Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 01-09-2006, 03:01 AM   #106
SMKFree
liquid_smoke's Avatar
liquid_smoke is on a distinguished road
yeah, looks like you missed the window title in the first one, "GPS"
The other two are only accessible from the initial gps screen
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 01-09-2006, 04:31 PM   #107
Pheebs'67 is on a distinguished road
OK then - Added the window name (sorry I missed this - I'm still new to all this!) but this still doesn't work ... (it might be worth mentioning that I've tried several skins and none take to embedding this app very well)
Any other ideas?
Pheebs'67 is offline   Reply With Quote
Old 01-09-2006, 04:48 PM   #108
b8bboi is on a distinguished road
since you're new, you need to read this.
http://www.mp3car.com/vbulletin/rr-faq/45536-how-do-i-setup-my-gps-application.html
b8bboi is offline   Reply With Quote
Old 01-11-2006, 04:06 AM   #109
neuwacom is on a distinguished road
Hi liquid_smoke
LSX is the Best RR Skin that i have seen. I use it on my Car and it works fine.
Is it possible to download the PSD File for the MENU2.skin ?
I need only Musik,Video,NAV,and Phone Icons on this Screen. And want to change the Icons NET and Game with Icons for Calculator and Notepad.
This would be very helpfull.
neuwacom is offline   Reply With Quote
Old 01-11-2006, 01:25 PM   #110
SMKFree
Quote: Originally Posted by neuwacom
Hi liquid_smoke
ill see if i can find the psd file for that menu, i may have to recreate it.
mp3car live search
Old 01-12-2006, 06:08 AM   #111
djmickyg's Avatar
djmickyg is on a distinguished road
not sure if its come already, had a look thru the tread already
im having a play with this skin and using the mouse wheel imput config in ur zip..
is anyone using this having truble pressing any buttons in RR when the mouseinput program is opened??
no buttons at all work when its open.. ??
djmickyg is offline   Reply With Quote
Old 01-12-2006, 07:09 AM   #112
djmickyg's Avatar
been tring to get freedrive working
i think i did alright sofar
i made a nme gps.skin
replace the one in the skin folder with this one..
and then edit the ExecTBL file in the skin folder and put some "/"'s infrom of the igidance lines
eg
/path to GPS............................................... .........{ path to your gps application }{ window title}
/"GPS","LOAD;EXTERNAL_GPS.skin;RUN;LSTOOLS\SB2.9\SK INbedder.exe;SKINbedder"
/path to GPS, use "GPSFS2" as the code for the "FULL" button on EXTERNAL_GPS.skin if you want fullscreen with menu on bottom
/"GPSFS2","LOAD;EXTERNAL_GPS_FS2.skin;RUN;LSTOOLS\S B2.9\SKINbedder.exe;SKINbedder"
/....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
/"GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;LSTOOLS\SB2 .9\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SCRIPTS\ EXIT_FS.exe"
Old 01-12-2006, 12:51 PM   #113
SMKFree
Do you have the LSTOOLS folder in the proper location?
when you click any of the MWI buttons inside the skin, RR tries to load this file
LSTOOLS\SCRIPTS\MMB.exe
if it can not find the file, RR will stop responding to mouse clicks (known bug in RR)
To test this out, located the file above and run it (while you have MWI open).
If it works then there is something wrong with your paths.
mp3car live search
Old 01-12-2006, 05:13 PM   #114
Mr.Fabio's Avatar
Mr.Fabio is on a distinguished road
Wink
Yes, it drive me crazy for a while
By the way, Liquid i just wanna say : you did it again ! Your skin is the best! You Rock
Thanx a lot for your job
Mr.Fabio
_______________________
Travla C134
Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Hermes
RoadRunner - PC Navigator 7.1 - FreeFone
Mr.Fabio is offline   Reply With Quote
Old 01-12-2006, 05:55 PM   #115
Mr.Fabio's Avatar
Take a look here..........
Just discovered....
When i launch iGuidance with SKINbedder after an MSOffice application, the following message appears......
Any ideas???
Mr.Fabio
Travla C134
Old 01-12-2006, 06:32 PM   #116
SMKFree
hum, thats very odd. It looks like its trying to find iGuidance inside your OFFICE install dir. Half the error message is in another language too. I would double, tripple check all your paths. Does this happen if you launch skinbedder standlone (not using RR)
mp3car live search
Old 01-12-2006, 06:42 PM   #117
WinoOutWest's Avatar
WinoOutWest is on a distinguished road
speaking of odd problems, here's one for ya:
If I cold boot and run RR everything comes up fine. If I launch iGuidance it does embed correctly. So I exit iGuidance and come back in and it is fine. Coupled with this I loose my touchscreen functionality. (mouse still works). If I hibernate and come back in everything is fine. Touchscreen works fine and if I launch iguidance it comes up perfect. This is consistently epeatable on cold boots.
Any ideas?
WinoOutWest is offline   Reply With Quote
Old 01-12-2006, 09:20 PM   #118
SMKFree
Any ideas?
Can you post the contents of both of your ExecTBL.ini files. The one inside the skin folder and also the one inside the root of RR.
mp3car live search
Old 01-13-2006, 12:36 AM   #119
SMKFree
update 1 uploaded, check first post for link
mp3car live search
Old 01-13-2006, 02:28 AM   #120
Mr.Fabio's Avatar
Translation of the other half error message : Unable to find the path specified.
IN RR : If i don't launch office before, all is right, 100% OK
OUT RR : If i launch office before, all is right, no error messages...
May be a problem induced by RR?
Mr.Fabio
Travla C134
