Posted by camsgs3
im really feelin this skin...a couple of things
1. The mute indacator doesnt turn red when pressed, it only works on my home PC, not car
2. when i play a new song, the previous song info(name,albumart) is still loaded on the main page...i have to hit the play button 2x(pause,play) for it to show correctly
3. I tried the rr.exe you posted in this thread, and boy it runs alot smoother then the current 10-16 version...my only problem is there no album art.....cdR whats "added albumart label" did u add, maybe im missing somthing
4. can you post a PSD file of just the buttons, i want to finish my IgMOD skin..is anyone working on a theme.ini file to match this skin?
here is a look:
is anyone else having these problems...
11-01-2005, 01:30 PM
#99
FreeDrive Creator
Select Case Frm.Tag
Case "video_browser.skin"
If Frm.DL.Path <> VIDEO_PATH Then
Frm.DL.Path = VIDEO_PATH
Frm.DL.Value = 0
Frm.DL.CenterList
End If
Case "audio_browser.skin", "search_browser.skin"
If Frm.DL.Path <> MUSIC_PATH Then
Frm.DL.Path = MUSIC_PATH
Frm.DL.Value = 0
Frm.DL.CenterList
End If
Case Else
If Frm.DL.Tag <> " DEFAULT" Then
Frm.DL.Path = Frm.DL.Tag
Frm.DL.Value = 0
Frm.DL.CenterList
End If
End Select
ta
CdR
11-01-2005, 01:31 PM
#100
FreeDrive Creator
nope sorry.. its coded in.. I have to have some branding :-)
11-01-2005, 01:32 PM
#101
FreeDrive Creator
Thanks!
I tried too.. but sadly couldnt get it working either...
11-01-2005, 01:35 PM
#102
FreeDrive Creator
The mute has prob got something to do with your soundcard drivers on your carpc.. or maybe how you mute in rrconfig.ini.. not noticed the double click needed to refresh details... but that wont be a skin fault if its happening, I will have a look and see if I can do out about it. The Album art is a browser thing, will be fixed in next release of rr
o.. MC = MediaCenter :-)
11-01-2005, 03:00 PM
#103
Confusion Master
I've had a similar problem with sendkeys trying to send keystokes to Red Deaths's Emulator
#104
Confusion Master
MC= Manchester City
11-01-2005, 03:02 PM
#105
Raw Wave
did ya fix it?
Roy
| Thread Tools |
| Display Modes |
Linear Mode
