The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 09-19-2006, 02:30 PM   #1
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
"Infobar"...
Hello!
I guess the thread title is a little off but it was the best word that came to my mind...
I'm trying to create a "infobar" display in my skin. Its supposed to be a text field which shows different text based on what I press on the screen and what happens on the computer.
Example: Default text shows (GPS route info) -> I press "next song" -> text changes to music title for five seconds then goes back to default text (GPS route info).
Is this possible with RoadRunner? I know I can use variables to make the text change but can this be based on a timer?
Btw: Is this the correct forum for asking this or should it be under Road Runner directly?
Cheers
Borte
Failure is not an option...
Borte is offline   Reply With Quote
Sponsored Links
Old 09-19-2006, 03:07 PM   #2
MGD
MGD's CarPC Specs
MGD's Avatar
Vehicle: 2005 Chrysler 300
My Photos: (0)
You can use the SwitchLabel code for that. You need to put this in the button code you press, like this
B1,9,82,96,63,"NextTrack||SETLABEL;!MYLABEL1||IDL, 5"
In the EXECTBL.ini you need those two lines
"!MYLABEL1","TRACKTITLE"
"IDLE","EXIT"
MGD is offline   Reply With Quote
Old 09-19-2006, 03:20 PM   #3
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
Could you elaborate a bit on this since the skin commands.txt doesn't say so much about it?
Would it also be possible to make it show the music track for 5 seconds if the player changes song by it self?
Old 09-19-2006, 04:22 PM   #4
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
This is not very simple.. any solution you come up with will have different quirks.. unless you make an extension plugin for this, it will not work perfectly everytime.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 09-19-2006, 04:24 PM   #5
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
But it would be possible using a plugin?
Old 09-20-2006, 05:06 AM   #6
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
Can someone point me in the correct direction for creating a plugin for Road Runner?
Old 09-20-2006, 11:42 AM   #7
Raw Wave
RoyN's Avatar
Vehicle: 1999 Range Rover 4.6HSE
My Photos: (0)
10 If you already know VB, then download the "Base Plugin" and start from that... IIRC that includes methods of sending/recieving info from RR.
20 If you dont know VB, well first learn VB, THEN GOTO 10
Roy
2005 Range Rover 4.4
RoyN is offline   Reply With Quote
Old 09-21-2006, 03:09 PM   #8
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
Ok. I'll try to work it out from there...
Btw: That wasn't "visual" basic... just good old mr. basic
Man, I miss playing snake back in the "dos" days...
Old 09-21-2006, 03:48 PM   #9
guino's CarPC Specs
guino's Avatar
My Photos: (5)
Take a look at the "extension plugin" sources and the FAQ about how to use it.. the code is fairly well commented, you just have to add a few things to it to create a new label code like "TRACK5SEC", the hardest part will be to monitor the current song.. I'm actually going to release a new interface for this soon, so you may want to hold off a little or PM me so I can send you the beta..
Old 09-22-2006, 06:55 AM   #10
Borte's Avatar
Vehicle: Audi S4
My Photos: (0)
Thanks Guino!
I'll check this out over the weekend...
Now I'm off to play the Norwegian Championships in Paintball...
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
