Go Back   MP3Car.com > General > Show off your project
Old 08-21-2008, 01:53 AM   #1
sharpmusic's Avatar
sharpmusic is an unknown quantity at this point
2005 Toyota Camry installation a work in progress
I finally installed a Eby-701 in my 2005 camry utilizing a bybyte frame .. It some customizing but it did the job. I had to drill several holes in the frame, and in ht car stereo mounting kit. I would like to fabricate some sort of bezel.
Right now I am using a docked laptop and moved my HU to the center console. I would eventually like to build a PC utilizing a Mini or Nano ITX case. But this laptop/dock has everything I need except DC power. It has Bluetooth 7 USB, Wifi (although the signal sucks under my seat), and portability of course. The down side is having to use a inverter and using ac power for the dock and the LCD. That will be the next phase when I convert the LCD to DC power instead of pluged into the inverter
I will attempt to post pics
sharpmusic is online now   Reply With Quote
Old 08-22-2008, 11:04 AM   #2
MAZDABOY is on a distinguished road
Here is some help.
MAZDABOY is offline   Reply With Quote
Old 08-22-2008, 01:51 PM   #3
yaniv's Avatar
yaniv is an unknown quantity at this point
Nice!
I think you could do a better job making it a bit more OEM. I see some smoothen plastic areas that could probably look better. Imo you need to fix your bezel.
My Car PC project
Current status: Fabricating screen
yaniv is offline   Reply With Quote
Old 10-07-2008, 03:17 PM   #4
odagled is an unknown quantity at this point
nice. I'm still trying to START on my project. Its been like 2 years. I have most the parts just need some planning. And...I'm in school so I have limited time.
odagled is offline   Reply With Quote
Old 05-02-2009, 02:16 PM   #5
sharpmusic's Avatar
I changed the bezel
I think it look a little more OEM now
what do you think?
Old 05-02-2009, 03:10 PM   #6
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
That looks incredible!
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 05-02-2009, 08:33 PM   #7
bluehcc's Avatar
bluehcc is on a distinguished road
Brezel looks factory! How do you fabricate your Brezel?
Let me share what I have done morning in my Camry.
I installed the Carnetix P1900 and Acer One Netbook inside the glove campartment.
GPS is attached above the rear view mirror with double side tape.
When the ignition is off, netbook goes into Standby mode, and it resumes from where it left last time when you turn on the ignition. It take no time to boot up. Cartnetix DC-DC does very good job in this case. It has a standby feature that still supply couple hundrey milliam amp of 19volt into the netbook to keep it up running in stanby mode whe the ignition is off. Of course, if the shut down sequence it mess up, netbook draw more power than expected, CarNetix will cut off the power, to prevent further battery drain. My Brezel doesn't good as your. Wish I can one of your
2006 Camry
Compaq Laptop
Holux GPS Iguidance 3.0
7" Xenarc Touch Screen
Carnetix 1900 Power Supplied, Wireless b/g
bluehcc is offline   Reply With Quote
Old 05-02-2009, 09:12 PM   #8
SwiftDeath's Avatar
SwiftDeath will become famous soon enoughSwiftDeath will become famous soon enough
You did a superb job on your bezel. I would also like to know what you ended up using. Plastic soldering, bondo, jb weld?
Sidenote:Whoo this post made me a bitrate for some reason!
-SwiftDeath
SwiftDeath is offline   Reply With Quote
Old 05-03-2009, 02:21 AM   #9
bluehcc's Avatar
I just realized, this is part of the Camry Double Din Kit. You can purchase it from Ebay
2006 Camry
Compaq Laptop
Old 05-04-2009, 07:24 AM   #10
da_glu is an unknown quantity at this point
that is amazing!
nice
Carpc plan=========90% -Never going to be finished!
Carpc parts==5% -Computer died
Carpc install==5% -Need to install computer
Carpc worklog-0% -Need to start that soon
da_glu is offline   Reply With Quote
Old 05-05-2009, 02:08 AM   #11
sharpmusic's Avatar
that bezel came from bybyte
Thanks it still need some work though, I installed the carnetix as well and sometimes it doesn't always put the mac mini into standby. The bezel was $21.00 at http://www.bybyte.com/images/95-8203.jpg. but I think its from the metra kit which I found afterwards for $9.99 at https://www.audiosavings.com/product...cc.r42b31.aspx
Old 05-05-2009, 05:56 PM   #12
keland44 is an unknown quantity at this point
nice to see another camry owner in the forums bezel looks lovely good job i'm planning on doing mine but my project has been postponed till next year do to finances
keland44 is offline   Reply With Quote
Work in progress: 2000 Nissan Maxima carabuser Show off your project 9 01-31-2006 12:11 PM
Prison vs Work ACHIEVER Off Topic 20 04-15-2005 02:53 PM
My work in progress carputer case kmkestell Fabrication 12 06-20-2004 10:54 PM
Acrylic single board pc case (work in progress) g60 General MP3Car Discussion 12 04-22-2003 07:50 PM
