Quote: Originally Posted by liquid_smoke
Can you post the contents of both of your ExecTBL.ini files. The one inside the skin folder and also the one inside the root of RR.
btw: I meant to say it iGuidance DOESN'T embed properly from a cold boot. It comes up with the file menu. So I shut down iGuidance, back to the main RR menu and back into iGuidance and it embeds properly. And then it will lose the touchscreen input until I return from a hibernation.
THis is in the root:
"QUIT","SendMsg;RRCDRip;showplugin||bye"
"BYE","QUIT"
/, Set Bellow the Path to the CDRip plugin (if used)
"CDRIP","PLUGIN;RRCDRip;D:\VBStuff\Road Runner\CDRip\CDRip.exe"
/, You can add commands to execute before suspend
/, and after resume, using the codes bellow:
"ONSUSPEND",""
"ONRESUME",""
"ONFILECLICK",""
"ONDIRCLICK",""
"ONPLCLICK",""
"ONDLCLICK",""
"ONPBCLICK",""
and this is in the skin folder:
/ turn off word wrap to best edit this file
/ a forward slash at the begining of any line tells RR to ignore that line of text.
/path to GPS............................................... .........{ path to your gps application }{ window title}
"GPS","LOAD;EXTERNAL_GPS.skin;RUN;LSTOOLS\SB2.9\SK INbedder.exe;SKINbedder"
/path to GPS, use "GPSFS2" as the code for the "FULL" button on EXTERNAL_GPS.skin if you want fullscreen with menu on bottom
"GPSFS2","LOAD;EXTERNAL_GPS_FS2.skin;RUN;LSTOOLS\S B2.9\SKINbedder.exe;SKINbedder"
/....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
"GPSFS","LOAD;EXTERNAL_GPS_FS.skin;RUN;LSTOOLS\SB2 .9\SKINbedder.exe;SKINbedder||RUN;LSTOOLS\SCRIPTS\ EXIT_FS.exe"
/path to PicViewer.NET download app at
http://www.phoco.net and install to default dir which should be same as below
"PHOTO","RUN;C:\Program Files\PictureViewer.NET\PicViewer.NET.exe;PicViewe r.NET"
/path to Mobile Emulator 2.0c download app at
http://thequiltcupboard.net/mobileimpact/download.htm also see this thread
http://www.mp3car.com/vbulletin/software-software-development/58928-true-touch-screen-friendly-all-nintendo-sega-emulator.html
"GAMES","LOAD;N64.skin;RUN;C:\Program Files\Mobile Impact\Me.exe;Game Emulator"
/path to RRConfig.exe
"CONFIG","RUN;RRConfig.exe;RRConfig"
/path to mousewheelinput utility download app from
"MOUSEWHEELINPUT","RUN;LSTOOLS\SCRIPTS\MMB.exe "
/set weather you have xm radio or sirrus radio, default is XM, if you have sirius remove the forward slash and put one infront of XM
"SAT","XM"
/"SAT","SIRIUS"
/This is for the circle button in the audio player screen, right of the battery meter, by default it pauses RR and mutes the wave line.
"CUSTOM1","PLAY||RUN;LSTOOLS\LINE\TOGGLEWAVE\LineT oggle.exe"
/weather sat images.... DONOT edit any of the below text
"WEATHERSAT","RUN;LSTOOLS\WEATHERSCRIPTS\WEATHER.e xe||LOAD;WEATHER_IMG.skin||LOADIMG;24;76;145;309;w eatherbar_off.gif;OUT||LOADIMG;24;76;145;309;weath erbar_on.gif;ON||LOADIMG;24;76;145;309;weatherbar_ off.gif;OFF||LOADIMG;24;76;145;309;weatherbar_on.g if;DOWN"
