Go Back   MP3Car.com > General > Show off your project
Old 12-16-2008, 11:27 AM   #16
Minoritydan is an unknown quantity at this point
Is Foldershare mainly for synching PCs that are not on the same network, like if its out of range of your home network it will synch folders as long as both are connected to the internet?
I see that you have an internet connection in your car - so you would not be on your home network.
I'm not finding too much info on it, I guess Live Synch has replaced it already.
http://www.downloadsquad.com/2008/11...ows-live-sync/
Minoritydan is offline   Reply With Quote
Old 12-16-2008, 01:05 PM   #17
jarred's Avatar
jarred
LiveSync just replaced foldershare, but works exactly the same way. It will work either over your local network, or over the Internet. The software automatically chooses the fastest method of transfer.
For instance, if I am in my driveway, I connect to my local network, and it does the file transfer over my local network.
If I start driving the connection will swing over to my EVDO router, and the transfer will resume over the Internet, albeit at a slower speed.
jarred is offline   Reply With Quote
Old 12-16-2008, 01:32 PM   #18
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Nice install.... How do you get SlingPlayer inside of iGuidance? Thats pretty cool. Is that a RR feature?
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 12-16-2008, 01:38 PM   #19
Is there a reason you got the EVDO router setup instead of, say, a USB connect card for your PC?
I'm considering getting internet in my car (I'm with ATT) but I'm not sure the most cost effective way.
Old 12-16-2008, 01:55 PM   #20
HiJackZX1's Avatar
I think one reason is so that other people can share his EVDO connection? Doesnt ATT limit the data connection? One thing I like about Sprint is that they are very relaxed when it comes to the amount of data usage. I went with a USB EVDO card, and it works good. Mind you it does hang when coming out of hibernation sometimes. Maybe he also usues the router for that reason, doesnt that one connect though the ethernet port? That would make it much more compatiable and less likely to act up.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 12-16-2008, 02:16 PM   #21
So you have a USB EVDO card only (no router)? How much is your monthly rate?
I'm not clear on why he has a Router and EVDO card.
Old 12-16-2008, 02:29 PM   #22
HiJackZX1's Avatar
Ok, I did a bit of research, basically the router turns you data card into a wifi hotspot. You connect the data card, usb data card, or even your cellphone to the router and it automatically configures itself. One feature that I see is that it also has a ethernet port to connect to a PC. i think that is what he has done. This would seem more stable, and allow others to share your connection, like at carpc meets. I use only the USB card, I dont want others connecting to me, lol.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 12-17-2008, 12:46 AM   #23
jarred's Avatar
jarred
The main reason is that I usually also have my laptop in the car, and the router allows me to share the connection with both my carpc and the laptop.
Another reason is connection reliability, the Cradlepoint router maintains the connection better than the Verizon software. A mobile environment is hard on wireless Internet connections, especially with my commute. I drive though a couple of dead-zone pockets, where there is no cell phone or data available.
The Cradlepoint router will automatically re-connect when coming in and out of dead-zones. It can also spoof the connection for a short time, say when my laptop is connected via a VPN tunnel. The VPN tunnel will not drop when I go through a dead zone, like it would if the card were directly in my computer, and I was using the Verizon software to manage the connection.
Another benefit is not having to install another piece of software on the CarPC, it just connects to the EVDO router like any other WiFi connection.
Plus, my carpc can seamlessly connect to my home WiFi router when I pull in the driveway, because it is higher up in the connection order.
Old 12-17-2008, 12:48 AM   #24
jarred's Avatar
jarred
Actually, I do not connect via the Ethernet port, because I need the automatic switching between my home WiFi and the EVDO WiFi.
If you use the Ethernet port, it overrides the WiFi connection for Internet access. When at home, I want the CarPC to use my Home Internet, for updates and such, so I don't go over the 5gb limit imposed by Verizon.
Old 12-17-2008, 12:52 AM   #25
jarred's Avatar
jarred
No, I'm just running IGuidance stand-alone, then I start up Slingplayer and put it in Video Only Window mode. I then re-size the window, and drag it over IGuidance.
Yeah, it would be cool to automate the process within RoadRunner somehow, but unfortunately, I'm not that good
Old 12-19-2008, 10:39 PM   #26
I'm testing out snyc on 2 machines at home. I guess it would be easier just for me to drag and drop in windows explorer if I want to sync music on my home wifi network.
I don't have Internet access in my car.
I really don't know what Advantages there would be for me to use sync. I just download music from themixingbowl - then edit the tags/add album art, then move it to my carpc.
Any thoughts?
Old 12-19-2008, 11:18 PM   #27
jarred's Avatar
jarred
Any thoughts?
If you don't have Internet access in your car, than using Live Sync really doesn't give you any advantage. The main reason I use it is I have a talk show called "Armstrong and Getty" which starts at 6:00 am and ends at 10:00am.
I record Armstrong and Getty on my home computer using a program called Applian Replay A/V. It saves the recorded web streams in 30-minute increments.
When I start my commute at 7:00am, the show starts transferring to my CarPC from my home PC via the Live Sync. It takes about 10 minutes per 30-minute incremented file (about 13mb) to transfer over the Verizon EVDO.
So I can start listening to the show at 7:10, skipping commercials, etc. By the time the first file is complete, the second one is already downloaded.
The only pain in the butt factor is that Roadrunner does not automatically add the newly downloaded files. So as the files download, I have to go into Roadrunner and add them to the playlist.
When I go to lunch the remaining files download, and I listen to the rest of the show on my way home from work.
Old 01-26-2009, 08:40 PM   #28
ViViper1 is on a distinguished road
Nice and neat install. Question, where do you keep your jack with the stealth sub there?
"The text that you have entered is too long (12638 characters). Please shorten it to 10000 characters long."
Dam it!
"The text that you have entered is too long (10418 characters). Please shorten it to 10000 characters long."
ViViper1 is offline   Reply With Quote
Old 01-26-2009, 11:29 PM   #29
jarred's Avatar
jarred
I wrapped it in a towel, and keep it where the spare tire is located.
Old 01-27-2009, 12:08 PM   #30
m4f1050 is an unknown quantity at this point
Hi, I had a question, is that 800x600 resolution you are running? I prefer to run 640x480 on mine, it's a lot easier to navigate through windows with the touchkit.
Also, Roadrunner is a Front End like Centrafuse? Do you have a link to the website so I can check on it? Thanks.
m4f1050 is offline   Reply With Quote
Just finished my Peugeot 206 Carpc + ICE install! malcs Show off your project 8 08-31-2009 04:22 AM
1999 Buick Regal LS CarPC install ronjon228 Show off your project 11 04-04-2008 06:18 AM
Mazda RX-8 Stealthy CarPC install Nerve Show off your project 18 03-28-2008 06:02 AM
Audi A6 custom install carpc with fingerprint recognition ejdeleon Show off your project 26 07-07-2004 04:25 PM
M10000 install - 2003 Mazda 6 Litespeed Show off your project 17 03-08-2004 10:45 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
