Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Closed Thread
Old 11-27-2006, 01:14 PM   #661
Zogg's Avatar
Zogg is on a distinguished road
Quote:
Originally posted by JohnWPB
If there is something else more in depth you are wanting to do, drop me an email (address is in the help file) and I will see what I can do about emailing the PSD that you need.
I did a quickie mod to the MAPPOINT_MENU_VIEW skin so I had a place to toggle MapPoint's Night Mode. If you could add one more button to that skin for that function it would be terrific, if not then maybe I could get the PSD from you for that skin so I could add it.
Thanks, Z
Carputer progress:
90% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓--]
Zotac N630I-D-E M/B w/ Nvidia 7100, Celeron 430 1.8 GHz, Xenarc 700IDT, M1-ATX, RR & DFX 4.0. Need to get EWF and HORM working one of these days.
Zogg is offline
Old 11-27-2006, 03:47 PM   #662
wfs1's Avatar
wfs1 is on a distinguished road
MS STREETS RR Setup, etc.
Okay for MS Streets as an external GPS (note make sure external GPS is checked in RR.ini file)..
Make a button call it "GPS" to call from various skins...
OPTION 1:
You can add the line below in the ExecTBL.ini file either in the RR folder or the skin folder depending if you want it in all skins or only one skin..
NOTE!! after the semi-colon of Streets.exe MAKE SURE to have a space before and after the hypen of - Microsoft Streets & Trips..
"GPS","LOAD;EXTERNAL_GPS.SKIN;STREETS;C:\Progr am Files\Microsoft Streets & Trips\Streets.exe; - Microsoft Streets & Trips"
OPTION 2:
add to the RR.ini file (Note see the screen capture "rr_config_streets.jpg" inside the zipped file posted earlier).
The later option works, if speech is enable it says "external gps"... the first option says "Streets"...
I preferred option #1
Now I tried to find the focus of the window when I saved templates and then trying to load them again but something with the hypen and space wouldn't load competely/correctly.
Like: "map1 - Microsoft Streets & Trips" or "map1.stt - Microsoft Streets & Trips" which in the later, wininpector show as the active window under the called template. Still No luck.
So what I did was to setup a running instance of MS streets, changing the map type, font size, zoom level, route options " like gas mileage, etc and then saved it under "C:\Program Files\Microsoft Streets & Trips\Templates" as "New North American Map.stt". Or wherever your MS Streets is installed to. This then became my default map for Streets.
This works on two different PCs..
Last thing to do is to auto-start GPS probably an AutoIt script of sometype..
Hope this helps someone in the future as I went through this throughly..
Note: My Street skin has changes in some of the command buttons instead of ALT+ in the sendkeys I used CONTROL+ as this embedded and had less flashing (popups) inside the skin. Not all buttons have a CONTROL+ function key available or Microsoft didn't show them in the help files..
wfs1 is offline
Old 11-27-2006, 04:59 PM   #663
kbreeden
Quote: Originally Posted by SangreDeThor View Post
what the toggle names does is, rotates the format of file name to
1). Track
2). Track-Asrtist
3). File name
It may not be in that order. or exactly that but that is what it does in my experience. does not work with *.m4a
Thanks, Sangre. I now see what's going on. For me, pressing the toggle button does nothing to the current playlist; however, when I load a new playlist the names in the new playlist are toggled. I thought it would impact the existing playlist, but that doesn't seem to be the case.
Also Sangre/John, since we're (I'm) on the subject of wish lists it would really be neat if there were some way to randomize the current playlist. I would love to be able to load my 20,000 song list, hit a button to sort it into random order, then turn off random play. That way, the list would be playing in random order, but I could see what songs are coming up next. B8bboi's CFX skin had that functionality and I really became addicted to it. Perhaps an extra click or a hold down of the toggle button could send a command to randomly sort the list.
kbreeden is offline
Old 11-27-2006, 05:02 PM   #664
kbreeden
Quote: Originally Posted by ajamils View Post
Mine never worked . It neither pauses the music nor switches screen.
I had the same problem as you. I did a clean install of RR and BD, downloaded the current version of VBRuntime and messed around with the volume settings of Iguidance and RR and all of a sudden it's working perfectly. I wish I could tell you what did it, but I don't know.
kbreeden is offline
Old 11-27-2006, 06:16 PM   #665
SangreDeThor is an unknown quantity at this point
some suggestions for people having issues with the switch.
make sure RR doesnt do all volume.. just master volume. and as a test set main to 100 and wave to 50. and see how that works.
CarPuter: 900Mhz P3 with 256 MB Mem, 160 Gig HD (Thanks kbreeden), Iguidance 3.0 GPS, Logitech PS2 keyboard, Bluetooth, WIFI.
Powered By Road Runner & DigitalFX Skin and Playlist Conveter
SangreDeThor is offline
Old 11-27-2006, 06:51 PM   #666
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
New Visulization
Ok, I have been working on adding a nicer visualization to the skin. I found a nice spectrum analyzer, and want to know what you guys think. It is semi transparent, and you can see the album art underneath it.
It's a few steps to configure, but would be covered in detail in the help file. SangreDeThor was nice enough to beta test it for me, and he got it working. I also want to thank Liquid Smoke for helping me out with this! We were IM'ing back and forth for a few hours working on issues with his skin and mine. Without his help this would not have come to be.
Let me know if this is something that I should include in the skin or not.
Here is a screen cap:
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline
Old 11-27-2006, 06:58 PM   #667
SteveC is on a distinguished road
YES YES and just in case YES
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline
Old 11-27-2006, 07:26 PM   #668
wfs1's Avatar
@John
John, I didn't offend or upset you by posting some Streets files?
I was merely adding some input and thought you might want them for future..
wfs1 is offline
Old 11-27-2006, 07:59 PM   #669
kbreeden
John,
I think it would be great as an option. I can see that there will be some times I'll want the viz with the album art and sometimes just the album art.
kbreeden is offline
Old 11-27-2006, 08:10 PM   #670
venealis's Avatar
venealis is on a distinguished road
PLEASE.
venealis is offline
Old 11-27-2006, 09:07 PM   #671
oh yea. especially after i went through all that trouble testing it out.
*EDIT* Venealis: Great avatar... super */EDIT*
Old 11-27-2006, 09:48 PM   #672
JohnWPB's Avatar
Not at all! I am grateful for the help, and will even include it in the help file, so that it may help someone else in the future.
JohnWPB is offline
Old 11-27-2006, 11:38 PM   #673
ajamils is an unknown quantity at this point
Hey John,
When is then next update with Spectrum coming out ? Can't wait to try it out
04 Accord Coupe Carputer
ajamils is offline
Old 11-28-2006, 01:34 AM   #674
JohnWPB's Avatar
Arrow New version is up and ready for download
Ok the update has been posted, check the link in the first post.
IMPORTANT! The Spectrum analyzer on the audio screen takes a bit to setup, and requires version 5.13 of Winamp. (Link to the file and FULL instructions are in the help file) The Latest version of Winamp will NOT work correctly with Road Runner, so make sure to get Version 5.13. This goes against everything I have heard about using version 2.95 with Road Runner, but it is working well here, and was working for SangreDeThor as well when he tested it. This is also the version that LiquidSmoke requires for his skin. Speaking of LiquidSmoke, MANY thanks to him for helping me through some of the hurdles to get this visualization working properly!
Again, READ THE HELP FILE on how to set this up. It is the top item under "How do I...."
If after reading the help file, there are still issues, post them here so I can either correct or alter the instructions to make it clearer.
JohnWPB is offline
Old 11-28-2006, 02:29 AM   #675
che420's Avatar
che420 is on a distinguished road
Killing me!!! i've been working on the red version of this and every time i think i get close you come up with killer changes......
...you know, that guy...
che420 is offline
Closed Thread
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 01:51 AM
Can you tell I was bored today: Take a look. Sweet05 RR Skins 47 08-17-2006 03:25 AM
new skin 'Blue' CdRsKuLL RR Skins 19 09-25-2005 05:48 PM
Cool Blue skin Rireal ME Archive 11 01-31-2004 06:53 PM
Nissan Blue skin final SpeersSV ME Archive 6 01-06-2004 06:00 PM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
