01-09-2006, 07:57 PM
#91
Okay i just got it to with P01. First its due to the fact that P is somewhat new and it needs to be added to the objects.txt file. There is also V, IDL, TMR and SD that are not in the objects.txt file. When i get home i will add these objects and see if that fixes the P01 runtime error 9.
Okay looks like a bigger issue then i thought. All above items Excluding PhoneBook List are non drawable items. Looks like a bug with non drawable items. If i change it to drawable and give them x y coordinates there is no problem.
But i did manage to add the rest of the objects into RRSkinEditor. Now i just need to fix the crashing with them. This is top priority on my list i will get to undo and preview after these are fixed.
01-10-2006, 12:32 AM
#92
Okay that took what like 30 minutes, minus all this thread editing and file uploading. Anyways i think the Y - Slider crash is fixed and i also added TMR,IDL,P,V,SD to the object list. I must of somehow missed them last time I added to objects.txt. Enjoy. Let me know if this fixes the y and p crash issues.
p.s. Woops one more thing. Forget I ever said Alpha, you didn't see anything  . I removed the old 015 link without virtual editor. Im just going to keep one link
http://home.comcast.net/~cstrachn/RRSkinEditor.rar Version 0.3.018 with Virtual editor
01-10-2006, 03:51 AM
#93
tryed with the latest version, 0.3.018 and now i get a error 9, substring out of range, on all of the skins i have...
01-10-2006, 12:39 PM
#94
Me too thats wierd. It worked at home. well then no one download this one. i will fix it tonight.
Edit: Alright i know what i did. I need to add some more error checking on the mouse move function. I think its checking for an item without checking to see if its within range. i.e 20 objects and it looks at 21. Easy fix. sorry guys try back tonight.
01-10-2006, 08:27 PM
#95
Okay sorry about that it should work now
Version 019
Link also found on first post.
I'm just going to create a skin with two of everything to use for testing.
01-10-2006, 11:46 PM
#96
i get the error 13, type mismatch again, on the skin (wip) cranium, can some one else try it??
01-11-2006, 12:16 AM
#97
I just downloaded wip cranium and it opened up okay. I went through all the skins and they all came up. What exactly do you do when it crashes? Which skin, object and what were you trying to do to it?
okay i found this
C:\Program Files\Radiator\Stations\default.rsd
In the star trek skin file and it caused RRSkinEditor to give the error 13. Anyone know if a rsd file path is okay in the skin? It was the radio.skin file. Okay i guess it was F that gave me the error. As in frequency. I will add that to the objects.txt file and it should fix that error. but im still not sure about the file path being in there like that.
marazi: error 13 might be due to an object not being in the objects.txt file. When guino adds things to RoadRunner the objects file needs to be updated to keep up with the changes.
p.s. I added some bugs in the create new skin button  I will try to get to it tomorrow. Also I will update 019 to include some added changes to objects.txt. need to find the layout for frequency so i can add it too. dont think i saw it in guinos list of commands.
okay updated link to RRSkinEditor v0.3.019 with new objects.txt file. Marazi try it again redownload the program and see if it crashes.
01-11-2006, 07:55 AM
#98
ive updated with the new release, and it still crashes...
im no expert on this, but i will try to do some tests to see if i can locate where the error is...
01-11-2006, 08:33 AM
#99
@Marazi, what screen of the Cranium skin is crashing? do you know what you are doing just prior to the crash?
EDIT- I have opened cranium skin in vers 019, I have gone through every screen and moved some things around and resized and added a label, used both editor and virual editor and no crashes here.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
01-11-2006, 09:10 AM
#100
it crashes when i open the skin, as soon as i have selected the folder, i get the error and it closes, im trying to open the cranium 0.2 version and the 01 version with no luck... Is there any paths i need to change or any other setup that needs to be done with the skin editor?? im using the .net 2.0 framework, got anything to do with this??
01-11-2006, 09:17 AM
#101
I would try to re-download the cranium skin and try it again. I absolutely cannot cause a crash with it no matter what I do. Download the skineditor too again.
http://www.savefile.com/files.php?fid=8734243
Please help.
01-11-2006, 09:32 AM
#102
will do
01-11-2006, 09:35 AM
#103
still the same...
maybe you can make a pack for me J187?? include your skin editor and your cranium in a zip file or something, if this dont work on my computer, it might be something elese with my system...
01-11-2006, 09:39 AM
#104
this is what i see as soon as i open the skin:
01-11-2006, 09:59 AM
#105
Ok, try this, the cranium skin is in the ZIP folder.
http://www.savefile.com/files.php?fid=6545420
Please help.
| Thread Tools |
| Display Modes |
Linear Mode
