05-13-2008, 08:33 PM
#2626
Vehicle: 1996 Mercury Cougar XR7 (Sport Edition) 4.6 v8
Quote: Originally Posted by Thrasher865
You'll have to excuse me, I searched as best I could but couldn't find any details on estimated system requirements. From your experience, what can you tell me about how this skin performs on various systems? I'm thinking of building a new computer just so I can run this skin, the video looks incredible.
it runs hella fast on a core 2 duo extreme!!
and runs very well on a 2.6 ghz celaron also those are the only ones ive tryed it on!
05-14-2008, 12:15 AM
#2627
SMKFree
Vehicle: VW Passat
i just (finally) got a new carpc and the cpu is 900MHz Celleron M with 512Ram and the skin runs perfectly on it, with ilist enabled and screen transitions turned on. So i would have to say that anything that is above this should be more than enough.
The skin is developed on a 2GHz Pentium M with 2GBram and nvidia gfx card.
Tested on a 2.6GHz celleron and an old P4 laptop. I have yet to find a box that it runs slow on.
Quote: Originally Posted by greatwhite
Deos anyone now if the current 3.3 download has the 3.301 update incorporated already?
NO
3.301 was released after 3.3
Quote: Originally Posted by MunkyWrench
I found an/some issue/s with the playlist browser. (AUDIO -> LIBRARY -> PLAYLIST)
I am using iLists.
My playlist directory is set correctly.
when looking at my playlist directory it functions normally, load/save/rename playlists.
but when i assemble a new on the fly playlist and then hit save, and type in a name, and press enter, the iList does not update itself to display the additional playlist that has been saved to my playlist directory.
the playlist IS created/present in my playlist directory.
if you rename a playlist even renaming it to the exact name it had before, then the iList DOES update.
by double clicking on a playlist in the iList, I can browse into the playlist and see the individual songs
but I can't back out of the playlist at all. theres no button for it.
so my playlist editor is stuck inside ironmaidenplaylist.m4a until i restart RR.
and hitting rename renames my music files! DANGER
so in summary:
-ilist doesnt update when a new playlist is saved to the playlist directory.
-can browse right into a playlist and cant back out.
-can rename my mp3s - surely not intended??
i take it that playlist menu is not supposed to browse into the playlist files?
if i'm missing the point i apologise.
hope ive given enough detail
thanks heaps for your work, smoke.
will take a look into these issues.
From top of the head though, you should not be able to browse into the playlist, it should play the playlist instead of showing its contents.
How are you able to rename your mp3 files?
Quote: Originally Posted by kelmk
Is it possible to add a button to load a website? I like the way the .net menu does it with no menus or borders on the browser but I can't figure out how to add a custom url. I just want a page to load up pandora.com
there isnt an easy way to add a custom url to those .net buttons. What i will do in the future though, is rebuild the system so each url is custom.
I tried this but it doesn't work for me. The only thing I can do is either reload the whole skin or switch to a non ilist screen before shutting down. I have no idea why the above code wouldn't work though.
the code he pasted would only work if your sytem is set to standby when u shutdown instead of powering off. What ill do though since this is an easy workaround is build that blank.skin into the shutdown commands, so no matter how you exit, it will always go to the blank.skin screen first then exit.
05-14-2008, 03:32 AM
#2628
i am able to rename songs by browsing into the playlist by double clicking on it in the ilist, and then hitting rename. the OSK comes up with the path to the song in it.
It didnt rename it right away, so I thought it was messing with the playlist entries, but after fiddling with RR and restarting a couple times I noticed the changes I made had in fact been applied to the mp3 filenames.
If it doesnt appear to rename them, give a RR a few restarts/ a break or whatver, mayb change to another playlist. im not sure exactly how to reproduce, but it DOES rename them.
05-15-2008, 08:26 PM
#2629
SMKFree
Vehicle: VW Passat
well thats definitely not the intended functionality. The rename button is actually to rename the playlist file. But its arguable of which way should be the correct way, i can see some people wanting it this way, others the other way. Ill take a look and see if this has changed in RR and if not then look into why its doing it with the skin. Or see if there is some option to check to toggle the different methods.
05-16-2008, 02:38 PM
#2630
Jesus Freak
Vehicle: 2006 Mazda Mazdaspeed 6 GT
Quote: Originally Posted by Ramanator
That is what i am looking for but how do i find a link for my home area i.e the california san francisco bay area
05-16-2008, 02:56 PM
#2631
thanks for the reply LS
Sorry man JUST saw your response to my question
THANKS a ton for your response
i figured out the white bar is the compass, ill be looking on how to make it clear like they have it in one moment
i think ive finally solved most of my issues this morning got iguidance 4 working great this morning thanks to your skin its turning into my dream carputer
ohh ONE quick question, anyway to disable the iguidance control panel script that loads when ig4 loads? anyway to get an onscreen volume/audio control instead of the ig4 controls, btw im using the 3rd gps setting with the gps up top and the small controls on bottom
05-16-2008, 04:55 PM
#2632
Vehicle: 2004 Chrysler 300M Special
Feature request:
I finally uploaded the newest void file to the carputer.
I noticed the ilist is gone by default an replaced by a scrolling song title bar.
I like it, but it only scrolls if the song titile is too long to be displayed.
Also, if the song title is short enough, it displays it twice on the same line.
Would it be possible to have the artist album and song title scroll across the screen continually instead?
Or have I just not found the setting yet?
Cheers
Leonardo Da Vinci
05-17-2008, 03:27 AM
#2633
Vehicle: 2007 Honda Civic Si
I've looked through this thread like 200x and it appears i'm the only one with this problem. I can't get the avs window to dock in RR. I can't even make it transparent when its in classic mode so i have to switch to modern and the its transparent but still no docking
05-17-2008, 10:55 AM
#2634
Quote: Originally Posted by eric_barcus
i have two other issues however i have not been able to fix, OUTSIDE of void/rr i can play .flv (flash video files) just fine BUT when using the file browser inside of void i navigate to my video folder called "flash" and there are no files inside
IS there a place to set up file associations or recognized file formats? i believe this is where i would find my fix, yes/no
LS you originally suggested the audio file association but it didnt work this did..
AWESOME i found the fix for the video there is a VIDEO file association in the RR.ini
videofiles=.mpg,.mp4,.flv,.avi
adding the above line under the [video] options worked and fixed the .flv issue now i can watch all the youtube videos i want  (pinkfloyd synced with the wizard of oz, how can you miss out?)
also there is a spot in the RRconfig on the video tab, my eyes overlooked it till i was here "focused" at work
05-17-2008, 03:16 PM
#2635
Any help please?? I'm using winamp 5.13 and my settings are
rr.ini:
AvsTransparent=TRUE
screensaver.ini
AvsTransparent=True
FadeOnIdle=False
SecondsToFade=300
FadeInterval=10
DefaultOpacity=70
MaxOpacity=255
I can't get the avs window to embed i can't get it to be transparent at all. It doesn't seem as if winamp has this feature for the winamp classic skin. I tried using the modern and has the same result. Can anyone help me out?
05-17-2008, 03:34 PM
#2636
rr.ini:
AvsTransparent=TRUE
screensaver.ini
AvsTransparent=True
FadeOnIdle=False
SecondsToFade=300
FadeInterval=10
DefaultOpacity=70
MaxOpacity=255
Haven't read the rest of you posts but:
Check RRconfig, the utility, not the file.
Under "music" check "AVS window", then under AVS/Screensaver check "AVS Transparent". At this point, it should be working if you are in the classic skin for winamp.
It's pretty simple with the new config..............but by the looks of your ini, you have this correct.
If it's still not working, you've got a bug in your install somewhere.
Leonardo Da Vinci
05-17-2008, 04:05 PM
#2637
The craziest thing happened i layed down to take a nap and came back to the screen and started trying to make a skin for google earth and it worked.... I have no idea why.
05-17-2008, 07:52 PM
#2638
I figured this would be a good place to ask this question. How can you get the visualization to continue playing in the background when you go to the next screen?
05-18-2008, 01:26 AM
#2639
Vehicle: 05 Dodge Ram
If I understand you right, Find this Line>>/ DEFINE GOOGLEVIDEOWEATHER "googleplayer.swf?docId=5527390467850863231&hl =en" in LSXCOLORS.txt and replace it with (San Francisco)
"googleplayer.swf?docId= 5711754632996851703&hl=en"
Hope this helps you out antimatter. In addition, I have mine coded for the Detroit area and it loads weather from last summer. Its most certainly not 80 degrees and sunny here.
If you cant DODGE em, RAM em.
05-18-2008, 02:15 AM
#2640
SMKFree
Vehicle: VW Passat
unfortunately for those looking into the weather forecast videos. They no longer are being updated, so even when u do change it from the default chicago, it will be old data in the video. So this feature will likely be removed or replaced if i can find a good replacement.
| Thread Tools |
| Display Modes |
Linear Mode
