Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > SkinBedder > SB Skins
Old 08-16-2006, 06:34 AM   #1
Banned
RPM_VR4's Avatar
RPM_VR4 is on a distinguished road
RELEASE: iG-Nexus (for iG3 UMPC, CF, Nexus)
iG-Nexus
Designed for CentraFuse RC2 with JustInTime's Nexus Skin beta 3.
Best with iGuidance 3.0 UMPC modified with JustInTime's Nexus Graphics Mod
For use with SKINbedder V3, Preview 2.
(Also see GE-Nexus for a matching Google Earth / GooPs SKIN)
1) Unrar iGNexus to SKINbedder\iGNexus.
2) Setup CF Nexus to run "iG3" as "SKINbedder.exe" with params "iGNexus".
3) Copy "iG3.png" to the CF\Skins\Nexus\icons directory.
4) Use ResHacker.exe to edit the iGuidanceUMPC.exe that was modified with JIT's Nexus graphics.
5) Replace bitmaps 120, 121, 139, and 238 with a single pixel bmp (dot.bmp included).
6) You can optionally replace the arrow with your car in bitmaps 176-183 [2D], 184-191/192-199 [3D])
Have fun!
RPM_VR4 is offline   Reply With Quote
Old 08-16-2006, 08:00 AM   #2
Raw Wave
justintime's Avatar
justintime is on a distinguished road
Gotta try this out! Thanks for putting it together.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 08-16-2006, 08:10 AM   #3
Raw Wave
justintime's Avatar
I think your 3D/2D button and your HEADING button, are inversed.
This does look very good man, I think I will give it a try for real!
2002 Honda CR-V
Old 08-16-2006, 08:16 AM   #4
Raw Wave
justintime's Avatar
How do you mute?
2002 Honda CR-V
Old 08-16-2006, 08:47 AM   #5
Banned
RPM_VR4's Avatar
Your right, I swapped them. Here's an updated .ini.
I left off Volume and Mute. I'd love it if you'ld want to add them or figure out some of the other graphics bugs. When Sb loads in full-screen or in windowed everything looks great, but if you switch you will notice a 1-pixel line between the map and the boarder. I noticed the same thing with the GooPs window moving over 1-pixel in my GE-Nexus skin. I'm not sure if it is a bug with CF, a bug with SKINbedder, or just something than could be fixed by editing the SKINs PNG and/or INI files.
Oh, also did you look into allowing people to "Slip-Stream" in pictures of their car with your iG3 patcher? Now that I have done it twice and I've only had iG3 a month, I am not looking forward to having to do it again if/when you release an update to your Nexus hack.
File Type: txt Right.ini.txt (983 Bytes, 226 views)
Old 08-16-2006, 08:58 AM   #6
Banned
RPM_VR4's Avatar
On second thought, I don't really like the 2D/3D and N/H toggle buttons. Should I make them normal buttons or toggle buttons, and with 3D/N, 3D/H or 2D/N (since my default buttons-up setting is 3D/H)?
...or should I leave them as alternating button up toggles? Should they say the mode pressing them will change to (as it is now if you set your iG to open up as 3D/H), or should the button text display the current mode instead?
Edit: I guess I could reduce the font size and make them normal or toggle with the text 2D/3D and N/H (or maybe a compass icon).
Old 08-16-2006, 09:06 AM   #7
Banned
RPM_VR4's Avatar
BTW: The left side nav is Menu, Dest, Save, Cancel Route. I'm not sure if I like the arrow icon for Dest or not. The boarder around iG could also be improved, but you wouldn't want to waste too many pixels thereby reducing the size of your map.
Old 08-16-2006, 09:14 AM   #8
Raw Wave
justintime's Avatar
I think the biggest problem with this design, is the resulting size of the Guidance screen. When you are about to hit a turn, ig3 will zoom in a bit and put blue vertical lines to each side of the screen. Normally its OK to lose that horizontal space, but now that you have taken another 200 pixels, it really adds on, and makes it much too small in Guidance mode
2002 Honda CR-V
Old 08-16-2006, 09:19 AM   #9
Banned
RPM_VR4's Avatar
Humm... well we could shave off another 20 or so from each side and see how it looks. I don't really use Guidance mode anyway. Auto-guidance is incredibly annoying and I just never manually switch over. Do you really us it a lot?
Old 08-23-2006, 06:34 PM   #10
sisith is on a distinguished road
Hey RPM, I cant get it to embed properly. Here are my settings right now. I goto "Settings" in CF, then I click "+" to add a new one, then I select application (should I be selecting plugin?), name it "iG3", application to run "skinbedder.exe",
parameters "iGNexus", window title "iG3". This is what is giving me all the problems I listed in my pm. Someone please tell me what Im doing wrong.
sisith is offline   Reply With Quote
Old 08-23-2006, 09:05 PM   #11
Banned
RPM_VR4's Avatar
I believe the window title is "iGNexus", not "iG3".
You can change the window title to whatever you want by editing iGNexus.ini. As long as CF matches that it will embed.
Old 08-24-2006, 01:47 AM   #12
Ok I finally got it to embed properly...but once it embeds it doesnt show the right side .png to switch 2d/3d and heading anymore...uggh
Old 08-24-2006, 03:59 AM   #13
Banned
RPM_VR4's Avatar
? This was designed for use with JITs Nexus CF Skin at 800x480. If you look at the two top pictures in the first post of this thread, you will see that one of them has Save/Cancel on left and 3D/N on right, but the other one doesn't. This is full-screen vs. normal. In JITs Nexus skin, you have to click the very left edge to switch between full-screen or normal (there is no button, just click anywhere on the left edge). You can also setup CF to default to full-screen when you first open it through the setup iG3 options.
Old 08-24-2006, 07:42 AM   #14
Raw Wave
justintime's Avatar
RPM is such a big Nexus supporter, that he knows how to use my skin better than I do LOL!
2002 Honda CR-V
Old 08-24-2006, 05:45 PM   #15
OMFG it works now...I could have sworn that I tried "iGNexus" as a window title before but I guess not....thanks for the help RPM and Justintime. Really appreciate the work you do on these forums
XP Pro on CF card working!! knubile WinNT Based 48 01-03-2005 07:48 PM
