Quote: Originally Posted by
helllordkb
Yeah, that was it, LOL, was trying out a new browser.
DAMN thats a sweet install. You got everything in there. I love the stock/factory look. everything from the sub box, control switches under the armrest, the servo for monitor tilt are incredibly well done.
Im curious, did you completely cut out the back end of the radio cage to get the moterboard plate to fit in there?
Yes thatīs what I did, I bought a double DIN conversion kit from
Fullspeed and replaced all of the radio cage with that.
This is the part (from Fullspeed) that goes into the dash after all the cutting
Before cutting anything
All cutting done
helllordkb
What did you use for the monitor to create the pivot point inside the radio cage/trim? I didnt see any mount hole on your bezel for a hinge or pivot point. what is the servo controller actually doing to move the servo, jumping the voltage applied to it between two levels? in or out? any schematics for that unit?
You can see the hinge marked with the two red circles
The servocontroller doesnīt "jump" the voltage level but it jumps the frequency of the signal to the servo, and by this it moves from one end to the other. There are two switches, one for the outer position and one for the inner so that the servo will stop in the correct position.
Here is the schematic that I have drawn for the servocontroller unit. I have it connected so that when I have the switch in the control panel for the monitor in ON position it automatically moves the monitor to the outer position when I switch ACC on and when I switch off the ACC or the monitor switch it moves in.
helllordkb
What monitor did you use for your install? any problems with glare?
Itīs a normal 7 inch wide touchscreen. Well yes the sun isnīt itīs best friend, but I think I will manage...It turned out that the tinting of the windows helped out pretty much...
helllordkb
What alternator do you have in there? 120 amp stock? Was that with the capacitor enough for your electrical draw?
The alternator is stock, but I have not checked up the amps on it...I have not noticed any problems that it would too small...
helllordkb
Did you keep the stock OEM speakers in the car? I didn't see any after market amp for your speakers.
All the speakers in the doors are stock OEM (8 of them) I have placed the amplifier for the stock speakers under the glove compartment. (Will post a picture of it as soon as I get one
helllordkb
Know of any good how to or guide on pulling out that radio cage like you did? whats involved?
Thanks, Awesome! install.
A Dremel, a vacuumcleaner and patience is all that is needed
I used this
guide (in german) with some modifications.
