Go Back   MP3Car.com > General > Show off your project
Old 03-12-2009, 08:46 PM   #1
VENDOR - SpatialMinds
millec's Avatar
millec
99 Land Rover Discovery II - Offroad Navigation
Navigation System
In the past I had a "carputer" that did everything (AM/FM/CD/NAV/MP3/DivX/DVD etc). The trouble with this setup was that I was always worried about it if I left the truck at a hiking trailhead. I like having a PC in the car though, as I can use it for Nav, as an OBDII scanner, store my vehicle workshop manual, store/view photos, write up trip reports in the field, surf the web, and check email. I decided to go with an Ultra Mobile PC (UMPC) so I can quickly remove it from it's RAM mount and store it in my locking drawers when not in use.
After a fair amount of research into UMPCs and ruggedized hardware in general I found the TabletKiosk EO Tuftab v7112XT. This is a compromise computer. It isn't as cheap as say an Asus R2H ($650 used), but it isn't as expensive as Toughbook tablet ($4000) either. It has a sunlight visible touchscreen and has a ruggedized case. For use in an enclosed vehicle it sounded perfect to me.
I purchased the Tuftab along with the VESA compatible docking station. Pulled the metal bracket off the docking station, drilled it, and shaved it to make a permanent low profile bracket that would mate to a VESA mounting plate from RAM.
The Mighty GPS through hull antenna is really easy to mount. Mounted by popping out rear dome light, drilling a hole, threading the cable through the headliner and down the A-pillar, and popping the dome light back in. Took about 30 minutes including the time to get the drill from the shop.
I've been using this system for about 6 months now and really like it. The processor on the Tuftab is a little bit slow but it keeps up enough to not frustrate me.
The software I'm using is my company's software, Overland Navigator.
* TabletKiosk EO Tuftab v7112XT - Sunlight Visible 7" Touchscreen, Semi Ruggedized, Bluetooth, etc
* MightyGPS Weatherproof through hull SIRF III GPS
* RAM mount securing it to the dash
* ElmScan 5 Bluetooth OBDII Reader
Software:
* Overland Navigator - Touchscreen Topographic Mapping Software
* Scantool.Net OBDII Software
* Windows XP Tablet Edition
millec is offline   Reply With Quote
Old 03-12-2009, 11:09 PM   #2
damarble's Avatar
damarble is on a distinguished road
I'd like to know more about that software, Overland Nav. I could use something like that on my offroad trips.
{Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
MY INSTALLATION LOG
damarble is offline   Reply With Quote
Old 03-13-2009, 11:16 AM   #3
millec's Avatar
millec
Additional info is available on our website. As it is my company, mp3car.com rules prevent me from posting a link, but you should be able to find it if you google for "Overland Navigator".
Tags
gps, jeep, mapping, topo, umpc
Lilliput screen on Ubuntu yam125 Linux 12 01-19-2009 01:42 AM
My troubles with the intel/i810 drivers in xorg are fixed. tdb30_ Linux 0 11-03-2007 04:33 PM
Voice activated navigation for routis! 0l33l PowerVoice 352 10-03-2004 04:39 AM
