Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Old 02-12-2007, 09:51 AM   #1
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
RR Skin Checker v1.0.3
Version 1.0.3 Now released.
Added check for missing .swf files.
Added check for redundant jpg,png and swf's
Added ini file with some of the RoadrRunner default commands against the .skin file they will call. ie AUDIO --> audio_player.skin
It will now list and jpgs,pngs or swfs that are in your skin folder but do not appear to be referenced in any .skin file. Note before just deleteing these files, do double check to make sure they aren't required. an example might be freefone.swf, as it is not referenced in the .skin fiels but freefone.exe uses it.
Version 1.0.1 Beta now released.
This now also checks the .skin references in your .skin files. It does NOT as of yet check the default RoadRunner ones or those set up in ExecTbl.ini
Fellow skinners,
It may be just me, but occaisionally I find that in the development and changing of my skins I sometimes forget to update the graphic (as well as other) file references in the .skin files.
causing
http://www.mp3car.com/vbulletin/show...4&postcount=46
and
http://www.mp3car.com/vbulletin/show...1&postcount=18
and
http://www.mp3car.com/vbulletin/show...7&postcount=82
and
http://www.mp3car.com/vbulletin/show...&postcount=381
Sorry JohnWPB for the last one.
so I have quick put together a little skin check program to check for that.
This is just a Beta at the moment, I've checked it on a few of my skins and *cough have had to do a bit of editing.
At the moment it just checks for missing graphic files (ie the empty,off,on, down ones), however I hope to expand it to also check for .skin links within the .skin files.
If you would like to test it on your skins you are more than welcome, if it is useful then let me know, if not also let me know.
Also if there is anything you think can be added, also let me know.
Basically what I am saying is "I want feedback!".
Just download the file, unzip and read the readme.txt. (oh and the licence file )
Don't worry, it does NOT make any changes to any of your .skin files
E.
Original SkinChecker 897 downloads. wow!
Enforcer is offline   Reply With Quote
Old 02-12-2007, 12:18 PM   #2
Ruffy's Avatar
Ruffy is an unknown quantity at this point
Good idea on this, would like to see it expanded.
Tried it. seems to work just fine. I ran it on my development skin based on a modified Blue Devil
Quote:
Road Runner Skin Checker v1.0 Beta
Skin : DigitalFX Blue run on 2/12/2007 at 12:16:44 PM
The following graphic(s) file(s) are missing from the .skin file(s) listed
Audio_Thiumb_browser_off.jpg found in Audio_Thumb_browserX.skin
Audio_Thiumb_browser_down.jpg found in Audio_Thumb_browserX.skin
choose_number_empty.jpg found in choose_dial_number.skin
ClutterAudio_Full_Player_OFF.JPG found in Copy of Audio_Full_Player.skin
ClutterAudio_Full_Player_ON.JPG found in Copy of Audio_Full_Player.skin
ClutterAudio_Full_Player_DOWN.JPG found in Copy of Audio_Full_Player.skin
Destinator OFF.jpg found in DESTINATOR_GPS.skin
Destinator ON.jpg found in DESTINATOR_GPS.skin
Destinator DOWN.jpg found in DESTINATOR_GPS.skin
Audio_JTT_On found in JumpToFile.skin
radioshark_player_OFF.jpg found in radioshark_player.skin
radioshark_player_ON.jpg found in radioshark_player.skin
radioshark_player_DOWN.jpg found in radioshark_player.skin
radio_menu_function_off.jpg found in RADIO_MENU_FUNCTION.skin
radio_menu_function_OFF.jpg found in RADIO_MENU_FUNCTION.skin
radio_menu_function_ON.jpg found in RADIO_MENU_FUNCTION.skin
radio_menu_function_down.jpg found in RADIO_MENU_FUNCTION.skin
RRMContact_empty.jpg found in RRMContact.skin
RRMContact_off.jpg found in RRMContact.skin
RRMContact_on.jpg found in RRMContact.skin
RRMContact_down.jpg found in RRMContact.skin
RRMobile_OFF.jpg found in RRMobile.skin
RRMobile_ON.jpg found in RRMobile.skin
RRMobile_DOWN.jpg found in RRMobile.skin
found in SongReminder.skin
34 graphic file(s) were found to be missing
RR Skin Checker brought to you by Enforcer.
www.en4cer.co.uk
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 02-12-2007, 01:46 PM   #3
GF-ler's Avatar
GF-ler is on a distinguished road
very good,
is it also possible to give out a list of files without using ?
GF-ler is offline   Reply With Quote
Old 02-12-2007, 02:19 PM   #4
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by GF-ler View Post
very good,
What do you mean exactly?
Old 02-12-2007, 03:53 PM   #5
GF-ler's Avatar
your application looks inside the .skin file if all called files are exist in the path, right ?
as i start a project, i copy a lot of .swf, and other stuff into the working path.
after finish the application i dont know which files are exactly using. therefore i make a lot of notes, but by god the most i forget after one day.
so, what i want to know is, which file of the path is without using, and which call is with no file. last thing you are doing with your application.
first would be helpfull.
Old 02-12-2007, 04:00 PM   #6
Confusion Master
Enforcer's Avatar
right, I get you now.
Yes the next step is to look at all the file references within the skin files.
But you also want a list of files (swf etc) that are not actually being used?
I'll add that to list.
Old 02-12-2007, 04:25 PM   #7
1Munkey is on a distinguished road
Enforcer has a great idea. I like to throw my entire skin file onto a thumb drive and just replace the one in my car. Problem is my dev computer has a lot of "great stuff" i.e. crap that I never deleted when it got replaced. This would save me a few minutes every upload saving me like a half hour by the time i die.....well worth it. Great work!
1Munkey is offline   Reply With Quote
Old 02-13-2007, 12:49 PM   #8
Confusion Master
Enforcer's Avatar
Updated, see first post
Old 02-13-2007, 07:55 PM   #9
Beta looks good enforcer. I'm not sure if you understood the request I was talking about though:
If I have, say oldcrappy.skin, and there's no other skins referencing oldcrappy, I'd would like it if the program said: oldcrappy.skin is not referenced by any other skins. Thus, I should prolly delete it. Theory being that, aside from menu.skin or loader.skin, any skin not referenced by another shouldn't be used.
Disclaimer: I understand that this gets complicated as people call skins from exec.tbl which wouldn't be referenced in a skin.
Just a 2 cent recommendation though
Old 02-13-2007, 08:13 PM   #10
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by Readme.txt
Development of Skin Checker
I will next be looking at adding a check for the Road Runner default commands
and also those personalised in ExecTbl.ini.
Then I will look at it the other way, ie. see what files are in your skin
folder that aren't referenced in any of the .skin files.
Old 02-14-2007, 10:38 AM   #11
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
I would not have taken it so personally, if you had mentioned the skinners in the previous links above mine, and not just singled me out!!
GREAT work on the script!!!!
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 02-14-2007, 11:29 AM   #12
Confusion Master
Enforcer's Avatar
Well they were all mine
Oh!, it's not a script, it's written in VB6.
Old 02-14-2007, 12:18 PM   #13
I guess that's what I get for not updating the readme.
Old 06-08-2007, 03:00 PM   #14
EL_GRECO101's Avatar
EL_GRECO101 is an unknown quantity at this point
Excellent!!! Thanks "Enforcer"!
Virtuousness & Daring...!
EL_GRECO101 is offline   Reply With Quote
Old 09-18-2007, 10:44 AM   #15
Confusion Master
Enforcer's Avatar
Bump for new version.
John, you might want to run this
EniCar the RR Clone enitalp Software & Software Development 296 12-13-2008 06:12 PM
Mauri RR skin mauri RR Skins 122 12-06-2007 10:50 AM
Wanted: RR Skin Programer, Pays good! swwesq Classified Archive 0 12-22-2006 01:04 AM
FrodoSatelliteRadioX Skin for RR w/Proximo's CF Style Blue 800x600 by b8bboi pyros RR Skins 3 03-20-2006 10:32 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
