I've been lurking about on here for quite some time finally got started on my carputer. My project started back in December when microsoft and ebay were doing there 30% cashback program. I ordered a prebuilt from mocoso via ebay and a lilliput 7" screen from a random ebay seller. I intally installed it under one of the seat and ran some temp wire to get it up and running. I used a bluetooth gps adapter I had for my HTC TYTN for gps. It was pretty crude just music and maps via delarmoe.
And thats how it was untill about a month ago when I decided to get back to work on it. I ordered up a BU-353 got iG4 and centrafuse(trial). I Did permanent install of the computer behind one of the panels in the trunk area. On other models of the LR3 with rear AC unit the rear AC unit sits in this location so it was an ideal spot, it has an access hole and it has some ventalation so it worked out really well.
The screen is still on my to do list. My LR3 does not have the factory nav system so I have cubby in the dash where it would normally sit. The plan is to put it in there flush mount. But..... I really like to be able to remove the screen and hold it. So I might build a wireless screen after I do the flush mount.
For in car internet Im running an adhoc wich my iphone connect to automatically and I have a tether program by pdanet that does the rest. Or if Im using my HTC touch Pro I use wmwifirouter which turns the phone in to a wireless access point. Id like to get an express gsm card and adapter but its far down on the list because I really dont want to constantly swap out my sim card or pay for a second plan.
I run a second battery an Optima yellow top. Since the land rover is a LHD and RHD market car it has 2 battery locations of for either and than empty location which makes it easy to install a 2nd battery. I also run an isolater for the seconbattery made by
traxide out of australia. Mine is specfic for my LR3 but he makes genearal kits, worth every penny. So my main power for the carputer comes off the second battery.
So heres a run down of the system
PC
-Case: Extruded Anodized Aluminum measuring 10" x 9.25" x 3.125"/254mm x 235mm x 80mm More Info
-Processor: ATOM 330 1.6GHz Dual Core 8 Watt CPU with 1Mb L2 cache 533MHz FSB
-Hard Drive: 2.5" 160Gb SATA II More Info
-Memory:1024Mb/1Gb PC5300/667MHz
-M2-ATX Smart Power Supply Connects directly to the battery,
-Built-in Bluetooth
Screen Lilliput 701
GPS BU-353
Centrafuse
IGuidance V4
Things to get..
Offroad gps software
dinovo mini bluetotth keyboard
another screen (possibly the transreflective)
Express GSM card and usb adapter
Backup camera
TPMS
OBDII setup
My goals are to eventually have the controls on my steering wheel be able to control track of the songs. To have nice GPS software for offroad. Flush mount the screen. build a wirelless screen and or a 2nd screen in the back. Find a pkugin for slinplayer for CF. Incoporate a backup cam and do the tpms integration.
Any feedback is welcomed.
