Go Back   MP3Car.com > General > Show off your project
Old 06-29-2007, 10:34 AM   #16
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Quote: Originally Posted by goldenley View Post
nice, I drive a 2000 Honda Accord SE 4dr!
I'm new to this stuff, and I've done some research into putting a basic mini-ITX system in my car. While I'm pretty handy with electronics, I'm a complete idiot when it comes to car stuff. I bought a Chilton book which is helpful for some car things. My main question I've hit right now is power wiring. Is there an auxillary power harness somewhere I can easily hook into to power the system? Am I going to have to take apart the dash to run a new fused power wire?
My plan is to build a simple mp3 system that can be easily upgraded/expanded later (DVD, OBDII, GPS, etc...). I'm thinking a VoomPC encolsure with a M1-ATX PS somewhere near me (probably mounted with velcro). I don't want to mess with the stock tape/CD stereo that takes up both DIN slots. I'll run audio through a digital tape thingy or a USB FM xmitter. I want the enclosure out of sight and the LCD easily removeable and stored out of sight. (actually haven't thought much about the LCD since it's not strictly necessary for an mp3 system).
Running the cable is very easy and traight forward.
I use 8GA wire. A littel over kill for the job as it only use to power the PC, but what the hell, it only cost 30 cents/ft and I need only 12 ft.
- Just make an inline fuse that is about 10" to a foot from the battery.
- After the fulse, run the cable along the passenger side fender to the front of the firewall and cross over to the driver side (ok this is for a LHD car )
- Use a small screw driver and punch a hole on the main harness rubber boot to inside the cabin. Although the car is automatic, I can't find a pre-drill hole (usually for clutch master cylinder hole) on this car. May be I overlook?
- use some (very little) vaseline or motor oil and rub the cable as a lubicant to make it easier to push the cable thru the hole you just punch on the boot. I use vaseline. Wipe it clean after you pull the cable all the way thru. I use babywipe to clean it as I have a bunch of them .
Route the cable along the driver side to under the driver seat (that is where the PC is) or all the way back to the trunk if you want your back there.
If you want to run the cable on the passenger side, look around the engine bay on that side for a predrill hole and use it instead of punch a hole on a rubber boot. Make sure you use a goomet to protect the cable.
Also, use some wire loom to protect the cable a long the run.
Do it once and do it right. Run the cable is the only way to power the system right and doesn't interfere with other components/devices of the car especially if you aren't comfortable working with car. Remove the negative battery terminal and go have a drink before start working on it. Just make sure that you aren't set off the airbag. Well, I never remove the battery on when I did it as I know what I do when it come to car, but I did remove the SRS/air bag fuse cuz you never know what you accidentally do/touch.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-29-2007, 11:40 AM   #17
goldenley is an unknown quantity at this point
Is this a physical connection to the battery terminal, or can I make this in the fuse box under the hood?
I've seen this warning a few times in the Chilton book. I think I'll play it safe and disconnect the ground.
Also, any suggestions on grounding? I know anything connected to the frame should work, but I'm curious what most people do for this.
Thanks for the reply. This is definitely encouraging and it seems like this is a doable project. I may actually buy a barebones system from mp3car.com to support the forums. It seems like a better deal than what mini-box.com was offering.
Thanks,
James
goldenley is offline   Reply With Quote
Old 06-29-2007, 06:33 PM   #18
MySQL Error
MatrixPC's Avatar
Easier to connect directly from the battery + terminal. Just use a ring connector.
I get the ground from the handbrake bolt. Just pull the cup holder up to access to that bolt. No scrapping paint needed.
Old 11-08-2007, 01:26 PM   #19
knifedag007 is an unknown quantity at this point
3rd din
Do you still have the extra din
if so how much?
knifedag007 is offline   Reply With Quote
Honda Accord System Theory GeoLogic General MP3Car Discussion 10 04-03-2006 01:43 PM
LCD for 2000 Honda Civic cybler LCD/Display 2 08-03-2005 04:15 PM
Full install Honda accord aerodeck ColonelB24 Show off your project 14 09-08-2004 11:21 AM
1994 Honda Accord Coupe Computer Project project94coupe Show off your project 20 07-28-2004 11:50 AM
My 2000 Mitsubishi Eclipse Setup mestre Show off your project 6 04-30-2004 02:19 PM
