07-18-2008, 04:23 PM
#2821
Quote: Originally Posted by Twinsen
What is it exactly that you're modifying in the code? Maybe I can help. I have a day job where I sit on my *** all day and maybe do about 30 minutes of actual work.
Just editing the png files and the appropriate.skin files........................
Leonardo Da Vinci
07-18-2008, 11:27 PM
#2822
Quote:
Do you have the latest version of flash?
1. I definitely have the latest flash player, but its not about flash i think, because i dont have any white boxes and im not dealing with a non working list, I mean i do have a working list, it just simply isn't flash, as you will see below, it is simply a list with two buttons on the right side, in fact when i opened it up on the skin editor they where just normal buttons. I tried looking in that personalize option and couldn't find anything about that.
Quote:
You have to change the Main Menu Layouts / Vis Options. Open the Options, and click on Personalize, then Main Menu Layouts. Here you can select the mode you're looking for.
2. PERFECT, WORKED LIKE A CHARM, THANK YOU
Quote:
Not sure on this one, although I think I have noticed that sometimes it takes about a minute for it to actually apply the rating, so I dunno.
3. It does take a minute for it to actually apply the rating, but its like it doesnt save it. So when i get back to the song its like i had done nothing.
Quote:
No clue on this one, I've been too lazy to even remove the gestures myself.
4. I guess i can live without gestures, its not that big of a deal.
Quote:
There's no coverflow that's built specifically for this skin, but you might be able to embed one that has been made for other skins.
5. Id say your wrong about that one, because i was tinkering A LOT to try and get that one, and after doing some looking around i found a screen called coverflow, from the list of screens on the skin editor it was called "coverflow.skin". I tried to find a link that would link me there from within road runner but i couldn't find it. So im guessing someone just has to point me in the right direction, i don't think its really that difficult at all.
thanks for your quick response Twinsen.
07-19-2008, 05:33 AM
#2823
#1:
If I understand you correctly, you can't get the scolling iList feature to work? Specifically, the drag and throw style scrolling?
If so, you need to go to the "option screen" in LSX, and select "turn on iLists". Now restart RR. If this doesn't work, you need to go into these folders: RR- skins- lsx - alt. Then you need to select the style you're using (IE: big vis opt 1) open the menu.skin file and edit the ilist lines. ILists are "commented" out by defaut in void. In other words- remove the backslash in front of the iLists lines.
You MUST, I repeat MUST have a version of RR that supports iLists or it will crash. Guino's site has the latest last time I checked......
And Yes, Gestures are a PITA with iLists. I turned them off also.
#5:
http://www.mp3car.com/vbulletin/1179149-post2291.html
Although it has been done. You just have to do it yourself- http://www.mp3car.com/vbulletin/1179149-post2291.html . You need a pretty powerful system to run it smoothly in RR though. The graphics requirements are quite demanding and will load the system up pretty fast. Typical low powered car computers need not apply............
If you get a working coverflow screen/skin up and running, by all means, post it! I'd love to give it a try, I just don't have enough time to work on it myself..................
Good luck.
Leonardo Da Vinci
07-22-2008, 04:32 PM
#2824
First off im really sorry of someone asked this question before me, but i swear i read as much as i can and i used  and i couldn't find what i wanted...
My questions are:
1. In the video it shows that someone is scrolling through the songs kinda like how you scroll in an iphone "springy". When I installed the skin and tried to do that, what would happen is that it would start the gesture recognition, so i took gestures off from the rr.ini....still, no help....i later realized that in one of the pictures in the "Manual" folder, the list looked different, i searched some more and found a flash file in the skin that looks the same....i tried inserting that flash file using the skin editor and that didn't work.
so, can someone please explain to me how to make it so that it would scroll through the songs like it does in the video?
PS. this is a SIIICK skin, good job liquid_smoke
lol well theres only 189 pages to look at...
I asked the same question on page 183, here is the answer i got, and it did the trick:
"u have to turn on the iList's, its in the LSX preferences"
Its what ever you call something when its even more rad than SIIICK
Uber Liquid Smoking!!
UberSick!
take your pick
07-23-2008, 12:34 PM
#2825
Quote: Originally Posted by liquid_smoke
So i guess what you really want to know is , where's that update
... yeah i know, you've heard this before. Its comeing soon!
someone asked if it would be by the end of this month, and while i cant promise anything, its very possible that will happen. The sooner the better, so i can start work on void 4.0 which will be rebuilt from the ground up and have an all new look etc. So im probably going to stop all updates on the 3.x series once it reaches 3.5 and then focus on ripping everything apart and redoing it.
more later.
Are we getting closer?  Garmin integration can't come soon enough!
07-27-2008, 06:10 PM
#2826
I'm tryingto setup MS Streets 2007 by using the embed apps option in Void. I can get the program to launch, but it takes over full screen.
I'm missing something simple, I know it.
Ideas anyone?
*EDIT*
Never mind, as usual I found the error just after my posting.
I followed the recomendation of placing ";" before the windows name. removed it and all is fine.........
Leonardo Da Vinci
07-28-2008, 05:02 AM
#2827
I have audio and can switch from FM to AM. However, I do not have the signal strength indicator and the two arrows shown above, and I can not tune into HD subchannels using HD sub button. Any help will be appreciated. Thanks
07-31-2008, 11:24 AM
#2828
Hi, I've got these looks from the skin...whats wrong? the fonts are in windows/fonts already..
how can I solve that?
07-31-2008, 11:33 AM
#2829
Re-install the skin is a quick way.
07-31-2008, 11:39 AM
#2830
May be a flash problem.
If you cant DODGE em, RAM em.
07-31-2008, 11:50 AM
#2831
i've already covered those two points and no effect.
07-31-2008, 12:27 PM
#2832
I can see firefox down in your status bar.. were you updating or installing flash from there? That's generally what the issue is with your white bar. You need to install from internet explorer.
07-31-2008, 12:42 PM
#2833
Try installing..........Never mind b3tts32 responded up there.^
08-02-2008, 08:12 AM
#2834
i've got a HQCT and can't change the band. There was some talk of a patch in this forum but i've searched and can't find it. can anyone help?
08-08-2008, 11:59 AM
#2835
Wow, seems like ever since DigiFX 4.0 came out, LSX Void gets no love anymore. Makes me kinda sad even though everything is working perfectly for me in my car.
| Thread Tools |
| Display Modes |
Linear Mode
