Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 01-04-2007, 03:08 AM   #106
SMKFree
liquid_smoke's Avatar
Quote: Originally Posted by Miles View Post
With liquid_smoke's approval, here is my attempt at providing skin(s) for Microsoft Streets & Trips 2006.
The attached zip contains 4 files:
GPS_Streets1.skin
Skin with streets app in the middle, surrounded by the commonly used buttons. By clicking on the 'FS' button in the top, it loads GPS_Streets2.skin.
GPS_Streets2.skin
Skin with streets app larger, covering up the top buttons. By clicking on the 'FS' button in the top, it loads GPS_Streets3.skin.
GPS_Streets3.skin
Skin with streets app filling entire screen except time, song title and 'FS' button. By clicking on the 'FS' button in the top, it loads GPS_Streets1.skin.
GPS_Streets_POPUP.skin
When using Streets1/2/3.skin, clicking on the 'MENU' button will open up this popup screen with a few more additional buttons.
Here are the settings I've added to Exectbl.ini within both the day and night version of the skin:
These skins use the existing images in LS latest release of the skin, so no need to add anymore jpg's.
Feel free to customize as you see fit, and a huge kudos to LS again for making such a well laid out and designed skin.
cool, thanks for the mod. I know someone was asking for something like this a few releases ago. Does this only work with 06? i have an older version collecting dust.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 01-04-2007, 10:26 AM   #107
Gixxer's Avatar
It should work with older versions. I've used the same sendkey commands on both 05 and 06
Gixxer is offline   Reply With Quote
Old 01-04-2007, 06:15 PM   #108
Should work. When you open up the GPS screen, I've associated the 'GPS' button to automatically connect the GPS and center on position.
I've seen the AutoIT script out there to do this automatically, just haven't got round to incorporating that.
Glad to share what I can with the limited skills I have w/ skins.
1997 Mustang GTS "Jenna"
VIA SP13000, 7" Xenarc TSV, 200GB, 'modified' M2-ATX, 1GB DDR400/3200, BU-353. RoadRunner + LSXVoid
Miles is offline   Reply With Quote
Old 01-05-2007, 02:16 AM   #109
GizmoQ's Avatar
This skin is Outstanding! I will admit I haven't kept up with the LSX series of skins so I realize I'm at a great disadvantage, but am I missing something on screen 2 and 3? The center sections are blank, empty, void (couldn't resist) of any information. I understand having one clean, blank page, but two. I'd like to figure out how to put the big logo and flash compass on one of them or have the option to put the same center as the main on all three.
Have you seen the work that CHUCK and others have done on adding additional functionality to the weather (added up to 6 changeable presets) and traffic (added up to 50 changeable presets) screens for those of us that travel outside of our local areas often?
XMFAV label doesn't need to be preceeded with a "=" -- that just says "XMFAV" (easy fix).
I also noticed you have no WinTV (Winamp TV plugin) button in the command lists - how do I add one?
Lastly, a request. I really like what you've done with the flash compass and was wondering if it was possible to make that a two stage flash where when you click on it, it switches between the compass and a speedo? I really think that would be OTT!
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is online now   Reply With Quote
Old 01-05-2007, 04:49 AM   #110
djmickyg's Avatar
you can use the button called CAMERA
djmickyg is offline   Reply With Quote
Old 01-05-2007, 05:01 AM   #111
djmickyg's Avatar
just a small question to everyone..
how are people switching the day and night skins?
manually?
gamma control? This would be a good option, but it hangs on resuming untill the mouse is moved.
skippy_76 rr.ini settings? also good but on changing skins it leaves a grey box over half the sceen..
Some hidden LS setting i don't know about?
Old 01-05-2007, 08:28 AM   #112
yrean's Avatar
manually?
Ive asked this a couple pages back, and there was no real answer. ive tried the gamma control also, not what i was looking for. I just want it to automagikly switch itself. like when road runner starts to load, it auto checks time, and switches skin accordingly. Right now ive been switching back and forth between the two manually. If you find out how to make this seemless. let me know here. im sure there are others that would like this option also.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
yrean is offline   Reply With Quote
Old 01-05-2007, 08:39 AM   #113
djmickyg's Avatar
have u tried the skippy_76 settings?
i have attached the alternative config editer that was around a while back which has auto the auto changing. but like i said earier this is seems to leave a grey box on the skin when changing then vanishes when i click something.. and it doesnt do it with other skins i have used.
also this config editer has the speed/gps setting which i think have been forgot about.
Old 01-05-2007, 11:09 AM   #114
SMKFree
i believe RR will automatically switch the skin based on the time thats set in general.ini. I havnt ever tested this but i know thats what the time values in this file are for and there have been times when i load RR and its on the day/night version without me switching it manually, but this seems to happen randomly. So there may or may not be a bug with this somewhere.
The values in the file are:
AutoSwitch=False
DayTime=8:00:00 AM
NightTime=6:00:00 PM
note: there are multiple general.ini files related to the day and night version of the skin, so anything you want to change in the file you should also change in the other files so it wont get overwritten.
A few of the options in the OPT screen will copy over a new general.ini file. For example, when you click the 800x4800/800x600 button it will copy a new version.
The files that need to be edited are located in these paths.
C:\Program Files\Road Runner\SKINS\LSX_VOID_NIGHT\ALT\800x480\general.in i
C:\Program Files\Road Runner\SKINS\LSX_VOID_NIGHT\ALT\800x600\general.in i
C:\Program Files\Road Runner\SKINS\LSX_VOID_NIGHT\general.ini
and same for the day version.
ill prob do some testing today to see if the auto switching works
mp3car live search
Old 01-05-2007, 11:55 AM   #115
SMKFree
no you arent missing anything, the idea is that those 2 screens are not the main screen, but extensions of the main menu. The reason they dont have the same information as the main screen is for a few reasons.
1. The main menu has about 10 different layouts or options that change something from the size of the visuals,album art, media info etc. Doing the same for the 2 secondary menus is a lot of work. If they stayed static the first thing i would hear is why cant i change them like i can the main menu.
2. i wanted an easy way to know that you are not on the main menu, thats why the background is slightly different on those two screens. Plus i dont really see anyone spending a whole lot of time on either of those screens. Its mostly just to access other functions.
If i wasnt so lazy i would just delete those 2 screens and use switch lables to change the buttons on the top.
If you want to make those 2 screens the same as the main menu, its not hard to do at all.
The only difference between them is just the lack of the items in the middle of the screen. You can just copy and past them from one screen to the other using the RRSkineditor. If you need some help on this i can post a how to.
XMFAV: I do this for testing so i can see what the label looks like (dont have xm hardware) and i allways forget to remove the = sign, i do this every release
Flash Compass:, i did not create this element, this was given to me by JohnWPB.
There is a speedo at the top of the screen (non flash though)
There is also a flash speedo that's currently not being used but is still included with the skin. Its from an earlier release of the skin and at some point i decided not to use it anymore. The file name is speedo.swf in the skins folder. I may add this back, not sure but not any time soon.
Weather:
Ive seen the features you speak of. Its not hard to add them. I considered it a long time ago but always thought to myself, how many people on a regular basis drive far enough that the weather changes?
With that said, i had plans before this last release to completely redo the weather section from scratch! Due to release pressure, it got pushed on the backburner.
I still plan on doing a weather update though, so likely preset will make there way in there somewhere.
WinampTV: use the camera button. Its named camera cuz most people dont actually have tv in there car and use the plugin for backup cams. It does with with tuner cards though.
mp3car live search
Old 01-05-2007, 12:10 PM   #116
SMKFree
zip fie corrupted.
what grey box do you get when changing what?
mp3car live search
Old 01-05-2007, 12:22 PM   #117
Eugene120's Avatar
Well. I reinstalled RR to drive C and it stoped hanging on load with this version of skin. (Flash reinstallation didn't help)...
Also changed the font to Arial:B 'cuz the default shows cyrilic characters just as black boxes.
Now I can say that the new version is MUCH faster than previous. Great work.
I've got another bug though: in WEATHER section the "degree" symbol is whown as "?"... does anyone have a solution to solve this regional_settings_problem?
Eugene120 is offline   Reply With Quote
Old 01-05-2007, 12:50 PM   #118
SMKFree
im going to shoot a pm to the author of the ratings plugin and see if anything can be done about the script requiring the default RR install path to work.
the default font is Arial Rounded, Arial Bold is a good choice also (the old default). Not sure why you would see boxes with the other.
Glad you see a speed increase.
Not sure what can be done about the ? for the degrees in Weather. There was a thread addressing this issue but i didnt read into it much at all as i never had the issue. If you cant fix it, i would just delete that symbol altogether.
mp3car live search
Old 01-05-2007, 01:15 PM   #119
Eugene120's Avatar
I found it. Here
If the symbol comes from thу server - there is nothing to do with it, but if it comes from your skin, then there is a chance to solve this by changing the symbol to 00B0 (code) - "°" <--- is this visible with your regional settings?
Old 01-05-2007, 01:22 PM   #120
SMKFree
Never mind the corrupt zip file, must be something with my laptop, downloaded on another machine and it works fine.
I must of missed the initial release of this tool. How old or new is it?
It seems good for the desktop, but a lot smaller than RRConfig and is prob a pain to use in the car. Still better than nothing though. I guess the size of ui items is a restriction of windows ui controls.
i really wish all the pieces were there to do a full config editor right inside of the skin. All the options can be set inside of RR. I believe the only major feature missing is a standard file browser inside RR to browse for paths. I have one integrated in this skin, but its not exactly what i would call a file browser, but it could be used easily for browsing for paths for the config setup. But the way the whole thing works is not idea for the task.
Still kind of confused as to why the config editor seems to be the biggest unsolved problem of RR.
mp3car live search
HD radio skin for LSX void 3 download hugenius79 RR Skins 35 10-03-2008 12:29 AM
LSX Void Error TeamRSX RR Skins 7 12-31-2007 12:52 AM
Lsx Void Error michael2 RR Skins 4 08-15-2007 09:55 PM
StreetDeck for a 1955 Buick aforget DigitalMods (Scripts / API) 9 07-29-2007 01:01 PM
LSX Void FAQ Cali Wiki Discussion Threads 1 07-23-2007 07:00 AM
