Go Back   MP3Car.com > General > Show off your project
Old 04-08-2008, 04:57 PM   #46
TheSovereign's Avatar
TheSovereign is an unknown quantity at this point
Quote: Originally Posted by NotYou View Post
I REALLY should sit down and start an install thread, seams like a right of passage here.. =)
I've got the 'premium' Boston accoustics sytem.. Not what I would call 'premium' to be honest, but it's actually not to bad for something from the factory.
I had to pickup the Metra CHTO-01 interface, which ran about $90 after shipping. This will allow me to use the factory amp, and overcome two limitations -- the amp itself is actually turned on by CAN bus signals, and there is no 12v accesory wire easily located. The CHTO-01 gave me both, and is similar to your harness just designed for the premium system. $90 is a little high IMO, but cheaper then investing in a new amplifier -- and the wife won't notice much difference I think.
Gotcha. It sounds like your implementation will be a little easier than mine then.... Good Luck!
Do you have 4 or 6 speakers? I couldn't find anything that said how many speakers the non-premium system has. The premium system has 6, and uses its 'DSP' to act as a crossover for the front woofers and tweeters.
6 speakers as well: two small speakers in the dash, and one speaker per door.
Now the Scosche harness only provides four "inputs:" Front-Left, Front-Right, Rear-Left, and Rear-Right... no distinction for tweeters or woofers... there's just no way I'm going to be able to get decent sound without buying "filtered" speakers, is there? (or at least an "easy" way, without dismantling dash and door panels... lol)
TheSovereign is offline   Reply With Quote
Old 04-14-2008, 01:03 PM   #47
DK888 is on a distinguished road
You can add an EQ like the one I have. This will split the highs, mids and lows and send them to the correct amplifier. One being the on you installed behind your screen for highs and mids to the OEM speakers.
Maybe we can throw in the Pheonix Gold amp and bass tube this weekend?
My 2000 Accord Project
DK888 is offline   Reply With Quote
Old 04-15-2008, 09:33 PM   #48
NotYou is on a distinguished road
Hmm.. interesting, I thought the Grand Cherokee's without the premium audio system only had four speakers. You sure it doesn't say "Boston" on the little nameplate in front of the speakers on the doors? Or - with the factory audio system - do you have sound coming out of the Instrument Panel (dash) speakers? Are there really speakers in the dash, or does it just look like it? Not doubting you, just trying to figure out how to help ya.
Ya know.. I just thought of something. Can you describe the audio path you have setup? Basically, describe the cables and connection path that exists from the computer to the speakers.
I just took a quick look through your thread again, and I don't remember seeing an amplifier for your speakers. If that's the case... then most likely the reason it doesn't sound that great is your missing something to power the speakers. The non-premium system uses the amplifier in the headunit to power the speakesr... and if you don't have one then the speakers are not getting an amplifier signal (which they need to work effeciently)
NotYou is offline   Reply With Quote
Old 05-23-2008, 08:46 AM   #49
Thanks for the suggestions guys... it turns out the craptastic audio was caused by a bug in an older version of Centrafuse (RC1). Running RC3 now, but when I upgraded to RC2 the problem cleared right up. =)
As far as the amp situation is concerned, since there is no stock amplifier, I buried a small 4-channel 200w in my dash to drive the stock speakers.
Old 05-23-2008, 09:26 AM   #50
I thought my speakers and amp went bad too! Thanks Sovereign!
Old 07-30-2008, 05:23 AM   #51
RVRNET1's Avatar
RVRNET1 is an unknown quantity at this point
Q: I'm rounding up my materials for my install. So far I have:
* Dell Inspiron 8600 laptop w/2GB RAM, 250GB HDD, XP Pro
* Power Inverter (Going to run the PC from the Power Adapter in the rear (I'm cheating)
* Going to follow your plan for the display (awesome job!!!)
* Verizon PCMCIA card w/extended cable
* LinkSys or Belkin USB b/g WiFi Antenna
* XM kit here from this site (I have the Boston Acoustics system in the Jeep)
Do you see any problems here, it sounds too easy...
Any suggestions would be great. I also have a Toshiba laptop here I can also use.
There's no place like 127.0.0.1 or ./usr/home
RVRNET1 is offline   Reply With Quote
Old 08-02-2008, 08:06 PM   #52
sneakfreak864 is an unknown quantity at this point
great job, looks nice
sneakfreak864 is offline   Reply With Quote
Old 08-12-2008, 03:23 PM   #53
Looks good... the only things that I can see that might be an issue are a.) how to get the laptop to power on automatically, and b.) perhaps the issue of introducing noise into the audio because of the inverter... but I don't have experience with either of those items, and there are some threads around here that discuss those aspects in an install.
Weelll... thank YOU for your help with the audio stuff!
Thanks!
Old 08-25-2009, 12:15 PM   #54
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Do you have a link to where you purchased the nav bezel?
Thanks! Looks awesome!
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
New Age - Feature Packed, Movie Listings, Video Preview on YouTUBE,PSD'S Released ThunderStick RR Released Skins 72 07-19-2008 12:28 AM
Streets & Trips 2007 / AutoRoute 2007 - testers with touch-screens needed Marvin Hlavac GPS 20 04-12-2008 03:39 AM
GoogleEarth GPSR Tracking briefnotion GPS 117 09-11-2007 08:32 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Choosing new amp. for 2007 Jeep Wrangler jsmoriss Car Audio 3 06-28-2007 06:04 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
