Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 05-04-2006, 03:12 PM   #1
Saturated_Fat's Avatar
Saturated_Fat is on a distinguished road
Question Jump Search Results
Ok guys this kinda sorta involves skins...... but is there a way to display the results of your playlist search? For example lets say I load all of my mp3s and I wanted to find a particular song, if It was winamp I'd hit j then type in a portion of the title and a list of songs would come up that matched my entry. Is there a way to have those same results displayed in road runner?
Right now I know that you can use the searchlist command and it'll search your playlist and automatically jump to the next song, but can I list the results using this command somehow? Basically I wanna have another box/list thingy display the results.
Thanks in advance~
Shotgun! - An Advanced CarPC Software Solution!
Saturated_Fat is offline   Reply With Quote
Advertisement Sponsored links
Old 05-04-2006, 03:18 PM   #2
Flappy's Avatar
Flappy is on a distinguished road
Very interesting. I also have all my MP3's in 1 list, i think this is a nice feature to add.
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Flappy is offline   Reply With Quote
Old 05-04-2006, 04:33 PM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
the SEARCHFILES skin command does that.
if you use the iDrive skin and go to the audio browser there is a SEARCH button, this will then list all the songs with an occurence of your search string.
other skins may have the same.
Enforcer is offline   Reply With Quote
Old 05-04-2006, 04:35 PM   #4
nameeri's Avatar
nameeri is on a distinguished road
Mauri's skin has this as well, works great.
Civiputer: Dont have one anymore, but here is what is used to be!
nameeri is offline   Reply With Quote
Old 06-07-2006, 03:00 AM   #5
DJiK's Avatar
DJiK will become famous soon enough
Re-requesting of the Same...
I'm having the same request/quetion as the OP.
I've downloaded and tested both iDrive and Mauri's Skins. Although both of
them have a search feature indeed, neither of them works as the 'J'
(Jump-to-File) plugin that's been incorporated in Winamp since version 5.02.
The primary difference between the SEARCHFILES command and the JTFE plugin
is delivery time. The former does a hard drive search -- "Presents the OSK
and shows resulting file matches on directory list."
(from Skin Commands.txt),
while the latter goes into the playlist and looks for any string matches there.
The matches, by the way, could be of any ID3vX tag field (including
Artist, Title, Track Number, Genre, Path, etc.)
In other instances, the SEARCHFILES command wouldn't find the files I was looking for at all.
Winamp that was open alongside RR, on the other hand, would quickly select the correct files using the 'J' search.
Before suggesting that I'm misinterpreting the SEARCHFILES command (which is possible),
please go to Winamp, open a playlist or load a directory with more than three media files in it,
and press 'J' on the keyboard to see how it works.
The JTFE (Jump-to-File Extra) plug-in also allows for enqueueing files.
To choose a song which a passenger had requested, what I'd do before using
Road Runner (when using just Winamp in the CarPC) was:
* Press 'J' on the keyboard
* Type the song name (or a part of it)
* Press 'Enter' -or-
* Press 'Alt + Q' on the keyboard (to enqueue)
* Hit Escape
I'm sure you can see how that's less risky than trying to scroll through
thousands of titles while driving down the freeway.
It's also a whole lot more effective than praying for the right song to come on.
Since RR is Winamp-Based, and JTFE is already embedded in Winamp (v. 5.02+),
I'm hoping that adding something like that to RR wouldn't be extremely difficult.
After all, I chose RR over everything else because it's taking advantage of Winamp's strongest features.
Links:
Official JTFE Development Thread
JTFE Development Log
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 06-07-2006, 09:43 AM   #6
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
* Hit Escape
Links:
strongly second this. Searchfiles only works if all your songs are in one directory. Kinda pointless
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 06-07-2006, 12:15 PM   #7
Winni is on a distinguished road
Guys, look for "SEARCHLIST"...
Winni is offline   Reply With Quote
Old 06-07-2006, 12:40 PM   #8
Terminal flasher
doesnt work the same way.
03 Acura RSX Coupe
Old 06-07-2006, 01:38 PM   #9
DJiK's Avatar
I'm not familiar with SEARCHLIST.
Do you know of a skin that uses this feature so I could see how it works?
Old 08-02-2006, 07:03 PM   #10
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
http://www.mp3car.com/vbulletin/rr-plugins/82528-djiks-jump-file-external-control-plugin-v0-99b-beta-post882443.html
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Any front ends with this type of search? Ascension Software & Software Development 4 06-24-2005 10:39 PM
Next Song search problems Ascension FrodoPlayer 8 06-18-2005 11:44 PM
How can I go from Search results directly to Auido_Player and play selected song? J187 RR Skins 0 06-16-2005 08:29 AM
Search Mode / Jump Mode frodobaggins FP FAQ 0 12-01-2004 05:48 PM
jump to winamp plugin? metlok Software & Software Development 2 05-12-2002 11:24 PM
