Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 04-12-2008, 09:58 PM   #2491
greatwhite's Avatar
"Waiting for gps signal" means it doesn't see the gps mouse (yeah I know, duh).
What MGD is getting at is rr is "stealing" the port from IG4 when both programs are running.
Downlod the program "xport", it's a virtual port splitter.
Tell it which port your gps is on, then slpit that into two seperate ports (it'll be obvious how once you run the program).
Then tell RR which of the two "virtual" ports to use, and tell ig4 to use the other.
Viola, no more conflict!
I can't think of any other simpler way to describe the process............
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 04-13-2008, 03:36 AM   #2492
pdegameplayer's Avatar
ok i did all that and the gps is working fine now but still having the problem of it not retaining any information that i input into the program it works fine when not embedded!
LSX Void 3.3 Gauges Mod
pdegameplayer is offline   Reply With Quote
Old 04-13-2008, 06:13 AM   #2493
greatwhite's Avatar
Are you using the flyout menu or the menu in IG4 when inputting data in the embedded mode?
It may be a corrupted script if you can't use the flyout menu correctly.
Try using the menu button (the big blue button) in the embedded IG program and see if that works.
Also, if you have ig4 installed anywhere but the default location, this may cause problems.........
One last point:
Make sure you have the path set correctly to ig4 or you can have all kinds of funky problems with embedding.
Good luck.
Leonardo Da Vinci
Old 04-13-2008, 06:26 AM   #2494
greatwhite's Avatar
LS:
(hopefully) Small request;
I use cdrskulls joypad 3.1 program for RR. Available here. Basically, it allows you to use a usb joypad to control RR. PLug and play simple, works right out of the box. This is useful in that I have hacked up a joypad and made hard buttons on my dash for RR functions (ie: gps, audio, dvd, fwd, play pause, vol+/-, etc)
But I'm having an issue when calling up the gps screen with joypad. When joypad sends the command to RR to intiate the gps, it loads up just fine in void except there's no script running for the flyout screen. Any idea why this is so or how to fix it? Perhaps joypad 3.1 is sending the command to RR but void goes through the skin commands and brings up the script along with gps?
I'd appreciate it if you'd have a quick look see.
Cheers
Leonardo Da Vinci
Old 04-13-2008, 07:23 AM   #2495
jacksmilzo's Avatar
hi, i write from italy
i have a problem with your skin:
i want change resolution to 800x600, i try to change the res in general.ini, but the skin don't change
i had a mistake?
ciao!!!
jacksmilzo is offline   Reply With Quote
Old 04-13-2008, 09:03 AM   #2496
BReMFoX's Avatar
I installed version 3.3 and 3.301
How do i enable freefone again?
| Suzuki Esteem 1.8 GTX | Intel Pentium 4 Carputer | Entertainment On A Higher Level |
BReMFoX is offline   Reply With Quote
Old 04-13-2008, 09:17 AM   #2497
One last point:
Good luck.
First off i have no idea what the flyout menu is second all the paths are set right and it is installed in the default location and the menu button works fine!
the only problem im having is that it wont save!!! both the set home and favs reset immediately and clear out all data.
Old 04-13-2008, 09:32 AM   #2498
also how do make either the lsx void skin or rr its self stop messing with my dimming control?
*FIXED* xport was messing up and sending weird speeds to rr like one time it sent 1025mph to it go figure right?
Old 04-13-2008, 09:45 AM   #2499
greatwhite's Avatar
look in RRconfig.
Sounds more like a ig4 issue if it's not saving your favorites.
The flyout menu is the little arrow that pops up on the gps screen on the lh side and gives you quick access to IG4's features. But you're obviously not using it, so I doubt ls's scripts are the problem.
Plus, you're starting to sound confrontational for someone with a "high tech understanding" and asking pretty basic questions, so I think i'm done replying to your posts.
Good luck. (I mean that sincerly. I just don't need the drama)
Leonardo Da Vinci
Old 04-13-2008, 10:47 AM   #2500
Kimota's Avatar
Hello
There should be a button on the main screen "PHONE" that will bring up freefone. If you need to assign a button for freefone, hold down the button you wish to use for a few seconds, when the "choose a command from the list" appears select "PHOCO".
You will also need to specify the Com Port for "serial line via bluethooth /cable" in the settings.ini located in "C:\Program Files\Road Runner\skins\LSX VOID 3.0" if RR is installed in its' default location.
pssstt
Kimota is offline   Reply With Quote
Old 04-13-2008, 11:13 AM   #2501
look in RRconfig.
i am truly sorry if i sound confrontational i'm not meaning to its just kind of frustrating not knowing what i am doing on this program. don't get me wrong i love all the features and the awesome lsx void skin its just the money i forked out for a program that don't work is kinda upsetting.....
ill try reinstalling and see if that will work... if not i guess i will have to dl a pirate copy of ig3 or something i mean i do own a license for a newer copy so it cant be that bad right? i mean i did buy it!
Old 04-13-2008, 11:23 AM   #2502
BReMFoX's Avatar
Quote: Originally Posted by Kimota View Post
Hello
Well, the weird thing is, when i press PHONE, phonecontrol appears instead of the default freefone.
Freefone is the default under the PHONE button right?
I also can't turn ilists on.
There is no option in "General options" to turn ilists on...
Before i installed the 3.3 version of the skin including the update i completely uninstalled the old version.
So that couldn't be the problem.
What's going wrong here?
Old 04-13-2008, 11:33 AM   #2503
greatwhite's Avatar
You've got something set wrong, somewhere.
I'm using ig4 with rr and void with no issues (yes, I bought it).
It can be something as simple as a mis-typed capital or character. You just have to approach it logically and triple check everything.
I don't know why you're frustrated with IG4, it sounds as if it works just fine stand alone (which is what you paid for).
Using a pirated previous version isn't going to help you if you don't have things set up correctly.
You're just having some issues with embedding somewhere. RR isn't the easiest program to learn, but it's not the hardest. Just keep learning and looking................you'll find what's wrong.
Leonardo Da Vinci
Old 04-13-2008, 11:51 AM   #2504
ok thanks ill recheck everything
Old 04-13-2008, 12:19 PM   #2505
Any chance you could do a sub thread somewhere on getting GE runnning in void?
I think I remember you saying you cached the maps a s well. A how to would be great for that also.
It' not like I couldn't figure it out, but I just haven't had the time to hack around with it myself. A littel how to would be great to get a head start.............
Cheers
i posted a pseudo guide towards the end of the GE plugin thread on how to cache maps and stuff. as far as embedding inside of void, all you have to do is hold down one of your buttons and change it to the GE button. LS has graciously set everything up to make it work perfectly from the get go, as long as you have your maps cached, port set, etc.
hari-bhari is offline   Reply With Quote
HD radio skin for LSX void 3 download hugenius79 RR Skins 35 10-03-2008 12:29 AM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 12:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 09:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 01:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 07:00 AM
