08-02-2006, 05:08 PM
#31
Para Laura
All I can say is... AMAZING!!!! I know this is a odd request but, can you make it skinable so this way people with other FE can use it as well? (it doesn't have to be right now  )
Thanatos.
08-02-2006, 05:11 PM
#32
Raw Wave
Lo m8,
Downloaded the filemanager, just get a blank screen on running the exe, what have I done wrong this time???
08-02-2006, 05:19 PM
#33
FreeDrive Creator
Quote: Originally Posted by DiNASTY
simply amazing... I'm guessing now that you somehow got flash to integrate with your VB scripts, you will do a full blown "Setup" or "Config" screens with paths and such? Or will you just have basic stuff in there?
never even thought about a full blown set up, most of the code is there, would just need to add a sdk module to the vb app and it would then talk to RR.. might be handy.. thats for later mind you.
It would be tricky to make it skinnable.. the best I could really do for a non flash person, would just make the background loadable, at least you could then change the colours of the background image. I will be releasing the swi file once I've sorted the code out, so for a flasher they can mess with it as much as they want.
you got flash installed ? cant think of anything else.....
CdR
08-02-2006, 05:35 PM
#34
Raw Wave
Anyone else having problems? All I get is a black screen, have tried flash 8 as usual.
08-02-2006, 05:42 PM
#35
FreeDrive Creator
you could try right clicking and selecting play.. see if that works, I forgot to disable that menu, so see if that helps. I have only tried it on two systems (main and laptop)..
anyone else having issues with the filemanager from the prev page ?
CdR
08-02-2006, 05:44 PM
#36
Raw Wave
won't even let me press play, will try on other machine in case its the lappy
08-02-2006, 06:29 PM
#37
Freakin sweet......
Dude u gotta get da good out ;-) ....
When my CarPC's hit the house - they auto connect to my HTPC drives. The HTPC drives record movies all day long, I have about 12 tuners recording all day to various HTPC's and drives. I love the interface here for moving (without leaving RR) from the House to the CarPC.
Yes I can do this a bunch of other background ways now but this is a friendly addition. Is multi-select i.e. Ctrl or Alt an option of some sort. Like tag to copy.
Hate to see you kill yourself on anything like that and stall a release just questioning.
its not released yet m8.. dont worry your not loosing it.. :-)
been busy working on a file manager module.. sort of finish it, just need to code in copy single files.. :-) .. also made it look a little bit better now
08-02-2006, 06:39 PM
#38
Do you have the eta on this skin's release date? This weekend, sometime next week, 2 weeks, etc?
Also would it be possible to make a night and day skin with the night skin being the current skin and the day skin being the inverted color one like someone posted earlier in this thread?
Thanks and I have to say once again, terrific job!
08-02-2006, 07:00 PM
#39
High Voltage
I think its best the way CdR is doing this, finishing all menus then beta releasing. I would rather him do that then release a new patch every week to add menus and stuff. Excellent work as always CdR
08-02-2006, 07:57 PM
#40
Para Laura
It would be tricky to make it skinnable.. the best I could really do for a non flash person, would just make the background loadable, at least you could then change the colours of the background image. I will be releasing the swi file once I've sorted the code out, so for a flasher they can mess with it as much as they want.CdR
I was thinking more in the lines of changing the button for something color, "source", "destination" color.
Also I just tryed on the TS and it the fonts look kind a small (just a tip  )
Thanatos.
08-02-2006, 10:43 PM
#41
SMKFree
CdR
same thing here, black screen. When i right click the window it just flashes away really quick.
One thing i did just notice though, is when i right click before it goes away i can read "about flash player 9". I'll have to double check but i know that i didnt manually update to flash 9 because of the issues i was hearing here. But its possible some other app auto updated it without my permission so ill check that and try again.
08-02-2006, 11:32 PM
#42
SMKFree
yeah, im definately running flash 9.
The only app i can think of that updated it was wmp11 and URGE which says that it will push updates to you without confirmation and since URGE heavily uses flash im guess they pushed flash 9 to me.
oldversion.com dosent have flash 8 yet so im not sure where i can grab an older version from.
08-02-2006, 11:47 PM
#43
Para Laura
08-03-2006, 12:14 AM
#44
SMKFree
your link works, but the link for the download on that page dosent.
ill see if i can find it somewhere.
08-03-2006, 12:18 AM
#45
ls, you can get flash 8 from here.
http://www.adobe.com/cfusion/knowled...fm?id=tn_14266
make sure you uninstall 9 first.
iGMon - Integration between iGuidance and Road Runner
CFX - Skin for Road Runner
| Thread Tools |
| Display Modes |
Linear Mode
