here is my cx-9 install, i make the face plate with bondoglass, because they don't sell the kit for this model, it's the first time i use bondo, but still looks ok.
here is factory
here is the center piece i need to make copy with bondo
here is the screen glue to the bondo
this is the mini amp i use, it's very small, it's like $35 it's 4ch with 300w
here is the screen put together painted and see how small the mini amp is
i had to cut the vga cable and the usb cable so i can bend them due to limited space
here is the cut and bent usb cable and the mini usb hub i use
here is the computer, i made the case and i fit everything in it
this is the reset switch and the relay for the screen, you got to have a reset switch if you run windows
in car test run
this is the ign wire to switch the power supply took me an hour to find it,
http://images1f.snapfish.com/2323232...7395%3A8nu0mrj
this hole is for the center speaker, but my don't have it, so i put my gps in it
http://images1f.snapfish.com/2323232...7395%3A9nu0mrj
push everything in
this is a test fit with out the dvd
and everything put back
