Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 12-25-2006, 01:36 AM   #1
Ruffy's Avatar
Popup Skin Menus?
Is there a way to create a pop up skin menu wherever you want it.
IE, the exit menu pops up and is often small. I can make it bigger by making the image bigger. But what if I wanted to move it to the side? Or to the bottom of the screen.
Or a audio slider pop up wherever I want it on top of another skin. This is whats missing for that real polished OEM style look. Pioneer z1 does it just fine.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 12-25-2006, 04:00 AM   #2
Griff1's Avatar
The best advice i can give is,Have a dig around inside your current skin for the Exit menu and see how its been done.
Create a backup of the popup image and change it.
It helps to download a few skins and pull em apart so to speak,see how the button codes work and such.
Here's a link to the skin editor = http://innovatedaudio.com/griff1/RRSkinEditor.zip
Good luck.
Griff1 is offline   Reply With Quote
Old 12-25-2006, 10:53 AM   #3
MGD
MGD's Avatar
You can have the menu popup wherever you want. Here are 2 screens with the exit menu popup at the center and the 2nd one with the /POSX and /POSY commands in the skin file.
In the exit_Menu.skin put this code
/POSX=25
/POSY=25
MGD is offline   Reply With Quote
Old 12-25-2006, 10:06 PM   #4
Ruffy's Avatar
/POSX=25
/POSY=25
thanks, but still dont know how to force a new type of popup menu. adding POS commands to the skin i want to move around just shifts the entire screens perspective. Screwing things up.
Old 12-25-2006, 10:21 PM   #5
Ruffy's Avatar
well i finally realized i had skincommands.txt
checked it out
command i needed is
B,570,103,62,81,"MENU;Whatever.skin;Whatever",
works well. Will make everything much easier now
I was using the Launch command before and that just wont do
Old 12-28-2006, 07:04 AM   #6
ThunderStick's Avatar
/POSX=25
/POSY=25
Place these values at the top of the *.skin file
I used a pop up menu in my drop skin.
HELP MY KIDS SCHOOL CLICK HERE
New Age- Garmin Style Skin for RR
"Your two cents are worthless pennies if you consider the exchange rate for my 2 cents"
ThunderStick is offline   Reply With Quote
Old 12-28-2006, 07:06 AM   #7
I was able to make it look like a drop down menu with this method.
New skin Floatingpi CF Skins 20 12-22-2007 12:31 PM
Mauri RR skin mauri RR Skins 122 12-06-2007 09:50 AM
IG3 working with FREEDOM SKIN - Will not Embedd Right... dtragic GPS 2 11-21-2006 03:22 PM
Popup Skin - Just Messing Around 65coupei6 RR Skins 3 09-17-2006 06:51 PM
FrankenSkin (first skin) chrishick RR Skins 3 06-24-2005 11:53 AM
