Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Closed Thread
Old 12-20-2005, 02:37 AM   #1
pRoFiT's Avatar
pRoFiT will become famous soon enough
RRSkinEditor BUGS / FIXES / COMMENTS / CURRENT PROGRESS OUTDATED
Well Guino added a ton of things to the editor to keep up with RoadRunner. Check out his thread here http://www.mp3car.com/vbulletin/rr-s...or-v0-5-a.html
Okay This should make it easier to find the current version of RRSkinEditor. If anything changes I will make it known in this first post. Except for the occasional post whoreing in my own thread
First off: Lbooker Wrote the original version of this software, Guino added some functionality and then I stumbled onto it. I have been fixing and adding functionality to this program for a couple months now. So I'm getting the hang of where everything is.
Second: This thread is for RRSkinEditor only. Bugs in the program. Any functionality that you may want or feel would make it easier to use. Or things you hate about it would be okay too.
Okay here is the good stuff.
Current Version of RRSkinEditor With new Virtual Editor V0.3.019
http://home.comcast.net/~cstrachn/RRSkinEditor.rar
Beta Version of RRSkinEditor With new Virtual Editor V0.3.024 Use UNDO/REDO at own risk
http://home.comcast.net/~cstrachn/RRSkinEditor024.rar
Current Source of RRSkinEditor found here
http://home.comcast.net/~cstrachn/RR...itorSource.rar
Source may be behind a couple versions
Microsoft VB Runtime Files Version 6.0 sp5. May be needed to run RRSkinEditor
http://www.microsoft.com/downloads/d...D-CDF2D29A79D5
Current Suggestions that I might work on are:
JohnWPB: Add PNG support to editor. 4-15-2007 <-- will look into.
4-22-2007: working without transparency will need to investigate the png format some more.
Royn: Add Ctrl Click on buttons to open the skin it points to when the command LOAD is used. <-- still thinking about this one ......Probably use the update RoadRunner skin command to reload the skin in RoadRunner
1-3-2007: Still not implemented
liquid_smoke: Enable/Disable Objects from displaying there box. That way you can click on an object that is behind something else without selecting something else. <-- started on this one. Got side tracked with virtual editor and some other bugs. Still working on it.
1-3-2007: Added to version 0.3.020
Display image attached to an IMG object <-- next on my list, somewhere on my list
Virtual Editor with Undo/Redo commands Directly embeded into RRSkinEditor <-- Virtual editor is working but needs improvement still.
Properties Box: Like in photoshop or frontpage. Would get rid of the double click to adjust settings. Click on an object and the Properties Box updates to reflect currently selected object. <-- started to work on this but can't find the best way to do it yet.
1-3-2007: Still on my list of things to do
Fixes:
Version 001-005
Added Flash playback ( kind of buggy, need to redesign this section )
Fixed crash with the up down order of object buttons
Version 006
Moved over the command [...] button
Added move objects with mouse
Version 007
Added Object Adjustment with mouse
Version 008
Added create new skin menu button
Version 011
Added x1y1 on slider to match xy when moving with mouse ( need to go back and add 2 boxes for this feature)
Fixed crash with adding Y slider style (my bug)
Version 012
Added default in the ini file to cause the program to use program directory for skin locations when first installing.
Added Auto focus to done on all objects to make it faster on objects that don’t need more then xy coordinates
Version 013
Fixed auto focus bug that caused curser to go to done when ever the command box changed.
Version 014
Fixed mouse adjustment when zoomed in or out
Fixed y slider style crash when pressing up/down/left/right
Version 015
Fixed GENERAL.INI failure during save when creating a new skin or skin folder with no GENERAL.INI file.
Version 016-017 of RRSkinEditorAlpha - okay beta
Added Virtual Editor
Has autosave configurable through settings
Autohighlight of object when switching to virtual editor.
Added compatability with /DISCARDABLE as a skin setting
Version 018 RRSkinEditor
Fixed crash when adding any non drawable items such as y - slider, IDL, TMR, and V - visability.
Version 019 RRSkinEditor
Fixed crash when opening skins with y - slider, IDL, TMR, and V - visability
I guess I should have saved and then reopened
Version 020 RRSkinEditor [1-3-2007]
Right click to move objects
Lock/UnLock buttons added for easier selection of complicated skins
Undo/redo added to the VirtualEditor only
Text will adjust to zoom command
Comments added as objects - can edit in editor
added /INC to objects.txt
/IMG will display image at x,y location
DISCARDABLE spelt right
Version 021 RRSkinEditor [1-4-2007]
Fixed comments highlighting objects
Fixed crash when selecting comments
Fixed bug where objects next to comments dont come out as brite as the other yellow objects
Version 022 RRSkinEditor [1-5-2007 1:00am]
Vixed copy paste key commands in virtual editor.
Switched auto lock off and now have it default to unlocked objects.
Version 023 RRSkinEditor [1-15-2007]
Switched auto lock off comming out of virtual editor
Switched drag object back to left click!!!!! some people are never happy
Soon to be selectible left or right click for the leftys out there.
added auto space between groups of objects. Make it easier to read. Plus it used to do that before i added comments
Version 024 RRSkinEditor [4-22-2007]
Added PNG support for layout.
NOTE: Transparency will be filled with white by default. Until further investigation into PNG. I may use Guinos GDI+ code. Once i've had time to understand how he is doing it.
Please feel free to send in the BUGs so I can help the mp3car community. And Guino of course
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline
Old 12-20-2005, 03:46 AM   #2
Meelobee's Avatar
Meelobee is on a distinguished road
Added link to this thread in tutorial
[■■■■■■■■■■■■■■■■■■■■] Install 80%
WWW.ZDCLAN.NL
Meelobee is offline
Old 12-20-2005, 05:15 PM   #3
pRoFiT's Avatar
Thanks Meelobee.
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline
Old 12-22-2005, 08:53 PM   #4
-zip-'s Avatar
-zip- is on a distinguished road
I use RRSkinEditor a lot, I really enjoy useing it. Thank you for keeping it going!
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline
Old 01-02-2006, 02:57 PM   #5
ITL
ITL's Avatar
ITL is on a distinguished road
I have been using RRSkinEditor for several months now. Not sure what version I'm on, but just found this when looking for drag and drop functionality. Can't wait to check it out!
My only desire at the moment is an efficient tab-index. I prefer keyboard navigation to mouse at most times and the tab-index on the old version completely blows. It's all out of whack. Hopefully it's been updated or can go on a to-do list. Thanks again! This will help me to wrap up my skin even quicker!
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline
Old 01-03-2006, 06:16 AM   #6
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
ok heres a simple request.. can you add a button on the menu bar or somewhere to open current skin folder ? I'm unsure how others skin, but I use a mixture of notepad to edit the skin and also your editor.. infact thinking about it.. two requests, 1 to open current skin folder and 2 to refresh current loaded skin :-)
cheers
CdR
CdRsKuLL is offline
Old 01-03-2006, 08:55 AM   #7
ITL
ITL's Avatar
Quote: Originally Posted by CdRsKuLL
ok heres a simple request.. can you add a button on the menu bar or somewhere to open current skin folder?
or at least set a default directory
500+ full albums
4,000+ video games
old carPC
ITL is offline
Old 01-03-2006, 04:11 PM   #8
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
actually, thinking about the last 2 request, i too use the skineditor alot along side of textpad. It would cool to be able to open the current screen loaded into a text editor of your choice.
Like an edit source button, (just like in a web browser) and in the settings you can point to the text editor you want to use for editing.
beer replenishment fund
mp3car live search
liquid_smoke is offline
Old 01-03-2006, 04:40 PM   #9
replicant is on a distinguished road
that's ana wesome request liquid.. after starting my new skin, i am also using a text editor alogn with the skineditor and find myself doing quick layouts with the skin editor then tweaking it in ultraedit, but having to close skin editor and re-opening to see changes. good job with the adidtions you've made to this app, profit.
replicant
Audi A4 (flickr pics)
replicant is offline
Old 01-04-2006, 04:53 AM   #10
SMKFree
yeh, it sucks when you forget you made changes in a text editor then go back to skineditor and resave the skin. Doh!
mp3car live search
Old 01-04-2006, 09:27 AM   #11
ITL
ITL's Avatar
Another idea, if you could implement some type of buffer, perhaps you could create an UNDO feature (with the CTRL + Z shortcut of course)
500+ full albums
4,000+ video games
old carPC
ITL is offline
Old 01-04-2006, 09:35 AM   #12
JPuma's Avatar
JPuma is on a distinguished road
I find that when my screen is in 800x600 mode and I open the properties to an object and the objects properties are really long I cannot see the bottom of the object window and the up down scroll dosent work when a objects property window is open.
JPuma is offline
Old 01-04-2006, 11:23 AM   #13
J187's Avatar
J187 is on a distinguished road
is it possible to
a. Fix the Tab order so that when you tab it goes in sequence with the boxes?
b. Make it so that when a textbox gets focus, the text is selected?
it would make skinning way way faster.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings View Post
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
J187 is offline
Old 01-04-2006, 11:37 AM   #14
J187's Avatar
Profit, are you kidding me? You added resize and move by mouse?? I could hug you!! Why haven't I seen this before (especially before I spent 3 hours on my skin LAST NIGHT typing coordinates!!) Thank you so much for your work. It is greatly appreciated!!
Please help.
J187 is offline
Old 01-04-2006, 12:09 PM   #15
pRoFiT's Avatar
Alright guys hit me all at once
Notepad sounds great. I dont have the current source at work so I will have to wait until I get home. The Notepad gave me a good idea as to how I will add undo to the editor. I'm not sure how easy it will be to add undo across multiple skins but I should be able to do it with current skin in view. Not sure if it will slow down the program but i guess we will see.
Default directory? Current version will use rrskineditor directory/skins for the default skin folder.
CdRsKuLL: Link to current folder should be easy to do.
Okay before i start on notepad here is my idea on it. To make it a virtual notepad linked to RRSkinEditor. So that when opened it will pull in the current skin and from there you can save and auto update to RRSkinEditor. That way you wont have to worry about not saving changes between the notepad and the editor.
Although if you want to have RRSkinEditor to just open any text editor with the skin file linked to it. You will have to worry about saving from one editor to the other.
Let me know what you guys think I can go either way or maybe even both
JPuma: Thought about that for a while. What if I created a properties box inside the view screen Sorta like photoshop has property box. Then I could display current object properties when selected?
J187: I will have to look into tab order. Not sure what you mean by text in the textbox?
pRoFiT is offline
Closed Thread
Some notes on my carputer's progress. Comments? *WITH PICS* Bailey General MP3Car Discussion 10 01-17-2005 12:53 AM
MediaEngine Development Progress Update CarComp Media Engine 23 01-07-2005 01:53 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
