Go Back   MP3Car.com > General > Show off your project
Old 06-03-2008, 02:42 PM   #1
pcmofo's Avatar
pcmofo is on a distinguished road
2000 Civic. Custom Dash. Factory Finish
Hello everyone. It has been a while since I have been back on these forums. Some of you may have seen my post about creating a fiberglass sub box in the fabrication forum. I am only days away from finishing my car up now so I though it would be a good time to post up some of the pictures here for others to check out my work. (more detailed info can be found at my Project Log on my web site
Let me start off by saying that I have a 2000 Honda Civic LX Sedan. I bought it about two years ago. I started planning this car pc project 3 years ago. I chose the 2000 civic because of its dual din dash opening, perfect for a 7" screen. Somewhere along the way I stumbled upon this forum which has helped me out alot with ideas and information. Most of my equipment came from the mp3car.com store and they have some great people working there.
Lets start off with the exterior of my car then move into the electronics. Keep in mind I am trying to make my car look like "this is how it SHOULD have come from the factory"
Not long after having my car someone hit it while it was parked and cracked the back bumper in half. While that was in the shop getting replaced I bought the OEM honda spoiler and had them bolt that on as well. ~$200
Later in the summer I got the windows tinted, 25% and 35%. This way (as I live in NY) it doesnt look like I have tints as much depending on the lighting angle. But I am going for a black and silver theme here so the window tints really tie the car together.
After a year of talking about getting new wheels I finally did about a month ago. 17" Konig Tuner II wheels on Hankook tires. This was a pain to get. After I spent all this time debating what wheels to get, I finally make a decision only to find out that they are discontinued for 4-lug. I finally found someone to sell me a few and there you have it. I love the combo of black and silver and the split fork design.
And that is where my car is at now. I will post some pictures of the custom audio setup, custom dash, and computer system and some build pictures shortly.
MII1200 - 512MB - 60GB - 7" Lilliput - SiRF Star III - BT - Wi-Fi - Rear Camera - Full Audio System - Custom Dash
Project Log
|----------| Software
|----------| Hardware
|----------| Fabrication
|----------| Installation
pcmofo is offline   Reply With Quote
Old 06-03-2008, 02:44 PM   #2
pcmofo's Avatar
Interior
On to the interior. When I bought my car I was driving an hour each way to school on the highway. I wanted a car that was good on gas (check!) and that could provide me with directions (as I take many road trips etc) and have ALL of my music. Also, I wanted to have a premium sound system in my car. No, I did not want to shake the windows off the car or hear me a block away, I just wanted a balanced system.
First lets look at my interior prior to any mods. Its so innocent with its tap player and FM radio.
Well I took apart most of my interior (I even drove to school one day with nothing in the car but the front seat bolted to the floor) so that I could put in sound proofing material. I didnt want to pay people to do electrical stuff to my car( why let them have all the fun right?) an it was WAY to expensive. So all of the stuff I have done my self. I didnt want to use Dynamat because of its expense. I read online that roofing flashing works just as good. Basic concept -> less vibration of metal in your car = less noise going out and coming in. Therefore using the sticky tar like substance with the thin aluminum backing as a sound proofing material worked pretty good. I applied 2 layers with a hair dryer to mold it into place and stick it well.
Now that I put sound proofing on every interior surface of the car it was time to install the wireing for the electronics that would be going in shortly.
Now I have a history of building computers (since I was 10) and I put one in my first car (a geo prizim) way back when before the iPod could hold all your music in your pocket when I was in highschool. I knew that a computer was the best solution for me to use for all my music, dvd, navigation, and intigration with anything else in the future. Half the reason I chose this model of civic was the dash was just screaming to me PUT A LCD SCREEN HERE!!! so I did.
I know there is some myth regarding Monster cable and if it works or not. I had a friend who got me it at cost so it was the same price as cheap wire so I did all the audio wiring in monster cable and all the power wires in high quality cable from a local car shop. It wasnt cheap for all the wiring I needed but I wanted this car to sound good. I didn't spend time putting in sound proofing to hear crap out of my speakers!
Basic audio setup -> computer puts out audio a USB external audio card (5.1 ch, less noise, better processing- Audio Advantage SRM by turtle beach). This splits the audio into front, rear, and sub outputs that I can control via software independently. From there the front and rear audio signals go into an infinity 4 ch amp that puts out about 120watts per ch. This signal goes to Infinity Kappa 6x9"s in the rear and component 6" Kappa speakers in the front. All the speaker wire was re-run with heavy gauge high quality wire. The tweeters were mounted in the doors. The sub is powered by a separate 150watt Rockford Fosgate mono-sub amp. It is now powering a dual voice coil 10" Rockford Fosgate sub in the sealed fiberglass enclosure.
In summation, I used a computer with a sweet sound card to generate a good audio source. I used high quality connections and power (including a 2farad Cap) and quality amps to boost the audio quality (not just loudness) and used high end speakers to reproduce the audio clearly. This combined with the listening environment (with the sound proofing) gives me sweet sound reproduction. Yes, its loud. but more importantly, it sounds accurate and looks like its a factory install.
Here is the amps, computer, and LCD screen I integrated into the former dash piece
I had the 4ch amp and the car pc mounted to the rear of the seats to save space and help them stay cool. I stealthed the wires by running them under the amps and below the carpeting. I have since moved the PC to under the drivers seat to improve connections, access, and signal quality.
Trunk with the computer, amps and sub wired up and tested before being prettied up.
LCD screen sitting pretty in the dash. This took a considerable amount of work with sanding, bondo and painting. I redid it twice, once because it was too glossy of a finish and another time to fix a small hair line crack.
I wanted my car to look nice and be functional. Having a trunk full of sub boxes is not functional. I decided "hey lets play with fiberglass today" I built a custom sub box to hold a 10" dual voice coil sub which was just enough boom for me. See how nicely it fits into place in the wheel well.
This is the finished sub box after carpeting it and installing my sub. If it looks blury thats because the sub was fireing at the time I was taking the picture.
There were 4 blank pop out pannels in the consol. I dont know what for but I know that it was a great place for me to add in stuff of my own! In one I put a USB port to connect devices to my pc (flash drive, usb charger etc) One has the BASS control knob for my sub woofer's amp to boost the bass. One has a iGo car charger that I took apart and integrated into the car so there is nothing in the 12v cig. port. The tips are changeable so if I get a new device or phone I can just swap tips and it will charge it. The remaining port was used for a Line-In audio port so that anyone with any audio device can play music in my car ( a small jumper cable to connect it is stored in the consol. A LED indicator is above it for the security system to show the armed status etc. There is a slim DVD drive mounted vertically in the arm rest. More pics of this another time.
This is the cup holder section I modified. I replaced my stock cup holders with ones from a 98 civic that could hold a CD plater. I used plexi glass to create a custom face plate for the buttons (note the relocated AC control buttons, also with blue LED's) This worked for a while but I decided I could pull it off without taking up this much space in my car so I have since gotten rid of it and I am almost done with the new version.
Here is a nice shot of my dash running the computer software and with the new EL gauge overlays.
I am almost done with my dash... I just have one or two more buttons to add to the lower dash panel and then I can finally close it up and finish off the electronics. ... and YES there is a security system in the car. It is a remote start + security with 2 way paging functions. (which lets me know your just tried to get into my car) Also all of the electronics are not visible so you cant tell from the outside. I also have a starter disable and a disable for the computer so when I take it to the mechanics etc they cant play with it. I am also thinking of adding a keyless RFID based entry/unlock system from scratch. I am still experimenting with other security measures. Yes I am sure a good thief can get into my car and steal everything but I am just preventing the guy with some screwdrivers in his trunk from breaking in and grabbing everything he can carry.
Anyway just wanted to see what you guys think of my car. I tried to make everything look as stock as I could like it was designed to go in the car. Anyone have any other ideas or things I should add to my car?
Project Log
Old 06-03-2008, 04:05 PM   #3
Ethan537 is an unknown quantity at this point
WOW Great job! I can't wait to see the new button panel.
Ethan537 is offline   Reply With Quote
Old 06-12-2008, 09:12 PM   #4
Derwood is an unknown quantity at this point
That is really impressive man. I'm working on a project for my 02 Coupe and this just gave me quite a few ideas. Look forward to seeing the udpates.
Derwood is offline   Reply With Quote
Old 06-25-2008, 04:39 PM   #5
Aximilation's Avatar
Aximilation is an unknown quantity at this point
Thumbs up
Hey that's awesome, I have a black 01 Civic, and this really shows me what I can do, I actually have most of the same stuff planned out, it's great to see someone do it with the same car. I was actually thinking the same on the RFID starter/lock system set up at some point, possibly integrated with the locks as well. I'm thinking one or two receivers and one proxy card to put in your wallet. When you get within range X it can read the card (from a door sensor?) and unlock/pop the door for you, then when you sit down (sensor in seat) it would turn it to 'on' and optionally start for you, or use a pushbutton. The only issue is that with these cars, there's a chip in the key, so you'd basically have to mount the key somewhere near the ignition, and keep a blank around in case you ever lose power. Using one sensor (if you could get enough range) you could have it set up so when you get close enough, it unlocks the door, disables security, and turns the ignition on for you. That's how I'd like to do it, what do you think?
Aximilation is offline   Reply With Quote
Old 06-25-2008, 07:29 PM   #6
bl3nd3r's Avatar
bl3nd3r is on a distinguished road
Great job! I love all the work you put in for good quality sound. I will definitely have to do this when I find a car I want to keep for a while.
bl3nd3r is offline   Reply With Quote
Old 06-26-2008, 10:40 AM   #7
layla17 is an unknown quantity at this point
nice work!
layla17 is offline   Reply With Quote
Old 08-09-2008, 09:39 PM   #8
chengxuez is an unknown quantity at this point
Hi, I am just wondering how are those rool seal work for you, whats your feedbacks on those?
thanks
chengxuez is offline   Reply With Quote
Old 08-09-2008, 10:15 PM   #9
protias is an unknown quantity at this point
gigady.
protias is offline   Reply With Quote
Old 08-10-2008, 09:28 AM   #10
Racing_Enriquez is an unknown quantity at this point
Very good work, very good....
RACING ENRIQUEZ I TEC FABIAPUTER
http://img57.imageshack.us/img57/906...logojpgmb6.jpg
Racing_Enriquez is offline   Reply With Quote
Old 08-10-2008, 09:43 AM   #11
funkyphil's Avatar
funkyphil is an unknown quantity at this point
great job friend, could you tell me how you built the fiberglass box for the sub? I really would like to do something like that, But I have no I deal how to do so!
Thanks Phil
www.philscustomcomputers.com
funkyphil is offline   Reply With Quote
Old 08-12-2008, 08:58 PM   #12
Meltz014's Avatar
Meltz014 is on a distinguished road
Lookin' good - I especially like the sub box. What was your budget for this project? That is, if you don't mind my asking.
Meltz014 is offline   Reply With Quote
Old 01-25-2009, 08:04 PM   #13
Belerique is an unknown quantity at this point
Wow I have a 2000 Honda and I've wanted exactly this. Insert the screen and move the AC controls, oh and replace the cup holders because they are almost useless (not deep enough). Did you have any wiring guide to do the audio? If you wouldnt mind I have some more q's to ask.....
great work
Belerique is offline   Reply With Quote
Old 01-28-2009, 05:55 PM   #14
titanicmusic14's Avatar
titanicmusic14 is an unknown quantity at this point
how did you create the video switcher I would like to make one .
titanicmusic14 is offline   Reply With Quote
Old 01-29-2009, 07:14 AM   #15
chrislamb's Avatar
chrislamb is an unknown quantity at this point
Smart!!
MINI COOPER S PRO
chrislamb is offline   Reply With Quote
What is the best finish for custom dash? Wolfman Fabrication 10 06-11-2009 03:06 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
FS: Custom made Honda Civic Dash panel w/ Xenarc 7" TS J187 Classified Archive 11 03-08-2007 01:10 AM
What do you think about hiring someone to do the custom dash piece? timeshifter Fabrication 12 01-18-2007 11:17 AM
Kals Custom Escalade Dash Process EsKALad Fabrication 52 02-06-2006 01:16 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
