Go Back   MP3Car.com > General > Show off your project
Old 06-27-2009, 02:04 PM   #61
jellymonster is an unknown quantity at this point
I'm a little jealous of your skill
Can't wait to see more pictures and good luck in your job interview.
I'm probably going to pinch some ideas from you, but alot of planning is needed first lol
JM
jellymonster is offline   Reply With Quote
Old 07-01-2009, 12:26 PM   #62
summer69guy is an unknown quantity at this point
edit
summer69guy is offline   Reply With Quote
Old 07-01-2009, 01:58 PM   #63
What water cooling have you got?
I'm going to go water cooled I think
Can you explain what components you have in your cooling? like what pumps, radiators, reservoirs etc you have, and how you got the speedfan to come on at 50C?
I'm hoping to do your excellent layout but upright against the back of the back seats. Need to do some measuring first though. I'll post some pics during the process, I'm hoping to do it between August to December, it's not going to look anywhere near as good as yours though so don't put your expectations high lol.
JM
Old 07-02-2009, 09:07 AM   #64
WuNgUn's Avatar
WuNgUn is on a distinguished road
First, you want Tygon tubing...I understand it's the best stuff to use.
Also, you might want to use anti-freeze/water mix, depending on where you live! I'm running 20/80% mixture...
Don't skimp on the pump...I use Swiftech MCP655 in both my desktop and car PC's.
Swiftech make some very nice rads as well. Careful here, as other company's rad inlets are very restrictive. I'd go 1/2" ID on both the CPU and chipset (if you want).
I also use a Swiftech MCRES Micro resevoir in the car...mainly to help remove any air in the system. My desktop doesn't use a rez, but a T-Line filler neck instead.
As for your CPU block, it all depends on what CPU you have I guess...
I have an old DangerDen block on my 939, and I had to custom mount it, as it was designed for a different system...
I like both the Swiftech blocks and DangerDen blocks...try to find one that uses a single metal, or is at least coated if not, to help prevent corrosion...
WuNgUn is offline   Reply With Quote
Old 07-03-2009, 07:24 PM   #65
TheGuv is an unknown quantity at this point
Great job and fantastic looking focus there... One thing about the watercooling... if you hit a pothole and shake up the coolant in the res you could get an airlock which would then leave your entire system to fry :S
You res has to be the highest point of the system (like it is in a car if you like) or this will always be a real risk.
TheGuv is offline   Reply With Quote
Old 07-04-2009, 07:32 AM   #66
WuNgUn's Avatar
The loop is so short, and the coolant flows very well, they a 'lock' would be nearly impossible...
I've tilted the case while running to purposely induce air into the system, and while it makes a fair bit of noise, and clouds the coolant with tiny air bubbles, eventually the bubbles get worked out in the resevoir and the coolant returns to normal...
At no time did I notice the flow stopping all together.
You would need to starve the pump for far longer than what a bump might cause...like roll the car onto it's roof?
Old 07-04-2009, 11:57 AM   #67
It's never impossible to get an airlock that stops the flow. Years and years ago I was doing watercooling and had to make our own waterblocks out of solid copper chunks lol... Always had various problems and one was airlocks, even if you're getting micro bubbles running through your system your cooling efficiency is down a heck of a lot to the point the CPU could start to cook, especially with a restrictive heat exchanger.
I remember another common problem was water pumps with thermal cutouts (generally used for protection against dry running), sometimes people had them cut out just from the case and water temps, so make sure your pump isn't too advanced for it's own good lol...
IMO watercooling today is a poor method to cool components given the alternative technology and products on today's market. Watercooling was most efficient when used in conjunction with tecs, but even this is rarely used now.
I would say a good quality heatsink and a couple of 120mm fans would do the job just as well if not better, and is going to be less probmatic.
Go for a large finned solid copper hs like zelman produce and add a fan (they're designed for fanless operation which means they're ULTRA efficient when used with large 120mm fans with minimal deadzones.
Old 07-04-2009, 02:33 PM   #68
thanks, it would also be alot cheaper lol.
I always thought water cooling is the best.
Old 07-04-2009, 02:52 PM   #69
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Its better, but its also alot scarier. I would $h!+ my pants everytime I drive down the road if I had water cooling. Only because if something goes wrong your equipment is wet and most likely f$^ked.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 07-04-2009, 03:04 PM   #70
joshuo is an unknown quantity at this point
^ +1
I'll say water cooling is awesome, but I wouldn't use it unless it cannot be done without it.
My current PC has 3 120mm Fans, 1 200MM fan, the cpu fan, and the graphics fan. It's not quiet, but at least i don't have to worry about water shorting my stuff out.
Water cooling would be like having a bear as a pet. It's awesome, but scary at the same time. that's why most people don't mess with it.
joshuo is offline   Reply With Quote
Old 07-04-2009, 05:17 PM   #71
WuNgUn's Avatar
lol...
Year 2, and trouble free!!
It's also about 'show' and presentation as much as it is about performance
Old 07-04-2009, 06:27 PM   #72
Tbh watercooling is no longer the king for cooling and hasn't been for some time. Infact most water pumps are louder than zelman cooling solutions that can match the cooling ability, let alone the fans on the exchanger. Vapochill replaced watercooling for many overclockers and such yonks ago.
Old 07-04-2009, 06:29 PM   #73
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
phase change cooling isnt near as cool looking in a case though imo And as he said, it's as much about show as anything else.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 07-05-2009, 05:28 AM   #74
so many things to take into account :S lol.
well, when I finally get round to the new fabrication, I'll put some more thought into it.
Anythings got to be better than my current cooling lol. I have stock CPU cooler, a 50mm intake fan, and a 4000RPM 120mm server case fan (loudest thing I have ever heard). I does the job, but it sounds like I have a havester attached to my car.
Old 07-05-2009, 05:48 AM   #75
Crinos is an unknown quantity at this point
Submerging the pump into the resovoir (wrong spelled) takes care of lot of the noise.
Cavitation is allways a problem with watercooling, the tiniest micro bubble, strongly reduse the cooling power, but a well built system, can reduse the cavitation to "next to nothing".
Allso, if you are afraid about frying the system, you allso doubt your own skills, and therefor not consider watercooling. If done right, there should be problem... though normal wear and tear should be in mind.
Just like the engines own water cooling system
Crinos is offline   Reply With Quote
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 12:28 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
