Go Back   MP3Car.com > General > Show off your project
Old 09-19-2007, 05:03 PM   #31
tonkadawg is on a distinguished road
finally got some resin on
the supplies:
getting the piece ready:
complete saturation:
letting everything set up and dry tonight. Will head back over tomorrow to see how it all finished up and to test fit to make sure nothing twisted.
tonkadawg is offline   Reply With Quote
Old 09-20-2007, 03:53 AM   #32
Uraijit's Avatar
Uraijit is infamous around these parts
Looking good. Looks like felt works great! Seems to have drank the resin right in.
I finally got my screen and did a semi-install yesterday. it's all up and running temporarily. I have another copy of Windows XP on the way, since I just used my laptop's disk and license to install it for now, so I'll be redoing it soon enough. But it works for now. WOOT! The screen is just mounted on the stand to the top of the console.
Greedy
-Adj.
Anybody who makes significantly more money than you do.
The Hoe-Puter Worklog
Progress (Phase one):
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Uraijit is offline   Reply With Quote
Old 09-20-2007, 06:50 AM   #33
mrbean_phillip is on a distinguished road
Good going, I like this setup
I am also using balsa wood for my setup, just to a lesser extent.....some good ideas here, thanx!
mrbean_phillip is offline   Reply With Quote
Old 09-20-2007, 12:06 PM   #34
thanks guys!
Uraijit - be sure to post up some pics of you install
I've got a question - anyone know what SEM color matches the dark tan piece I'm replacing? I've looked online but it's too hard to tell - also, doesn't appear that anyone in my area sells SEM products.
Old 09-20-2007, 05:51 PM   #35
more progress!!! This morning Dad put a second coat of resin down. I couldn't be happier with the way it turned out :
I was able to do some test fiting - screen dropped right in - nothing twisted or warped!!! Need to dress the edges and do some trimming before I can test it in the truck, but if the screen fit like before, I'm confident it will fit the console just like before.
Went ahead and applied some resin to the back side
Not sure if we'll be working tomorrow since it's my birthday and I plan on going out If we do work, it will be the trimming and dressing the edges and might also get some sanding in so next week we'll be able to shoot some primer.
Old 09-21-2007, 08:51 AM   #36
Uraijit's Avatar
Started my own worklog, so I can stop cluttering yours up. There are a few pics if you want to check them out.
Greedy
-Adj.
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Old 10-22-2007, 06:49 PM   #37
and finally some updates! Here's the screen installed and the whole bezel mounted back in the dash:
Heres a couple of pics showing how much trimming of the inner dash was needed:
got the powersupply mounted to the bottom of the case
and got the motherboard mounted to the case too:
and some off subject pics I grabbed of Dad's current project - Piper Cub:
Old 10-23-2007, 05:15 PM   #38
Uraijit's Avatar
Wow, and I thought your dad had skills just building the bezel. That plane is awesome!
Your project is looking pretty sweet too! How are you doing your sound?
Old 11-02-2007, 06:00 PM   #39
case is done - includes power supply, HD and mother board. Mounting the DVD will start next week and once that's done that should be all of the fabrication.
Old 11-05-2007, 11:51 AM   #40
Uraijit's Avatar
Where is the case going to be mounted?
Greedy
-Adj.
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Old 11-05-2007, 02:30 PM   #41
case will be mounted under where the cupholders now are. DVD will be replacing said cupholders.
Old 11-12-2007, 06:37 PM   #42
made some good progress on the DVD
this piece probably took us 3 hrs to finish up - got the curves just right. This is also probably the one piece where I learned the most from the old man
and the rest:
test fitting in the truck (might have to adjust the angle or do some more trimming to get it all to fit right)
flush mounted for the DVD:
Old 11-12-2007, 06:53 PM   #43
DK888 is on a distinguished road
Awesome fabrication! The wood work alone is phenomenal.
My 2000 Accord Project
DK888 is offline   Reply With Quote
Old 11-13-2007, 07:43 AM   #44
Uraijit's Avatar
Looking great! Can't wait to see it finished.
Greedy
-Adj.
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
Old 11-13-2007, 10:32 AM   #45
thanks guys! Hopefully all the hard work pays off!
MP3Car Infill G4 install in a 2003 Infiniti G35 (Moved Threads) voidunknown Mp3Car Infill G4 - Double Din Car Computer 4 04-11-2007 12:37 AM
2003 Toyota Matrix install Matrix_24 Fabrication 43 05-16-2006 08:01 PM
carputer in 2003 tahoe. plenty of bondo! TahoeZoo Show off your project 5 04-06-2005 08:31 PM
Lcd and Ps2 install in 2003 WRX WRichieX Newbie 3 03-10-2004 10:37 PM
M10000 install - 2003 Mazda 6 Litespeed Show off your project 17 03-08-2004 10:45 PM
