Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 01-30-2006, 10:09 PM   #1
DiNASTY's Avatar
DiNASTY is on a distinguished road
Arrow FlashDeck
Skin Progress: Revising
How to install
1) Get the BETA v1.2 Here (extract anywhere you please)
2) extract "reboot.exe" to your RoadRunner directory
3) extract the "weather" folder to your RoadRunner directory (for weather support)
4) add the following to your KeyTbl.ini: 4081,"EXIT" (for iG support)
5) Run FlashDeck and click on "FlashDeck Config" under "MENU->INFO->FlashDeck Config"
NOTE: At the moment, this skin only works with flash player version 8 or earlier.
Customized logo Tutorial Here
comments/suggestions and donations are more than welcome
File Type: txt ToDo.txt (541 Bytes, 565 views)
File Type: txt Donations.txt (128 Bytes, 263 views)
DiNASTY is offline   Reply With Quote
Advertisement Sponsored links
Old 01-31-2006, 12:17 AM   #2
marazi's Avatar
marazi is on a distinguished road
awsome....
looks great
marazi is offline   Reply With Quote
Old 01-31-2006, 12:33 AM   #3
jthiani's Avatar
Location: Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
jthiani is on a distinguished road
file does not work on any of my video players....real player, windows media, or winamp...what gives.....???
jthiani is offline   Reply With Quote
Old 01-31-2006, 12:41 AM   #4
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
What's the video codec you used?
0l33l is offline   Reply With Quote
Old 01-31-2006, 01:39 AM   #5
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
u guys may need this: http://www.techsmith.com/download/codecs.asp
@Dinasty: I'm not sure of your intentions for the bottom of the screen, but I'd like to see the current song + other info on there (suggestion).. also what happened to the cool playlist editing you showed me before ? did you separate the lists ?
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 01-31-2006, 01:44 AM   #6
My Village Called
0l33l's Avatar
TechSmith Screen Capture Codec (TSCC) did the trick. Thanks guino.
DiNASTY: Clean up your desktop
Old 01-31-2006, 01:46 AM   #7
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
still doesn't work for me.
edit: nevermind, works with quicktime.
edit2: ok, but no audio, with quicktime.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 01-31-2006, 05:14 AM   #8
Phythorian's Avatar
Phythorian is on a distinguished road
Nice and simple, like it!
But will this dragging work good with a touchscreen?
Finished!
pc 99% - install 100% - audio 100%
Phythorian is offline   Reply With Quote
Old 01-31-2006, 10:24 AM   #9
DiNASTY's Avatar
Sorry bout the codec. I will try another format for the next vid.
@Guino: Yeah, the playlist is separate now but will probably have those same effects on it. As for the bottom, there will be the Visu, Clearlist, Search, Eq, Open (playlist), Save (playlist) ect... I think I can fit the current song either on the very bottom or on the top bar. Still many buttons to add though and i don't want it to get cluttered.
@0l33l: and that's only about 1/4 of my desktop.. guess i should run that cleanup wizard huh.
TBH, I'm not sure that it will work out on a TS. But it should considering that you only have to drag the song slot a very short distance to add it. also, if your in a directory you can also just click to add it. (not shown)
Old 01-31-2006, 10:45 AM   #10
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
cant someone just screenshot it for us using paralyzed computers (i.e via 800s lol)
Old 01-31-2006, 02:39 PM   #11
m-ruiter's Avatar
m-ruiter is on a distinguished road
1 Word: WHOW
Looks like this is gona be better then iRunner, but when does iRunner get finished ?
m-ruiter is offline   Reply With Quote
Old 01-31-2006, 02:45 PM   #12
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
Looks good and I'd like to see the rest really how ever I'm not sure how much use drop and drag will be in a car enviroment.... very clever though.
IMHO
Terran
ccsnet is offline   Reply With Quote
Old 01-31-2006, 03:00 PM   #13
replicant is on a distinguished road
impressive work dinasty and guino.
replicant
Audi A4 (flickr pics)
replicant is offline   Reply With Quote
Old 01-31-2006, 08:53 PM   #14
LiquidKernel's Avatar
LiquidKernel is on a distinguished road
Looks great! Definitely looks like it has major potential.
For those who need the codec... http://www.techsmith.com/download/codecs.asp
95 Volvo 850 T5 • Konis • ECU @ 17psi • Orange Ambient-Light + LED Dash Lights • DigiMotive Dimmer • Custom LED Brake Lights • TSX HID Projector Retrofit • Hella Raintronic
Carpc: [▓▓▓▓▓▓▓] 99% Cleanup.
LiquidKernel is offline   Reply With Quote
Old 02-01-2006, 01:13 PM   #15
pwcmed's Avatar
pwcmed is on a distinguished road
I am behind a proxy and have no other internet connection, can someone please post a screen shot.
pwcmed is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
