Go Back   MP3Car.com > General > Show off your project
Old 03-15-2008, 10:52 PM   #61
Nermin's Avatar
Nermin is an unknown quantity at this point
Quote: Originally Posted by greatwhite View Post
I'm not sure I understand what you mean by this.....
Are you removing your head unit and attempting to power the speakers from the motherboard/soundcard directly?
If so, that won't work. The computer sound output is "line level" and needs to be amplified in order to be audible.
and no, I'm not going to connect it directly - here is the amp I got the other day
[-------------] Hardware Status
[-------------] Software Status
[-------------] Fabrication Status
Nermin is offline   Reply With Quote
Old 03-15-2008, 11:01 PM   #62
Nermin's Avatar
Old 03-15-2008, 11:03 PM   #63
Nermin's Avatar
this is the amp I want to use - however I have only 2 speaker connections (picture bellow) and I need to connect all of my speakers in car (7 in total) - how do I do that?
Old 03-16-2008, 07:53 AM   #64
greatwhite's Avatar
greatwhite is an unknown quantity at this point
It's a 2 channel amp. Clearly visable on the box. It's only made to power two speakers. I don't think I've ever seen that brand before. It's looks like it's aknock of of sony Xplod (why would anyone copy Xplod?????)
You could wire two speakers to each channel if you wanted to power 4 speakers, but I wouldn't recommend it.
It'll look pretty ghetto and probably sound like crap. Not even sure what it would do to your amp impedance wise......
I'd recommend getting yourself a good four channel amp and maybe a decent mono amp for your sub if you really want to run four speakers.
Also, you shouldn't use the infinity speakers if that's your intent. They are 2 ohm speakers, aftermarket sound equipment is meant to run 4 ohm usually.
I only run 2.1 sound myself. MB Quart 6.5 components up front and a 12" sub in the trunk. Sounds great and the rear seat passengers aren't excluded from conversation in the front seat by audio behind them (rear speakers).
Cheers
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 03-17-2008, 04:48 PM   #65
Nermin's Avatar
crap, OK - I guess buy another AMP, this time 4 channel
Old 03-17-2008, 07:07 PM   #66
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Or you could go for 2 small motorcycle amps. The ones I have are 150 watts each. So thats 75 watts per speaker, which to me is more then enough.... The even have ones that are 300 watts each, and they are super cheapppppppppppp. You can put them anywhere. Here is a link http://cgi.ebay.com/300W-2CH-MOTORCY...QQcmdZViewItem. Mine do not really generate to much heat, im sure 300 will run slightly hotter. I went with these because I dont like normal size amps, they dont look good at all. So these sit in the center console with all my USB and other components. For the SUB I bought a motorcycle amp also which puts out 650 watts, which is enough for movies and adding extra kick to music. I am not interested in booming down the street making people think someone is bombing them.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 03-17-2008, 07:42 PM   #67
Nermin's Avatar
see Jack this is exactly what I need - thanks for suggestion bro - most certainly I will need 2 of those
I dont like having music too loud so that 4 blocks down the road people can hear rattling of your trunk - I dont see need for that + it is absolutely tasteless - if I can get stock car sound from 2 of 300W amps I'll be satisfied
Old 03-17-2008, 08:51 PM   #68
HiJackZX1's Avatar
I think im going to make a new name.... everyone thinks its my name, lol..... 150 watts per speaker is alot, so you should be more then good. Also they wont be noticable... The 650 watt amp is about the size of 2 of the smaller amps put together, because of the size I can hide that too, and it wont be in the way of my puppies (when i had the two 10's with a big amp, they would cry because they couldnt lay in that spot.) Also you could tune front and rear to perfection with it being to seperate units, unless 4 channel has that ability, never played with one. You may be able to put them in the area were your head unit use to go.... I was going to do it, but I have to much modded cr@p going in there (relays for auto switch mod, and to turn on the monitor). For some reason Dodge made that space very very tight and small....
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 03-17-2008, 10:18 PM   #69
Nermin's Avatar
typing HiJackZX1 (whatever it stands for, but i did not think it's your actual name) is a lot - I make it short like that and you know who I mean
Old 03-19-2008, 12:52 PM   #70
MGD
MGD's Avatar
MGD is on a distinguished road
300 Club
Good to see another Chrysler 300 computer installer. I have a similar setup in the trunk. Also bought two 4 channel amps and mounted them to the back of the rear seats. Here are some pics of my install. I know, crappy phone pics but hey, you see them. Good luck on your install.
MGD is offline   Reply With Quote
Old 03-19-2008, 02:20 PM   #71
HiJackZX1's Avatar
It was a joke, plus i could never change the name, I already bought the domain name to start advertising my truck, kinda like a worklog, but for all aspects of the build including exterior, interior, and engine.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 03-19-2008, 02:26 PM   #72
HiJackZX1's Avatar
thats niceeeeeeeeeeeee, looks OEM, im praying that I can take my dash to Nexson, which does beautiful fiberglass work, he happens to be two cities away from me. You guys should check out his work, he does out of state work if im not mistaken. http://www.mp3car.com/vbulletin/fabr...6k-killer.html
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 03-19-2008, 07:20 PM   #73
Nermin's Avatar
MGD, thanks for the welcome and you're more than welcome to share your comments/suggestions - your install looks wicked I love the Chrysler load screen
how big is your touchscreen (it looks like 7") and where in the world did you get that wood bazel???
Old 03-20-2008, 12:21 AM   #74
tayedrumma is an unknown quantity at this point
i know i dont poke my head in at mp3car.com a lot but i had to say something.... you have such a nice car but your putting in crappy stuff from ebay and that x-plore amp... do yourself a favor and get a nice alpine 4channel amp or something like that. i have owned many alpine amps and their sound quality is good.. myself, im getting ready to drop about 6 large on the zapco dc reference amps
tayedrumma is offline   Reply With Quote
Old 03-20-2008, 12:22 AM   #75
sorry, didn't mean to sound rude, but it's almost rude to the car to put crappy equipment in it
chrysler 300 2005 anaviel Worklogs 2 01-20-2007 08:02 AM
Scion XB or Chrysler 300 Base Model? hookid Off Topic 91 04-09-2006 09:46 PM
Chrysler 300 -- need aftermarket headunit? mikemccoy Car Audio 6 12-15-2005 09:05 PM
@005 Chrysler 300 MGD Show off your project 26 12-10-2005 09:20 AM
My Chrysler 300 Install rb_selectblend Fabrication 2 08-11-2005 06:43 PM
