12-28-2005, 01:04 PM
#61
Quote: Originally Posted by devin98
This is what I did:
I Pointed RR to iguidence.exe in its default location, and set it to external GPS, however when I click GPS in RR using the LSX skin it opens up a different window with iguidence.
Iguidence is install in its default location
-Devin
Are you sure you're spelling it correctly? You keep spelling it iguidence here but it's iguidAnce
12-28-2005, 01:07 PM
#62
Quote: Originally Posted by kbreeden
Unable to D/L skin from posted link.
Strike that. It downloaded fine, but I was confused because the download box didn't appear until after the download completed.
12-28-2005, 01:08 PM
#63
ok I tried all that I have the LSX skin installed in
c:\program files\road runner\skins\LSX
the LSTools installed
c:\program files\road runner\LSTOOLS
RR pointing to external GPS to c:\program files\Inav\Iguidence\iguidence.exe
it still opens a normal iguidence window externally
12-28-2005, 01:09 PM
#64
yes sorry it is spelled right, well with road runner its just point and click anyhow
12-28-2005, 01:33 PM
#65
Which GPS option do you have checked? Is it the External one? Also LSX skins has some other folders, where did you download the ENTIRE skin to? is it in your c:\program files\road runner\skins\LSX folder? Which Skinbedder are you using? Hopefully the one he suggested. Did you also update the Exec.. ini file in the root of road runner? I suggest you read his instruction again and double check everything.
PROGRESS 95%[//////////■]Complete - Software configurations
Current Task: Just adding on...
Needed:wireless keyboard/mouse
My Carputer Blog
Car System Site
12-28-2005, 01:36 PM
#66
I am using the skinbedder that came with the skin, I have external gps selected, the skin files are in c:\program files\road runner\skins\LSX
The LSTOOLS are in c:\program files\road runner\LSTOOLS\
Can you advise on to where his instructions are? I did not know what to update in the Exec..ini file
-Devin
12-28-2005, 01:39 PM
#67
I'm not on my home PC right now to tell you but maybe once I get home and can actually look at it I could be of more help. For now, backup your Exec file in the road runner root and replace that with the one in the skin and test.
My Carputer Blog
Car System Site
12-28-2005, 01:56 PM
#68
I managed to get it working, I pointed RR to c:\program files\road runner\LSTOOLS\SKINbedder_v2.99999\Iguidance\start up.exe
and it seemed to work
12-28-2005, 02:00 PM
#69
In the INI file? That's where the path is suppose to be, great job.
My Carputer Blog
Car System Site
12-28-2005, 11:19 PM
#70
SMKFree
you dont have to copy or move the ExecTBL.ini file from the skin folder, it stays in the skin folder. RR uses both the ExecTBL.ini file that is in the root of RR and also checks the currently loaded skins folder for ExecTBL.ini and it uses the commands found in both files.
12-28-2005, 11:23 PM
#71
Ah good to know.
My Carputer Blog
Car System Site
#72
SMKFree
there should not be a SKINbedder_v2.99999 folder inside of LSTOOLS, you must have copied that folder from somewhere else.
it should be
LSTOOLS\SB2.9\SKINbedder.exe
you dont point anything to startup.exe that file is used by SKINbedder.exe to launch and kill the nag screen in IG
12-28-2005, 11:24 PM
#73
Are all GPS buttons suppose to work? I currently only have the zoom and the full buttons that work.
My Carputer Blog
Car System Site
12-28-2005, 11:28 PM
#74
SMKFree
Quote: Originally Posted by Erwin
Is it also possible to use Mapmonkey or Freedrive? I have FreeDrive configured in RRconfig but it doesn't start up when I click on the GPS button in the skin. When I click the GPS button RR tries to startup iGuidance, because I don't have iGuidance installed i get an error messege. How can I use MM or FD?
Freedrive currently is only supported in the older version of this skin, LS3.0betaX
There will be updated freedrive support later.
all this info is in the first post!
12-29-2005, 12:04 AM
#75
Sorry I don't use any of them so I guess I don't pay muuch attention to them. I use IG. Are you supporting both skins? Old and New? I see the old is day skin and the new is night skin.
Can this also use SkinBedder 3.0?
My Carputer Blog
Car System Site
| Thread Tools |
| Display Modes |
Linear Mode
