Go Back   MP3Car.com > General > Show off your project
Old 07-16-2007, 07:17 PM   #1
bambam's Avatar
bambam is on a distinguished road
3000GT with 10.4" Lilliput monitor
Ok, we got back form the 3SI Gathering in MI (well worth the driver BTW) so here's the write up for the lilli install...
First thing, take apart the Lilli 10.4" monitor for the bezel and store the other parts until needed.
Next, I hacked up an old console I bought off of Ebay. Notice how much plastic I had to grind off to get the bezel to fit
and the area where I want to install a Jeep cup holder (where the ashtray and lighter were):
I created a fiberglass form of the area I wanted to fill:
I figured I try to make a plastic ring by spreading Dynatron plastic around the fiberglass form:
After 20 minutes, I took the ring off and taped it into the console to let it set and harden overnight.
What a frustrating effort that was. It ended up being a waste of time and a 1/2 tube of Dynatron (and that stuff is $25 a package).
The ring was just too flimsy to use as a base for the monitor bezel.
Thankfully, Our neighbor stopped over with her pug puppy which made my day! LOL! Cute little squirt!
bambam is offline   Reply With Quote
Old 07-16-2007, 07:18 PM   #2
bambam's Avatar
Ok, back to my basic problem. What am I going to make the base out of to secure the monitor bezel and the Jeep
cup holder? After digging around upstairs, I came across a couple of boxes of abs regrind plastic I had.
I then made a sludge out of the regrind and acetone. I put the fiberglass mold back into the console and then
packed it with the abs regrind sludge:
You could feel the plastic slowly hardening and getting very hot. Because the sludge was so thick, it took a good
4 1/2 days before it hardened as solid as a rock. Next, I popped out the abs plastic mold. You can see how it
ate away at the fiberglass mold:
Next, I cut holes in the plastic mold using a dremmel where the bezel and cup holder will be and then used the
Dynatron to epoxy it into place. This plastic to plastic was a very strong bond:
Finally, the last layer of Dynatron.
And painted with bed liner spray.
Now it was time to install the monitor into the bezel. Using another old console I had, I cut off the plastic posts
with the screws and made some 'wings' so it could be taken apart in the future if need be.
And now installing the touchscreen and secure it with industrial strength Velcro.
Old 07-16-2007, 07:19 PM   #3
bambam's Avatar
After that was done, it was time to hook up the console monitor to the carpc on the test bench and cross my fingers
that everything still worked.
Great! Everything worked like a charm but I ran into my first glitch. I was using a motherboard from a
Shuttle SS51G with a 2.8G P4 processor and 1G of ram. What a piece of junk. Talk about slow and a power hog.
My old mini-itx board used to bootup in my other carpc setup in under 25 seconds using an nLite'd version
of XP that I created. This hog takes well over a minute and unfortunately, the 150W Opus power supply I am using
cannot power the motherboard, the Lilliput and the usb devices so I had to cob up a separate power link using
an old Morex 60W power supply I had laying around. You can see that on the cutting board between the keyboard
and the cup holder. I was very pressed for time getting ready for the 3SI Gathering in Michigan so I had to
use this cob job to get the job done. Using a thick plastic cutting board, I mounted the Morex, usb hub and
slim dvd drive under the passenger seat (I epoxied a plastic 'cover' over the Morex).
It fit perfect! I put the passenger seat back in and checked all the connections.... CRACK!
Damn, I never saw the metal 'wing' under the passenger seat so when I moved it back, it literally
ripped my slim dvd drive to shreads! With only 3 hours to go before we were leaving, I just took it out,
threw it in the garbage and forged on.
Luckily, everything worked although it can be a pain using 2 separate power sources because I couldn't trigger the
Morex from the Opus. Simply using the Opus 12V lead to trigger the Morex to turn on would cause the Opus to shutdown
completely so I had to use 2 separate toggle switches.
Here's how it looked installed and up and running.
And a few screen shots running RoadRunner and the fantastic DigitalFX front end
And lastly, a shot from the back. My amplifier and carpc are mounted under the extended hatch area, under the grates.
This setup worked fantastic going out to and returning from the National 3SI Gathering in Stevensville, Michigan (12 hrs each way)
and gps saved our butts several times when we hit a few traffic jams but now that I am back, there are a few things I am going to fix
like getting rid of that crappy Shuttle motherboard and getting another mini-itx board so I can power everything with just the Opus.
I also need to make a better venting solution so I can get rid of the grates which removes the entire purpose of extending the
hatch area because we needed the luggage room. I also need to hook up and program my Shuttle Express and a few other odds and ends.
Overall, I am about 70% happy with the project but made a few mistakes that need to be fixed maybe this winter when I put the car
in storage. I forgot to take into consideration, the vinyl clips that go between the console and the dash. They don't line up
correctly and it bugs the hell out of me. I should of put the entire console back into the car before I let the Dynatron dry overnight.
Hacking the console up so much made it weak in a couple places which basically made the form slightly out of whack so the
abs form and the Dynatron were also slightly out of whack. Other than that, it was a good learning experience for me.
Old 07-16-2007, 07:21 PM   #4
sporty_drew's Avatar
sporty_drew is on a distinguished road
Nice, I'm jealous I want a 10.4 Where did you get your Dynatron plastic?
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Old 07-16-2007, 09:20 PM   #5
bambam's Avatar
I had the 8" model and believe me, the 10.4 model is MUCH better. The touch screen is very sensitive and accurate. The screen is bright and extremely clear from both the drivers and passengers seat. And of course, it is very nice having the larger screen picture.
I got the Dynatron from Fisher Auto Parts but I saw it several times on Ebay too.
Old 12-19-2007, 06:20 PM   #6
Phreak Show's Avatar
Phreak Show is on a distinguished road
I cannot find the correct model on lilliput's homepage, can you please add an modell number?
Where did you buy it?
greetz
Phreak Show is offline   Reply With Quote
Old 12-19-2007, 09:49 PM   #7
Injector's Avatar
Injector is on a distinguished road
how's viewing at that angle? does it fade at all?
Injector is offline   Reply With Quote
Old 12-21-2007, 11:28 PM   #8
bambam's Avatar
greetz
I just checked on Ebay and found one here exactly like the one I have..
"Imagination is more important than knowledge." -AE
Old 12-21-2007, 11:36 PM   #9
bambam's Avatar
The viewing angles are great from the drivers seat and passenger seat and the touchscreen is very, very good (sensitive). The picture is great in late afternoon and absolutely perfect at night. The mornings are ok but mid afternoon is just about impossible to see because of the glare. I am using the DigitalFX frontend and am usually listening to mp3's during the day so I don't even turn on the monitor because I know where the screen buttons are and use the touchscreen with the monitor off.
The only bad things about my setup is because it was so big that I barely got it to fit and it "lays down" more than I want. Sometimes street lights reflect off of it which can surprise you and the other thing I don't like is that it doesn't look oem enough for me. I'm almost thinking about going to the 8" model just because of that but as far as monitor quality and picture quality, I love this model...I just want my car to look stock, like it was made for it and it doesn't have that appearance with such a big screen at that angle and the imperfections of my mod around some of the edges.
Old 12-22-2007, 02:25 AM   #10
supra_161 is an unknown quantity at this point
nice work
supra_161 is offline   Reply With Quote
Old 03-02-2008, 10:26 AM   #11
Wrenchmonkey's Avatar
Wrenchmonkey is an unknown quantity at this point
That's awesome BAMBAM did you post this on 3Si?
Wrenchmonkey is offline   Reply With Quote
Old 03-03-2008, 09:26 AM   #12
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
What were the EXACT measurements of the screen itself square please?
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 03-03-2008, 01:00 PM   #13
russoxley187 is an unknown quantity at this point
I like the 10.4 inch model from gooddeals dot com better.
for one its cheaper and the response on the touch scree is much better.
russoxley187 is offline   Reply With Quote
Old 03-05-2008, 06:01 AM   #14
bambam's Avatar
Hey thanks...appreciate it!
I forgot if I did or not so I just checked and yes, I have a thread on 3si here and a quickie to the 2 seat conversion here and a bunch of other stuff like cup holders, dyeing the rug, new HU, etc. (just do an advanced search on username bambam)
Thanks again
Old 03-05-2008, 06:02 AM   #15
bambam's Avatar
I really apologize that I can't give the measurements at the moment because my car is stored every winter and the storage garage is an hour away...sorry 'bout that.
VM7000 / Lilliput 629GL-70NP Fried Monitor Andreas384 LCD/Display 7 01-29-2007 04:28 PM
WTB 7" Lilliput Touchscreen monitor RussellB Classified Archive 0 08-11-2005 10:51 AM
2005 Lilliput Monitor Differences jtrnp LCD/Display 8 04-14-2005 01:05 AM
Alpine NVE-N077PS's RGB output to VGA input on 7" lilliput TS monitor? hsuca GPS 3 10-04-2004 05:13 PM
FS: NEW 7" Touchscreen Lilliput VGA LCD monitor - Black Housing fondoo Classified Archive 6 06-22-2004 08:06 AM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
