The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Closed Thread
Thread Tools Display Modes
Old 01-09-2007, 11:42 PM   #181
Ruffy's CarPC Specs
Ruffy's Avatar
Vehicle: 2000/Chrysler/300M
My Photos: (0)
woah major bug
so I was working on audio_full_player.skin
I went into editor. Added a button, hit file save.
It sprung out a BAD FILE error at me.
imediately the screen was screwed up. It showed menu.skin image but with the audio player buttons. I close it, reopen the editor and go back to the skin
its replaced all of audio_full_player.skin with the contents of menu.skin
Freaky
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline
Sponsored Links
Old 01-09-2007, 11:43 PM   #182
Ruffy's CarPC Specs
Ruffy's Avatar
My Photos: (0)
udpate..... it no longer provides errors.
Apparantly it did not like audio_full_player.skin i was working on and decided to remove it...
freaking great
dunno what it didnt like in the skin.... but all is well now. disregard everything above. removing the .skin files didnt cause it. I just thought it did.
Ruffy is offline
Old 01-10-2007, 01:05 AM   #183
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
So is all good now? Except for the editor removing the one file, Which is bad. Only idea is maybe you had notepad open with the skin file. or some other program may have been using it still. Then trying to save to a file that was open somewhere else would probably cause the program to crash.
Has this happened again? And i was going to ask for a copy of the failing skin but it sounds like its gone?
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline
Old 01-10-2007, 01:16 AM   #184
pRoFiT's Avatar
My Photos: (2)
Thinking about the properties box/text size when adding commands......What if the small/medium/large setting only effected that dialog box that comes up? Would that work? I really really wanted to make a better tool for the properties box.
Damn just had a kewl idea for adding new commands to the editor. Well i was thinking i could have a program pull out all unknown objects from a directory of skin files and then auto build them into the objects.txt file. Although thinking about it....if guinos commands.txt file is consistant on objects i could probably parse through that document and save all objects to the skineditor objects.txt file................Oh well its late gnite all.
Ive made a couple more fixes/changes. Trying to figure out the drop down box issue before next release. unless there is a big bug someone finds
Edit: Damn guino!!!! Inconsistent with his skin commands.txt file. Looks like more work then just doing it by hand for each release!!!! Maybe i could parse through the source files for RoadRunner ......nah. okay now gnite!
pRoFiT is offline
Old 01-10-2007, 05:11 PM   #185
Ruffy's CarPC Specs
Ruffy's Avatar
My Photos: (0)
all is well now
Notepad wasent open
there must have been a glitch in the skin somewhere and the editor couldn't parse it properly. can't have a copy since the editor "took care" of that little problem
if it happens again i'll be sure to make a duplicate copy of the offending skin
Ruffy is offline
Old 01-11-2007, 01:32 AM   #186
kpjuk's Avatar
Vehicle: Peugeot 807 - 2003
My Photos: (0)
Hello Profit,
a while ago I tried to create a consistent objects.txt, based on skin commands.txt
If we can get to a consistent file, I can include this in the Help File, which may be a way forward. What needs to be done, can I help in any way ? The skin editor is key to clean development of skins for RR, so your contributions need to be fully supported by the community.
Let me know what I can do, but don't include programming! I did have a look at your source, and it was well beyond my simple capabilities.
cheers
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
kpjuk is offline
Old 01-12-2007, 12:49 AM   #187
pRoFiT's Avatar
My Photos: (2)
Quote: Originally Posted by kpjuk View Post
Hello Profit,
cheers
KPJUK
I was up late the other night writing the begining to a Skin Commands.txt file converter aka objectgrabber. I just need to parse through the file and pull out the relevant information. From what I saw so far most objects had a common layout in the text file.
/, (B) Buttons
/, x y w h Command Tooltip
BXX,XXX,XXX,XXX,XXX,COMMAND,TOOLTIP
But some objects had less info and others had another comment line that contained more info on each property. Like above code would have "This is sent to RR" and such. So what I was going to do was read file until "/," then read first line without "/" and split based on "," which would give me the BXX line, The only problem then is what is XXX,XXX,XXX,XXX Where if I save the previous lines I can try to extract "Buttons" from line 1 "x, y, w, h, command, tooltip" from line 2 and match up with the BXX,XXX line.
Of course this doesn't take into consideration commands/CODE that get added to RR. That would be a whole other process to parse through and retrieve information.
So
/, (<object here aka B, IMG, L, A>) <Name for me to display, or function>
/, < Actual description of each parameter separated by , >
/, --- --- --- --- ------- ------- (Don’t really care bout this line)
BXX,XXX,XXX,XXX,XXX,COMMAND,TOOLTIP <-- this could be <object aka B>,<parameter names would be better here but showing pace holders is okay I guess> I.E. B,XXX,XXX,XXX,XXX, <-- maybe XXX for any numeric value
Not sure about that last line. It may be okay the way it is. As long as COMMAND,TOOLTIP,XXX and other default naming conventions stay the same.
R,B,G are numeric values so XXX is fine for me In fact all plain text/numeric values could be XXX on that last line. FONT, STYLE, CODE have actual values that are buried in the Skin Commands file that I pull out and manually put into skineditor objects file. Also Color is an added feature that requires a certain layout in the objects.txt file.
Maybe if I have more time to think about it I could layout a word document or PDF to describe a standard command list to go by. You know just incase we get an ISO Audit
PM if you want to talk more about this.
edit: p.s. this is what i end up with for the button command in my file
Button,B,x,y,w,h,Command;COMMANDCODES,Tooltip
COMMANDCODES triggers the skineditor to put the [...] to open a list of commands. Same for color "what ever,Forecolor R;RGB,g,b,whatever" RGB triggers a [...], on the "Forecolor R" Field, for a color picker the drops values into field r g b. So i would need to know that r,g,b would need r;RGB,g,b in my file. so as long as r,g,b is standard and not b,r,g or g,b,r or Pr,Yb....you know what i mean.
pRoFiT is offline
Old 01-12-2007, 01:16 AM   #188
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Skin Commands text file
May the force be with you!
Just in my small travels, I have a lot of commands myself that are not in the skin commands.txt file.
Some of the below are labels, some are commands, but one thing for sure, there is no mention of them listed in the skincommands.txt file. I am quite sure there a LOT more than this.
(Some of these are used in the skins, and some are just variables that can set certain functions in RR. Most of them can be shown as labels, and thus should be understood by the editor as such)
Here are just a few that I personally know of:
speedatt
speedattmute
speedattunit
speedattgrad
speedattvola
speedattvolb
speedattspeeda
speedattspeedb
speedattmode
speedattvolzero
speedattvolgainat50mph
speedattmaxstep
speedattvolzero
OnSongStart
AvsTransparent
igautosw
gpsonvoice
pauseonvoice
lastscreenswitchtime
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline
Old 01-15-2007, 09:20 AM   #189
deus ex machina's Avatar
My Photos: (0)
Undo/Redo is working in this version: http://www.mp3car.com/vbulletin/showthread.php?t=87357
Also, the changes are all commented, so it should be easy to combine the code with a later version.
deus ex machina is offline
Old 01-15-2007, 09:32 AM   #190
Ruffy's CarPC Specs
Ruffy's Avatar
My Photos: (0)
please please release a simple update swaping the mouse button back. Rightclick move is not natural.
Also i found some autolock/bugs/issues
If i go to editor, then go back everythings locked. Have to unlock all to do anything.
Ruffy is offline
Sponsored Links
Old 01-16-2007, 12:25 AM   #191
pRoFiT's Avatar
My Photos: (2)
Fine! <reserve right to remove later>
Done, check first post for new version. Plus fixed the auto lock comming out of virtual editor and put spaces between groups of objects.
pRoFiT is offline
Old 02-08-2007, 04:41 PM   #192
Vehicle: 2003 Sentra Spec-v
My Photos: (0)
Id like to download your version of the skin editor but your site seems to be down. Might you post a new location where I can download it?
Thanks!
Click Here to see my Car's Website
2003 Nissan Sentra Spec-V
Spec-V is offline
Old 02-08-2007, 10:04 PM   #193
pRoFiT's Avatar
My Photos: (2)
Thanks!
Weird. Um its still working for me. Goto the first post of this thread. Download version 0.3.023 <-- I havn't updated my website for this version. It only has version 019 and 022. 023 puts the mouse back to left click and fixes a couple minor things that I missed when I released 22.
pRoFiT is offline
Old 02-09-2007, 05:05 AM   #194
Ruffy's CarPC Specs
Ruffy's Avatar
My Photos: (0)
Just want you to know... I love you man
*runs away sobbing while the download starts*
Ruffy is offline
Old 02-09-2007, 09:27 AM   #195
My Photos: (0)
I just realized, Its most likely the fact that I am at work. Ill try at home tonight!
Thanks!
Spec-V is offline
Sponsored Links
Closed Thread
vB code is On
Trackbacks are Off
Some notes on my carputer's progress. Comments? *WITH PICS* Bailey General MP3Car Discussion 10 01-16-2005 11:53 PM
MediaEngine Development Progress Update CarComp Media Engine 23 01-07-2005 12:53 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
