Been working on the van for over a year and it is getting really close to being done. One of the last things I have left to do is finish up my carputer install and polish/tweak it.
Here are some pictures of what I have done.
Speaker installed in side door. Polk because there was a good deal on them and a good friend said they were pretty good.
Side view on the roof of the enclosure I made that holds the satellite antenna for the XM radio and GPS.
Amp mounted in the wall. Computer case is just sitting there on the floor up against the wall. This is a cruising van and there is tons of room inside. No reason to hide it. Black box to the right and behind the drivers seat is the starting battery. Second battery (not pictured) is underneath the van.
10.4 inch touch screen using DigitalFX 3.0 skin with the emerald greed theme. Just below the screen, barely visible, is a slot load slimline DVD player.
Overview of the front area. Showing the two speaker enclosures I made out of fiberglass holding Polk db 6.5" speakers. You can see where the screen is. The screen is molded into the dash using some fiberglass and bondo.
12 inch Pioneer shallow mount sub in fiberglass box in rear of van.
