Go Back   MP3Car.com > General > Show off your project
Old 08-06-2009, 10:47 AM   #106
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Today Im receive amplifier(Audison VRx4.300):
_Dejan_ is offline   Reply With Quote
Old 08-08-2009, 06:30 AM   #107
MarkB is an unknown quantity at this point
Firstly Dejan, thanks so much for providing detailed pics & info about your build. It is very useful for newb like myself.
I would like to know why you chose the claro halo XT, instead of say the claro plus.
It seems the main advantage of the halo is the headphone out? (I note it also has RCA outputs)
I'm going to follow your progress closely regarding your audio setup.
Do you have a software/hardware setup you could recommend to run actively front tweeters, frond mids and mono sub? (5 channels)
My car only has 2 seats and I don't need rear speakers.
MarkB is offline   Reply With Quote
Old 08-08-2009, 12:12 PM   #108
_Dejan_'s Avatar
Hi Mark,
Im chose Claro Halo XT because have RCA outputs and swappable OPAMPs for all analog outputs(By default as Im read use Claro Plus little better OPAMP's) but on Halo XT I can change it to OPAMP's which sound best for me...
On my CARPC I have Intel P8400 CPU and is very on limit... This is depend of which filters you would like use... Example:
If I use Linear IIR with 1 channel I get popping because hardware can't handle it.
If I use FIR-Min I can get working 5 channel but is on CPU limit...
I think I will use linear phase mode which will work ok and use less resources...
I use currently 5ch mode(2xTW, 2xMID and SUB) and I don't need rear speakers...
Old 08-22-2009, 02:42 PM   #109
_Dejan_'s Avatar
Let look what Im do in last days...
First mounting and connecting new power supply:
Im get new battery which will be in boot...
2x
New VGA cable:
Tomorrow I will continue...
Old 08-22-2009, 09:10 PM   #110
What PS is that?
Old 08-22-2009, 10:23 PM   #111
crimpdaddy is on a distinguished road
What PS is that?
that looks like the M4-ATX... that is the same PSU that I use. nothing wrong with extra power
crimpdaddy is offline   Reply With Quote
Old 08-23-2009, 02:32 AM   #112
_Dejan_'s Avatar
Yes it is M4-ATX. Is my second unit because on first USB doesn't work and they are replace it...
Old 08-23-2009, 12:01 PM   #113
_Dejan_'s Avatar
Few new pictures...
First Im connect batteries together:
Then Im find place where will have power cable in engine place...
I must fix it that cable can't move...
Im make plate where will be mounted amplifiers, carpc...
And battery charger(Copy of CTEK XS 3600)
Old 08-24-2009, 02:39 PM   #114
_Dejan_'s Avatar
What Im do today
First ground...
Then marking positions...
Holes...
Amplifiers...
Power terminal...
Old 08-26-2009, 02:40 PM   #115
_Dejan_'s Avatar
Today my boot look like this:
Im turn on amplifiers and play trough phone because Im searching which cable go to which speaker(unmarkedcables.press)...
Old 09-03-2009, 05:27 PM   #116
_Dejan_'s Avatar
Today Im try mesaure my system with TrueRTA and get next results:
First mesaure noise in car:
Im not shure if dB is ok I think it must be cca. 10-20dB lower...
Then Im mesaure Left MID (Full Range):
And Right:
Tweeter(BugPass filter at 1.5kHz you can see slope)...
Left:
Right:
For first mesaure I think that results are ok, but I must check why sound go +/- 5dB...
In generator Im use "Pink Noise" and leave it 10sec. to make average. I think that with "Quick Sweep" has been signal more linear...
Old 09-07-2009, 12:47 PM   #117
_Dejan_'s Avatar
Today Im make new mesaures with less noise
In my previous post Im change pictures with new results(Except noise graph)... Here is few new results...
SUB (Full Range):
Left MID+TW(MID: 63Hz<->3kHz - BugPass TW: 3kHz - BugPass):
Right MID+TW(MID: 63Hz<->3kHz - BugPass TW: 3kHz - BugPass):
And all speakers together:
Old 11-11-2009, 12:21 PM   #118
_Dejan_'s Avatar
Hi,
Currently nothing special in my garage For car Im buy 15" alloy's and Goodyear UltraGrip 7+ tyres...
Here is another toy which I have
Also this winter I have plan damping car...
My Fiat Stilo 99% complete (Lilliput in Dash) antofa007 Show off your project 35 11-18-2006 01:21 PM
Fiat Brava OBD-II Compatible? Pharazon Engine Management, OBD-II, Engine Diagnostics, etc. 6 10-22-2006 11:12 AM
My First Carputer..fitted in a Fiat Bravo (UK) Daz155HGT Show off your project 13 10-22-2006 07:57 AM
Microsoft, Fiat Announce In-Car Computers Partnership uxu General Hardware Discussion 26 07-19-2004 07:45 PM
