The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Skins
Thread Tools Display Modes
Old 03-23-2007, 09:47 AM   #1
jeep642's CarPC Specs
jeep642's Avatar
Vehicle: 2000 BMW 328Ci
My Photos: (0)
what GPS app with what skin in RR
Up until now I used nRoute as my GPS app (I load it in RR as an external GPS app), and it was a pain because all I had was the windows window embedded in RR...small buttons, pop up menus, had to use a real keyboard etc etc...
I wanna use either Robby BMW e36 skin or the simplistique skin. Wich GPS app would be better to use with these 2 skins and generally in RR (iGuidance, mappoint, destinator...)
I live in the US
I searched but didnīt really see anything about compatibility issues with either one.
Should I just get either and make my own gps.skin if itīs not in the skin I wanna use?
thanks
Cheers
_____________________________________________
If you made your own skin, visit
The CAR PC NETWORK SKIN PAGE
at the
CAR PC NETWORK
jeep642 is offline   Reply With Quote
Sponsored Links
Old 03-23-2007, 10:50 AM   #2
v8 scimitar's CarPC Specs
v8 scimitar's Avatar
Vehicle: 1971/Scimitar/SE5, Ford Focus TDCI
My Photos: (0)
You will have to look at the skins and see what they support as the authors tend to include skins for their favourite app.
Mappoint is native in RR but not as feature rich as others. For destinator you can use either freedrive or mapmonkey as destinator on its own doesn't work on a PC.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 03-23-2007, 10:54 AM   #3
MGD
MGD's CarPC Specs
MGD's Avatar
Vehicle: 2005 Chrysler 300
My Photos: (0)
In the U.S the best one IMHO is iGudiance. Works very well embedded in RR.
Can look like this.
MGD is offline   Reply With Quote
Old 03-23-2007, 02:36 PM   #4
jeep642's Avatar
My Photos: (0)
1...2...3... iGuidance it is !!!
thanks for the help guys !
at the
CAR PC NETWORK
Old 03-23-2007, 02:53 PM   #5
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
iGuidance is nice, but there are other options.
I am testing UMPC now actually, and I like it, but I miss S&T 2006 sometimes. For instance, the POI database is severely lacking in iGuidance whereas it is awesome in Streets and Trips.
iGuidance is great to use on a touchscreen with no skin needed. iGuidance auto-reroutes when you miss a turn. The 3.0 Maps are much much nicer than the previous versions and are better than S&T 06. Previous versions of iGuidance however, this was a flaw.
Streets and Trips however is not too friendly on a touchscreen without a skin. Many different routing features on S&T such as a gas warning when your tank gets low based on average mpg, and everything. Just small little things. Also you can add POI's as thumbtacks, where in iGuidance you can only add saved "favourites" which must be a street address. For example my university is huge. The default address in iGuidance is correct for the main office. The main office is about 1 mile from where the building I park at is. In Streets and Trips I just added a pushpin and saved the map, and then routed to the pushpin, not the actual address. In iGuidance, I can't do this, because it is not a real address. It is an address on a "fake road" meaning not a real mapped road, just little ones the university put in that are not governed by local laws type roads.
So read the GPS FAQ thread and it pretty much lists the pros and cons of each app. And any GPS can be embedded by making a skin and most have already been made.
THe thing I like best about iG UMPC though is the 3d maps. S&T does not do this. But I have driver issues with iG, whereas M$ has great universal support for gps pucks.
Old 03-23-2007, 03:54 PM   #6
jeffreyd_tx's Avatar
Vehicle: 06 Altima
My Photos: (0)
I said it in a few other threads but I figured it is worth spreading the word again. Garmin MapSource has, hands down, the best POIs I have seen. I have not been able to stump it. It is just very clunky to use in our environment. I have it loaded for I am looking ofr a place or need a phone number.
I have Mappoint loaded as well but dont like it much at all.
iGuidance looks the best and is the easiest to use.
jeffreyd_tx is offline   Reply With Quote
Old 03-28-2007, 04:18 PM   #7
My Photos: (0)
Can look like this.
what skin is that?
Ozzman is offline   Reply With Quote
Old 03-28-2007, 04:28 PM   #8
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Actually I use both.
iG for general navigation. S&T for lookup info when iG can't provided. Also cross check routing on both when going to an unfamiliar area (talking about hrs of driving not 15-30 minutes away.)
OP, open these files in the skin folder and change if needed.
- ExecTBL.ini to see any custom command for the GPS command
- menu.skin (menu2/menu3.skin if any) to see what command use for GPS button. Most skinner seem to use the RUN command like RUN;path-to-gps-app.exe.
- External_GPS.skin (or any Name-Of-Software_gps.skin like iguidance_gps.skin) to see what is the code/command use for that particular skin.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-28-2007, 04:33 PM   #9
MGD
MGD's CarPC Specs
MGD's Avatar
My Photos: (0)
Quote: Originally Posted by Ozzman View Post
what skin is that?
Hemi DAY/NIGHT
Still working on it.
Sponsored Links
vB code is On
Trackbacks are Off
LSX (VOID) released liquid_smoke RR Skins 1302 03-01-2007 10:43 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
How do I integrate my application with RR ? guino RR FAQ 0 09-23-2006 08:38 PM
FrodoSatelliteRadioX Skin for RR w/Proximo's CF Style Blue 800x600 by b8bboi pyros RR Skins 3 03-20-2006 09:32 PM
GPS:MM shutdown RR when switch skin MatrixPC RR Bug Tracker 5 05-12-2005 11:07 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
