Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 05-19-2008, 10:44 PM   #2656
SMKFree
liquid_smoke's Avatar
Quote: Originally Posted by greatwhite View Post
Hold on.................
The drop down menu is no longer there. I get "notes" when i click on the upper LH corner...........
Problem solved I guess. The menu must be removed in the latest 3.3? I just Dl'd a fresh copy of void the other day, I was running the "old" 3.2 in the car up to today.........
the menu was not removed or changed in any of the versions. Sounds like you may have assigned the command for that button by mistake. If you click and hold on the button, a new screen with a bunch of buttons should show up, choose "MENU" from the available options. Other buttons on this screen also behave the same way.
Quote: Originally Posted by hari-bhari View Post
is anyone having problems with the new installer? everytime i try to unpack it on my carpc, it stops at one of several files. usually its vista.pdd but sometimes its one of the background.jpgs or the diskcheck.exe (or is it harddisk.exe) file. i have tried redownloading several times, but with the same results. i tried unpacking the same file on my other pc and it works fine. so i reinstalled xp pro from scratch, ran a chkdisk and tried again with the same result. weird thing is that if i unpack the older void 3.0 it works with no problems. what could be going on, any ideas??
kind of sounds like something odd with that specific pc, esp if you are able to install the same file on another pc. If you already have had 3.0 installed on the troubled machine, i would just copy the 3.2 install from a good machine over to the problem one.
Quote: Originally Posted by Quattro View Post
After some testing, I believe the problem I'm having is skin related. I've been using the Shock skin for a couple of days and did not see anything similar to what I described above. then toaday I used void and I had a song by mario where the tile was correct but the artist and album art was of alica keys. I switched to shock and everything was correct and then I switched back to void and everything was correct then.
LS, any ideas of what might be happening?
cant say ive seen this before. What version (version date) of RR are you running?
Quote: Originally Posted by Bxsteez View Post
After trying for hours to get freefone to work i gave up and am trying RRMobile but the problem i run into is that the software starts up once RRMobile starts up. Can someone point me in the direction of the area with the start up procedures? Or give me some sort of advice on getting phone control through either one of these phone control programs
i believe freefone may have been based on RRMobile, not 100% sure though. RRMobile will load RR when it starts also. If you click OPT>Phone Settings you can change which phone app loads. RRMobile is not supported by default though, so you would have to do some mods to get it to work. The reason RRMobile is not supported is because the author of the app has abandoned future development.
Quote: Originally Posted by Nickman View Post
LS -
I don't know if you have seen this, MeHere, program. http://mehere.glenmurphy.com/ . This adds moving GPS traking to GoogleMaps. Its free. I think the ability to track movment on a searchable map is paramount. Since googleearth has given many much grief, I thought this may be a useful addition.
nm
ive played with it a few times in the past, but its not really suitable for incar use. Reatime gps tracking on a google map is top priority though.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 05-20-2008, 09:11 AM   #2657
b3tts32's Avatar
Smoke
I have 2 requests.. I'm not sure if they're feasible or not but I thought I would at least ask.
1. Is there any way from the xplorer window to transfer from another drive besides the c drive? I have no optical drive so I usually just plug my jump drive in and transfer my new music. I would like to do this from the skin but I only have the option to transfer anything from the c drive.
2. This is probably a stretch.. but I use the color picker to use a color for my day skin and a theme for my night skin. I usually have to go through about 5 or 6 buttons to do this. Is there any way I could do a macro or something to simulate going through all of this with one button? It's not a big deal but I figured I would at least ask.
Thanks in advance
b3tts32 is offline   Reply With Quote
Old 05-20-2008, 09:38 AM   #2658
turns out i couldnt install ANY program. did a hard disk check, came out fine. turned out it was bad ram. go figure!
hari-bhari is offline   Reply With Quote
Old 05-20-2008, 10:24 AM   #2659
Quote: Originally Posted by MunkyWrench View Post
for anyone whos wondering about this,
heres how i have gotten around the problem of ilists resuming blank.
in exectbl.ini
"ONSUSPEND","LOAD; black.skin"
"ONRESUME","ESC"
its not a new idea that going to a skin without an ilist avoids the ilist problem,
but lsx has the blackout skin (very simple skin) just sitting there so its a nice work around.
on my system it appears to 'just work' with no short glimpse of some random screen at resume.
i tried it out and it didnt work for me, then i realized there is a space between the load command and the skin name. it should read:
"ONSUSPEND","LOAD;blank.skin"
"ONRESUME","ESC"
that code should work for everyone now. by the way, im using blank.skin, not black.skin. i think blank is the one for blackout, whereas black just makes RR disappear or become transparent or something. anyhow, this patch works and now i can go into standby on any screen without worrying about my ilists messing up. woohhoo!
Old 05-20-2008, 01:12 PM   #2660
Confusion Master
Enforcer's Avatar
Upd8 can do this automatically
[/shameless plug]
Enforcer is offline   Reply With Quote
Old 05-21-2008, 06:17 AM   #2661
lsx void 3.3 ploblem
I have ploblem. What about number 7 8 in button.. please help me.
anuchit is offline   Reply With Quote
Old 05-21-2008, 06:41 AM   #2662
jacksmilzo's Avatar
inside rrconfig disable "no internazional..."
jacksmilzo is offline   Reply With Quote
Old 05-21-2008, 06:48 AM   #2663
greatwhite's Avatar
Smoke:
You were right about the drop down quick menu. I either changed it by accident, or something happened, dunno. Fixed.
I also checked for the clipping setting, but it was already enabled. Cycled it off, no difference. Turned it back on, and it worked. Must have not been written to the ini the first time for some reason. Meh, dunno.
But, new question:
When I embed my OBDII program (dashcommand), everything works fine until I try to navigate music or volume.What will happen is the embedded rogram will flash in and out during selections. IE: press FF and the embedded program disappears and reappears lng enough to see the underlying black screen where it would be embedded.
Is this a normal action or is something not set correctly in my config?
Native support for this program would be great, and at 20 bucks for a touch screen freindly OBDII program, you can't go very much wrong...........
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-21-2008, 10:00 AM   #2664
Thanks jacksmilzo...
Old 05-21-2008, 01:00 PM   #2665
super-fly's Avatar
ok i went into the gps and the compass was disabled. I enabled it and now there is a compass bar where the white spot use to be. I would just like to hav it with no compass and no white spot...like the screen shot on the first page. I updated flash player however I dont have Internet exporler installed, is that a problem?
super-fly is offline   Reply With Quote
Old 05-21-2008, 01:12 PM   #2666
eric_barcus's Avatar
superfly i did the same thing, installed hte flash update and same white bar issue
ALSO ive seen people with differnt color compass' how do we change it from the blue to something else or see thru like ive seen aswell
two lsx void noobs looking for answers now AFTER following the recommended update without seeing change
eric_barcus is offline   Reply With Quote
Old 05-21-2008, 02:17 PM   #2667
super-fly's Avatar
I've converted my itunes library album art to jpg and am able to see the album art in the library now. However, the album art will not show up on the main screen when the song is playing, it just says no album artist, like the picture a few post up. I am also trying to get rid of this white bar still and have had no luck.
Old 05-21-2008, 05:40 PM   #2668
greatwhite's Avatar
how is your library organized?
RR looks in the folder for music and then it displays the first image it sees. If the jpg is not in the folder with the song, it won't display it.
Good luck.
Leonardo Da Vinci
Old 05-21-2008, 08:09 PM   #2669
greatwhite's Avatar
Oopps, spoke too soon.
Clipping is enabled, still have the "pink screen" when minimized...................All pink except for the void "double chevron" maximize button.
Ideas?
Leonardo Da Vinci
Old 05-21-2008, 08:32 PM   #2670
hey guys im curious
ive noticed that if i have a vidual on and switch to iguidance then close it and return to the music its super slow and rr reacts ALOT slower too, but if i stop the plugin then restart it everything is fine, ive made the visu process less info and everything cant seem to fix that, maybe the iguidance map is takeing alot of ram?
HD radio skin for LSX void 3 download hugenius79 RR Skins 35 10-03-2008 12:29 AM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 12:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 09:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 01:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 07:00 AM
